Kawasaki Zephyr 550 will only start with choke
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4  Next
garacs
PostPosted: 16:56 - 22 Jun 2024    Post subject: Kawasaki Zephyr 550 will only start with choke Reply with quote
Hello everyone!
Being a newcomer first of all I would like to present myself: I am 51, living in Berlin, Germany, and recently bought a 1991 Kawasaki Zepyhr 550 to restore. I bought it cheap and worked on it in my spare time.
The bike was not running, it had been stored in a garage for some 5 years (as far as I know, maybe more) and was needing a full rebuild, so that's what I did.
I do have mechanical experience, having owned several bikes and scooters (2T and 4T) in the past, so I am not a complete newbie.
Yet, after replacing parts with original Kawasaki spare parts, following the service manual to the proverbial "T", when it ws time to attempt the first start, the engine turned happily, but I had no spark.
Investigating the issue, I nailed it to a defect CDI. Replaced that, sparks were finally there.
Now the moment of truth...
Turned key, ignition, on, choke, new fuel... it started! I let it run to 4k for some 7-10 seconds, then slowly turned the choke lever to the off position, and the engine died...
Choke on again, engine starts, leave the choke on and try to give some gas, very slowly... it died.
To make a long story short: it starts perfectly well with the choke on, but dies as soon as I give gas or turn the choke on.
Carbs were cleaned in ultrasound cleaner, part by part (disassembled the carbs before, obviouly). New Kawasaki original gasket sets installed, new floaters, all new basically. All installed according to the manual.
Yet I have no joy. I read all other posts in this forum with similar questions, and they all point to an air leak, which I believe to be the issue, but disassembling the carbs and reassembling them several times, I can never find the leak.
Here a small video of the issue:
https://youtube.com/shorts/EWkqf4piB_g
What am I missing?
Working on it: Kawasaki Zephyr 550B 1991
garacs
PostPosted: 18:10 - 22 Jun 2024    Post subject: Reply with quote
Another small video
https://youtube.com/shorts/GSu4xObzNL0
blurredman
PostPosted: 18:44 - 22 Jun 2024    Post subject: Reply with quote
You definitely didn't confuse the jet positioning, say accidentally putting the idle jet as a main and vice versa?
garacs
PostPosted: 18:58 - 22 Jun 2024    Post subject: Reply with quote
no, as I said I followed the service manual to the "T"
garacs
PostPosted: 18:59 - 22 Jun 2024    Post subject: Reply with quote
So I removed the carbs and reset to factory standard the idle screws...
Pilot screw setting (turns out): 2 1/4 turns out
garacs
PostPosted: 19:02 - 22 Jun 2024    Post subject: Reply with quote
All jets as per standards
garacs
PostPosted: 19:04 - 22 Jun 2024    Post subject: Reply with quote
The manual... Float hight was also set to 17mm
garacs
PostPosted: 14:50 - 23 Jun 2024    Post subject: Reply with quote
Well I disassembld the carbs again, and checked the pilot jets - the were clogged from gunk from the old fuel I had used to test it out a couple of weeks ago.
Now it starts perfectly, does not bog down when giving gas, and finally holds the idle, as it should. Next steps: synchronization. Wish me luck!
https://youtube.com/shorts/PpDrTn5kTcE
PostPosted: 15:08 - 23 Jun 2024    Post subject: Reply with quote
Step 1: clean the carbs
Step 2: clean the carbs (properly this time)
RhynoCZ
PostPosted: 15:18 - 23 Jun 2024    Post subject: Reply with quote
It also sounds like you should have a look at the timing chain tension.
garacs
PostPosted: 16:24 - 23 Jun 2024    Post subject: Reply with quote
Cleaned them now... Wink
garacs
PostPosted: 17:06 - 23 Jun 2024    Post subject: Reply with quote
This is something I was not thinking to do at the moment.... But will get to it in the future eventually
garacs
PostPosted: 17:38 - 27 Jun 2024    Post subject: Reply with quote
aaaannndddd.... after a couple of days not working on it, I tried to start it, and id did only with the choke (we have 28°C today...). And I noticed that cylinder 1 does not start together with the others: it is "cold" until I rev the engine up to 5k, then finally starts and the idle settles. Yet it bogs a bit when I give some gas... but at least it does not die.
PostPosted: 08:04 - 28 Jun 2024    Post subject: Reply with quote
Wouldn't hurt to pull the plugs and see if you have a weak spark on that cylinder from cold Thinking
that_impulse_guy
PostPosted: 08:22 - 28 Jun 2024    Post subject: Reply with quote
no mention made of cleaning our all the gunk that will be in the petrol tank, the petrol tap etc.
and once done, put an inline fuel filter in....because at this rate youre going to become really good at taking the carbs on and off
garacs
PostPosted: 08:30 - 28 Jun 2024    Post subject: Reply with quote
Did that, and visually all spark plugs show the same spark: strong and clear. O also measured the distance to a metal part and it is within specs
PostPosted: 09:34 - 28 Jun 2024    Post subject: Reply with quote
Agreed. Recent new coils on my 40 yr XJ turned it into an instant starter. Your Zephyr is already 33 yrs old.
