Recommend me a power bank / power station
TravisBickle
PostPosted: 07:44 - 01 Jul 2024    Post subject: Recommend me a power bank / power station Reply with quote
Three of us are touring Europe next month (camping).
We'll all have handlebar mounted phone chargers but I imagine we're going to need recharge facilities for various devices during the evening.
Can anyone recommend me a decent/reputable brand power bank / power station that can take a 12v input (SAE) to recharge while riding that we can all use to charge our devices once we get to the site? Probably need around 6 USB outputs I should imagine.
I've had a quick look and most coming up are either way too big, some cheap generic Chinese crap, or too small (single person use).
2024 BMW M1000XR
2021 Honda CMX500 Rebel S
2016 Triumph Tiger 1050 Sport
PostPosted: 08:39 - 01 Jul 2024    Post subject: Reply with quote
Anker is a decent make.
One to charge 6 devices is going to be huge though (think of the size of the batteries of the 6 devices all in one place, it has to be at least that big to charge them all once). Probably be better if each person took a smaller one and charged it themself.
TravisBickle
PostPosted: 08:54 - 01 Jul 2024    Post subject: Reply with quote
Good point!
Being a bit of a mother hen though as the other two are only kids (20s) so wanted to have a backup for them as well if needed.
I was thinking of taking one of these as it will serve as a jump starter as well if needed (and also a lot of jump starter / power bank units only take a USB-C input whereas this one takes a 12v input):
https://www.amazon.co.uk/NOCO-GB150-UltraSafe-Lithium-Gasoline/dp/B015TKSSB8/?th=1
Just not keen on relying on USB socket on the bike to charge the unit we'll all be relying on to charge our stuff (had a USB output on the bike fail on my last bike), would rather have 12v straight from the battery.
BUT it's only got one USB output!
Might have to have a rethink...
2024 BMW M1000XR
RhynoCZ
PostPosted: 11:20 - 01 Jul 2024    Post subject: Reply with quote
Can't you rent a power station/bank unit instead?
Freddyfruitba...
PostPosted: 11:33 - 01 Jul 2024    Post subject: Reply with quote
Excellent idea taking one which will double as a jump starter - it's what I do myself, having been caught out a couple of times with a dead bike battery. But you certainly don't need a mammoth thing like that massive £282 Noco gadget - that will apparently give you 80 jump starts per charge and will start engines up to 9 litres! Noco (who are well though of) do smaller versions, though I have a Halfords one, which I use as a phone charger on occasions... needless to say I've never needed to use it to start a bike since I've owned it, but it's good for peace of mind. Mine is no longer sold, but this looks like the nearest equivalent:
https://www.halfords.com/motoring/battery-maintenance/jump-starters/halfords-advanced-lithium-jump-starter-2l-100355.html
Regarding the single USB output, which will be common to all of these boosters - you can certainly buy USB adapters (eg https://www.amazon.co.uk/dp/B0BGJCXY22) but I've no idea whether they would play nicely when used specifically to charge multiple devices at the same time.
PostPosted: 12:00 - 01 Jul 2024    Post subject: Reply with quote
If you're looking at spending that much, if you can find room for it, you could fit a leisure battery to your bike for much less.
Basically what they do on camper vans, you have a charge relay which only sends charge out once the main battery is fully charged, it then sends power to a second deep cycle leisure battery (a deep cycle battery is happy to be discharged a long way then charged back up repeatedly). Then you hook up your devices to the leisure battery, be that a multi-port USB charger or even an inverter.
The advantage of this is you never eat into the charge on the main vehicle battery.
They usually use a great big lead acid battery for this mounted on the van frame. people even run mivrowaves and TVs off them. You do get smaller ones too, so likes of a 3.5Ah deep cycle lithium battery is fairly compact and light and that's 3500mAh which is more than the biggest anker powerbank, it would run a fairly meaty sound system all night, a couple of lights and charge a lot of phones.
TravisBickle
PostPosted: 12:43 - 01 Jul 2024    Post subject: Reply with quote
Problem with the smaller ones by Noco is they don't take a 12v charge input, only USB. Like I said I could use one of the USB outlets on my bike to charge it (I think there's one under the seat, not checked yet) but I think a 12v would be much more reliable as I can just plug it straight into the SAE from the battery. I could also sling it in the car for future use after I get back from tour as a backup.
The USB hub/splitter is a good idea, thanks. If it doesn't play ball, the other two will just have to wait their turn until I've finished charging my siht!
It's a nice idea, but probably more appropriate for a GS or something similar. Where would I put one on a M1000XR? At least with a portable power bank like this I can sling it in the car or indoors when I'm done with it, I probably won't want to carry the extra weight of a leisure battery the rest of the time apart from one or two long tours to Europe every year.
2024 BMW M1000XR
PostPosted: 13:09 - 01 Jul 2024    Post subject: Reply with quote
I use these buck converters to fit USB power supplies to vehicles that don't have them. I generally use a fused switched live but you could also directly hook it to the battery or whatever 12v charge socket you have.
https://www.amazon.co.uk/Ytesky-Inventor-Converter-Transformer-Adapter/dp/B07QQ587K3
The last post was made 2 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 64.5 Kb
