| LatencyXR |
 LatencyXR Derestricted Danger
| MarJay |
 MarJay But it's British!
| LatencyXR |
| Easy-X |
 Easy-X Super Spammer
 Posted: 19:32 - 25 Jul 2024 Post subject: |
Try this:
https://sprocketcalculator.com/ ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Ste |
 Ste Not Work Safe
 Posted: 00:37 - 26 Jul 2024 Post subject: |
According to my book of Tef volume 3 chapter 8:
Bigger the rear wheel sprocket, smaller the gearbox sprocket, 'lower' the gearing.
Smaller the rear wheel sprocket, bigger the gearbox sprocket, 'taller' gearing.
lower gearing = higher acceleration
taller gearing = higher top speed.
IN THEORY.
But, speed is an expression of 'power'.
Power = Force x Speed.
So Speed = Power / Force
Riding along, force you are working against is 'Drag', force you have shoving you is 'Thrust'.
And this is where it gets complicated!
Engine has a power curve. As the engine revs increase, so the power it makes increases, gets to a 'peak. then starts to drop off.
Coming from the engine, Power is Torque x Revs....
Gear up, and you increase the rear wheel revs, but you reduce the 'Torque' which is whats giving you the 'Thrust' to punch your way through 'drag'.
So, if you up-gear, it WONT necessarily make the bike any 'faster'.
Because the 'Thrust' you get from the motor isn't enough to over come drag... so the bike will actually go SLOWER.
Conversely, if you lower the gearing, you will increase the 'torque' and hence thrust at the rear wheel, which COULD give you some entra force to overcome drag and go a bit faster....
BUT depends on the shape of the power curve, where 'peak' power is 'made' and how much is drops off either side of that peak.
If you gear too high, then you will never get the engine to rev up to peak power and deliver full-force
Gear too low, you will run out of revs before you reach a road-speed where you lack 'thrust' to go any faster.
So to get 'best speed' its a question of finding the 'optimum' and finding the exact gear-ratio that gives you exactly the 'speed' that has the 'Drag' you have the power to beat....
Most bikes as standard are USUALLY slightly 'over-geared' so that the engine revs are knocked back for more relaxed 'cruising' at a speed a lot below thier pottential maximum.
So its more often that LOWERING the gearing, not only increases acceleration, but CAN see a few clics of extra speed.
BUT, thing to note is that GEARING doesn't 'set' how fast you can go...... but POWER.....
You can mess with years as much as you like, unless you have the engine power to make the THRUST force to shove you along that fast, you will NEVER go any quicker.
tl;dr your bike doesn't have enough power, go back to the original 46t gearing as MarJay say or if you're bored and want to play with things you could go up one more to see what that does.
| A100man |
 A100man World Chat Champion
 Posted: 10:39 - 26 Jul 2024 Post subject: |
| LatencyXR wrote: | the engine is probably pretty fucked |
Most likely or been fucked with
| LatencyXR wrote: | Engines been checked by mechanic to which he said it's had a great service history.. |
That's alright then.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| blurredman |
 blurredman World Chat Champion
 Posted: 11:38 - 26 Jul 2024 Post subject: |
No it wouldn't.  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| slowasyoulike |
 slowasyoulike Scooby Slapper
The last post was made 2 years, 41 days ago. Instead of replying here, would creating a new thread be more useful? |