(and I think of them them as a new retro-style bike Sad )
garacs
PostPosted: 10:54 - 28 Jun 2024    Post subject: Reply with quote
It does not have issues with the coils nor with the sparkplugs. Tested them all and all values are within specs as I said before.
Can it be that the issue with the first cylinder is due to air leak via the exhaust manifold, that is not completely airtight?
As soon as it gets hot enough, it starts working...
PostPosted: 21:05 - 28 Jun 2024    Post subject: Reply with quote
My old coils also measured correct Ohms..
but I think in this case it's no your problem and nor is the leaking exhaust, my best guess is the coke/enrichment circuit on no 1 carb is blocked.
Robby
Dirty Old Man
PostPosted: 14:18 - 30 Jun 2024    Post subject: Reply with quote
It looks like every problem so far has been down to filth in the carbs.
I'm assuming cylinder 1 is on the left of the bike as you sit on it, so it is also the lowest point on the fuel system when the bike is on the side stand.
Water is heavier than petrol. It settles in the lowest point. Drain the carbs and look for water in what came out. It is likely that you have a puddle of rusty water sitting in the bottom of your fuel tank. Set the fuel tap to reserve to drain out most of it (preferably not into your carbs). Fit an inline fuel filter.
Expect this problem to continue to appear for ~1000 miles, until all of the crap and water in the fuel tank has been flushed through. Petrol with ethanol in will help to absorb the water.
Two main things that cause this problem:
1. Condensation. Fuel tanks breathe a bit. Moisture in the air gets into your fuel tank, condense on the walls of the tank, and drips down to sit under the fuel for the rest of time. Keeping the fuel tank full helps with this, as well as using it regularly. It's a problem on bikes that have sat in a shed for years.
2. Leaking fuel filler cap. Rain gets in.
garacs
PostPosted: 19:30 - 02 Jul 2024    Post subject: Reply with quote
It could be a good guess, but:
    1. the gas tank was emptied completely back in March, when I bought he bike. Since then, it was kept inside my "office": never been out under the rain until now.
    2. the carbs were cleaned in ultrasonic cleaning machine, new gaskets installed, all jets cleaned (well until I had to clean them again, a week ago)
    3. I did install a new fuel filter, right before the carbs
    4. the bike is not kept on the side stand, but on front and rear wheel stands, keeping the tires off the ground and the bike perfectly straight
    5. I put in new oil + new oil filter
    6. I installed new sparkplugs (same brand and part number as per maintenance manual from Kawasaki)
    7. all electrical cables were checked and I even replaced them with a new (used) wiring, since mine had some botched connectors and some cables were damaged. This was done in April
    8. I completely stripped down the bike while restoring it, down to the frame, and checked every bolt and nut rebuilding it
    9. rebuilt the brake calipers front and rear, and installed new Brembo brake pads. Next is the steel braided lines, in the cart to be purchased
    10. New battery, new fuses... new CDI...
As you can see, I am way over and beyond that part of having water in the tank. As I said before, I am still wondering if a leak in the exhaust where it connects to the cylinder head could cause the issue: yes or no?
garacs
PostPosted: 19:36 - 02 Jul 2024    Post subject: Reply with quote
This could be it, but I am not sure, since all carbs were disassembled and cleaned in ultrasonic. I would need to remove the carbs again to verify that, but it is indeed a hassle, and I did it 3 times already in the past 2 weeks, without finding any issue. Could there be another reason?
Robby
Dirty Old Man
PostPosted: 19:46 - 02 Jul 2024    Post subject: Reply with quote
An exhaust leak should not cause this issue. It can make the bike run slightly lean on that cylinder, but not enough to cause your problem. You should still fix it, but don't expect it to do anything.
The most obvious explanation for your problem is still something clogging up the number 1 carb. My reasoning is that you're not getting enough fuel through at low power requirements - so fuel isn't getting through the small holes. When you have the engine spinning faster and a higher power requirement, you are getting fuel into the engine through the bigger holes.
So I would be checking that carb, yet again. I would also be going through everything upstream of it - fuel line, carb fuel rail, filter, fuel tap, tank. Looking for any rust or gunk and cleaning it out.
If the tank has any sign of rust inside, I tend to treat them with phosphoric acid. A 4L bottle is cheap and does the job. Just don't get it on aluminium or rubber parts, unless you want them to dissolve.
blurredman
PostPosted: 08:02 - 03 Jul 2024    Post subject: Reply with quote
Even coils that spec up well can be problem.
sickpup
Old Timer
PostPosted: 09:13 - 03 Jul 2024    Post subject: Reply with quote
Inlet manifolds and airbox manifolds are usually rock hard and cracked on these. Genuine new Kawasaki ones in my experience are also rock hard and cracked, its always the first thing I look at on these.
Also I seem to remember the inlet manifolds use a stupid spring retainer around the carbs instead of a clamp, they let in air.
The last post was made 1 year, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 135.99 Kb
