Checking valve clearances - do i need to drop the oil
baggy73
PostPosted: 11:00 - 01 Aug 2024    Post subject: Checking valve clearances - do i need to drop the oil Reply with quote
Have a CG125es 2006. need to check the valve clearances, got a haynes manual and started to remove the engine casing. and oil leaking. I am totally new to this bike maintenance thing and am probably being very stupid but should i drop the oil completely, or is a little oil going to escape only. I only did an oil change 2 days ago then realised I needed to check the valve clearances.
WD Forte
PostPosted: 11:02 - 01 Aug 2024    Post subject: Reply with quote
No, there will probably be a wee dribble as you remove the 'rocker cover', but that's all.
You might need a gasket if the current one breaks or tears as its removed, but if to comes off whole and looks healthy you can generally re use them.
Fit a new one if you wish of course.
bikers smell of wee
baggy73
PostPosted: 11:43 - 01 Aug 2024    Post subject: Reply with quote
Thank you for that. I had oil dribbling out of the side engine casing i was removing to get to the fly wheel. is this normal.
WD Forte
PostPosted: 11:52 - 01 Aug 2024    Post subject: Reply with quote
What?
the headline is "Checking valve clearances" now you're removing the side casings too?
If you're doing that then of course you'll lose the oil and want to drain the oil into clean container first or just add fresh stuff after re assembly.
bikers smell of wee
Ducked
PostPosted: 16:36 - 01 Aug 2024    Post subject: Reply with quote
Perhaps you are removing the side cover to see the timing marks and to turn the engine over?
On the SYM Wolf, a CB125 (similar apart from not being a pushrod engine) clone, there are circular threaded ports that you can remove for that, which prevents significant oil loss.
I would expect a CG to have similar arrangements, though I dont know this for a fact.
PostPosted: 08:54 - 04 Aug 2024    Post subject: Reply with quote
There should be a smaller port, don't take the side case off.
baggy73
PostPosted: 19:44 - 06 Aug 2024    Post subject: Reply with quote
so much for haynes and the internet. they had the casing removed, must be an earlier modal. will try and look through the holes.
The last post was made 2 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.77 - MySQL Queries: 14 - Page Size: 48.86 Kb
