bike wont start.
to v or not to v
PostPosted: 19:30 - 26 Jul 2024    Post subject: bike wont start. Reply with quote
went to go on a ride tonight. turned bike on, everything normal. pressed start button and bike died. no noise, just lost all electrics.
checked fuses, everything ok. then i wiggled the wires coming out of the fuse box and the electrics came back. pressed start button and there was a audible click from the fuse box and everything died again. rinse and repeat.
heres a pic of the fusebox and wires
https://i.imgur.com/ercUOeZ.jpg
help!
Moto Guzzi V7.
jaffa90
PostPosted: 20:14 - 26 Jul 2024    Post subject: Reply with quote
What is the battery voltage and the voltage with the negative probe on the frame when pressing the start button? In other words is the battery connected to the bike?
PostPosted: 20:21 - 26 Jul 2024    Post subject: Reply with quote
3/4 of that makes no sense.
What voltage do you get between the two battery terminals? Should be 12.8V ideally.
Does it start if you use jump leads? Ignore all the people who insist you can't jump a bike from a car, they know nothing.
Triumph Sprint ST 1050
doggone
PostPosted: 20:26 - 26 Jul 2024    Post subject: Reply with quote
Touching the fuses area might be a red herring you maybe just wiggled all the wires enough to temporarily make a poor connection.
I'd try tightening battery terminals or better undo them completely and wire brush gently before retightening.
The earth side is always most likely to be dodgy.
to v or not to v
PostPosted: 20:34 - 26 Jul 2024    Post subject: Reply with quote
thanks for all the replies fellas.
battery terminals are tight and clean. how do i go about testing the voltage?
i have an old ammeter but no idea what im doing with it to be honest.
i have one of those lithium battery emergency jump starter things in my car. will give it a try.
Moto Guzzi V7.
PostPosted: 20:52 - 26 Jul 2024    Post subject: Reply with quote
https://www.ebay.co.uk/itm/145693136071
Robby
Dirty Old Man
PostPosted: 21:15 - 26 Jul 2024    Post subject: Reply with quote
You wiggled things and it worked. So something is loose or broken in the area that you wiggled.
Loose is easy to fix. Find anything loose and make it tight.
Worth charging the battery too. The click could be the starter solenoid with a low battery. Usually lots of clicks there though. One click suggests a bad connection.
to v or not to v
PostPosted: 04:30 - 27 Jul 2024    Post subject: Reply with quote
connected jump starter and bike fired straight up. have ordered a new battery from Halfords.
thanks for the help fellas Thumbs Up
Moto Guzzi V7.
PostPosted: 08:14 - 27 Jul 2024    Post subject: Reply with quote
Ah, but you don't kno why the battery was flat. Had it died or has your charging system failed. You may have just bought a battery for no reason because your old battery may have recovered if charged.
to v or not to v
PostPosted: 08:18 - 27 Jul 2024    Post subject: Reply with quote
battery is kept plugged into an optimate charger so definitely not flat.
i have no idea how old it is, so hoping its just reached end of life.
Moto Guzzi V7.
to v or not to v
PostPosted: 11:57 - 27 Jul 2024    Post subject: Reply with quote
new battery fitted and every things good.
once again thanks for the help fellas, and as much as it pains me to say it, especially Nobby Razz
Moto Guzzi V7.
doggone
PostPosted: 12:39 - 27 Jul 2024    Post subject: Reply with quote
A ghetto way to check it is probably charging, somewhere not too bright have bike idling and rev it gently with something in front of headlight - your hand will do.
The headlight ought to go noticeably brighter coming off idle.
Or rather if it does you know it's charging Ok.
DaddyStu
PostPosted: 21:40 - 27 Jul 2024    Post subject: Reply with quote
Just fitted a new battery on mine due to dash "Lo' warning and check engine light. Starts lovely - rev'd the nuts out of it on the drive for 10 mins. Commuting tomorrow.
Old battery says fully charged and indicating 12V. Maybe just reached its limit and wont go any higher without some tickling up. Might've been old anyway so wanted to swap it out.
Daddystu
The last post was made 1 year, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 75.99 Kb
