| Author |
| LatencyXR |
 LatencyXR Derestricted Danger
| Back to top |
| Nobby the Bastard |
| Back to top |
| stinkwheel |
 Posted: 18:17 - 02 Jul 2024 Post subject: |
You can't test a reg/rec with a normal multimeter, it has componants that react to loads in different ways and a multimeter doesn't put that much load on.
So it's a process of elimination. You check the stator windings and you check the connections to and from it. If they are all fine, the reg/rec is suspect.
You've done the static test of the stator. You can also do a dynamic output test using your multimeter on volts AC connected to the stator output with the reg/rec disconnected. I don't know what sort you have fitted because you are inexplicably reluctant to say what make and model of bike/engine it is so you'll need to work that out for yourself because there are a couple of different ways it could be wired.
If you're getting a good AC output going to the reg/rec from the stator and good continuity to the battery and earth from it, it's faulty. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| LatencyXR |
| Back to top |
| Nobby the Bastard |
| Back to top |
| stinkwheel |
 Posted: 19:30 - 02 Jul 2024 Post subject: |
I'd be inclined to test the AC output at the reg/rec connector (with the reg/rec disconnected), so you can confirm the power is getting that far. As above, a decent and roughly equal AC voltage between each pair. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| LatencyXR |
| Back to top |
| LatencyXR |
| Back to top |
| Nobby the Bastard |
| Back to top |
| Nobby the Bastard |
| Back to top |
| stinkwheel |
 Posted: 20:35 - 02 Jul 2024 Post subject: |
Sounds like you need a new reg/rec.
The stator produces AC and as you've seen, up to 35V on each phase.
The regulator rectifier rectifies the AC into DC then regulates it to around 13-14V.
If there's 35v going in on your yellows and the voltage doesn't go above resting battery voltage when the engine is revved, either the reg/rec isn't connected to the battery or it's dead. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| LatencyXR |
| Back to top |
| Nobby the Bastard |
| Back to top |
| Nobby the Bastard |
| Back to top |
| LatencyXR |
| Back to top |
| Nobby the Bastard |
| Back to top |
| LatencyXR |
| Back to top |
| LatencyXR |
| Back to top |
| WD Forte |
 WD Forte World Chat Champion
| Back to top |
| LatencyXR |
| Back to top |
| jeffyjeff |
 jeffyjeff World Chat Champion
| Back to top |
| that_impulse_guy |
 that_impulse_guy Scooby Slapper
 Posted: 07:59 - 04 Jul 2024 Post subject: |
you've eliminated everything else, the reg/rec is like...£5 i think on ebay (figure of speech...theyre about 12-15£). its a pretty generic thing at this point in time. ____________________ Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R |
| Back to top |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
| Back to top |
| A100man |
 A100man World Chat Champion
 Posted: 11:12 - 04 Jul 2024 Post subject: |
| LatencyXR wrote: | .. and the wiring diagram is in Chinese |
but, but 'Brixton' is a French motorcycle brand...  ____________________ Now: A100, GT250A, XJ598, FZ750
| Back to top |
| Nobby the Bastard |
| Back to top |
The last post was made 1 year, 218 days ago. Instead of replying here, would creating a new thread be more useful? |
