| lingeringstin... |
 lingeringstin... Spanner Monkey
| Easy-X |
 Easy-X Super Spammer
 Posted: 22:37 - 05 Aug 2024 Post subject: |
There some sentimental attachment to this bike that we should know about? Seems like an awful lot of work vs. getting a bike with a bigger engine to start with  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| lingeringstin... |
| stinkwheel |
 Posted: 23:38 - 05 Aug 2024 Post subject: |
It'll be exactly the same displacement. The way it is with your standard engine, you're displacing 125cc every 360 degrees. If you "big bang" it (not exactly the same as a big bang motor but the term split single is already in use for something very different), it'll displace 250cc in one 360 degrees and nothing in the next 360 degrees.
I don't know what sort of calculator you're using but displacement is half the bore squared, times pi, times the stroke. (all in cm, not mm to get cc)
So for your 54mm piston with your 53mm stroke you get 121.3cc per cylinder. Total displacement of 242.7cc.
If you use a 125 crank which has a 43.2mm stroke with a 54mm piston you get 98.9cc per cylinder, a total of 197.8cc. You also have a massively oversquare engine (A CD250 and CD125 engine are exaclty square as they come from the factory) which should produce peak torque at higher revs at the cost of lower rev torque. So it'll pull better when spanking its arse but will feel anaemic when the revs drop.
It'll probably produce much the same power output if it doesn't shake itself to bits, almost certainly less than a single of the same capacity due to increased piston surface area contact.
Weird but ok, give it a try. I'd imagine it'll vibrate like hell. Biggest thing will be how you rejoin the cam. As in clocking it accurately, maintaining concentricity then joining the halves together strongly enough they don't split but without using so much heat it ruins the hardening. It would take some precision machining.
I wonder how Allen Millyard does it?...
Oh, it appears you chop it in half with an angle grinder on your lawn then rejoin it using an old gudgeon pin as a dowel.
https://youtu.be/7myfnvhl_r4?si=Kt_V2_lwVfiGg0Lg
Regarding carbs, I found a CB125T ran perfectly well on a single, standard carb instead of the twin carbs. It was producing the correct fuel:air mix. I know this is different though because that was only sucking through one pot at a time. You probably want a carb with a choke surface area equal to the combined inlet port surface areas. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
 Posted: 00:11 - 06 Aug 2024 Post subject: |
Rebore the cylinders, bigger pistons, hot cam, retiming, carb re-jetting... what are we reckoning here: at most you might rinse 25hp out of the engine?
And then you find the clutch slipping
Could you squeeze in the engine from a Rebel 400 or Superdream CB400N? ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| stinkwheel |
 Posted: 06:25 - 06 Aug 2024 Post subject: |
Occurrs to me that if you're going to go to the effort of cutting and rejoining a cam, it would stand more chance of gaining power if you messed with the valve timing. I'm sure the valve timing specs for the K-series CB250s or early T-series CB125s are out there somewhere which would probably be a good starting point (although bore and stroke are different).
Re-profiling would be trickier because I bet they also have more lift and duration but the hardening on them is pretty thin. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sickpup |
 sickpup Old Timer
| WD Forte |
 WD Forte World Chat Champion
| stinkwheel |
| lingeringstin... |
| lingeringstin... |
| lingeringstin... |
| blurredman |
 blurredman World Chat Champion
 Posted: 14:55 - 06 Aug 2024 Post subject: Re: feck! |
| lingeringstink wrote: |
I still like the Rotax idea though. Seems like a sensible engine for my needs. |
They are pretty torquey. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| virus |
 virus World Chat Champion
 Posted: 16:12 - 06 Aug 2024 Post subject: |
the rotax they used in the mt350 will run fine on 87 octane or even lower too, which would suit your penchant for filling your tank with anything vaguely flammable  ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| stinkwheel |
 Posted: 16:55 - 06 Aug 2024 Post subject: |
The military bikes are also famously badly geared. They wanted gearing that would do road and off road riding and in classic military fashion, picked gearing that does neither very well.
Anecdotally, from watching them at many rallies, owners also seem to spend a lot of time repeatedly kicking and swearing at them any time they want to go anywhere. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| lingeringstin... |
| stinkwheel |
 Posted: 06:21 - 07 Aug 2024 Post subject: |
It doesn't have a peppy short-stroke engine for the same reason it doesn't have a 60bhp 2-stroke engine or a DOHC inline 4 (both of which they were making at the time). It's a dull, economic, easy to ride commuter bike. Practically the definition of a mundane Universal Japanese Motorcycle. They made it with a square engine precisely because it's so middle of the road.
They made it with a 250cc engine because when that series of bikes first came out, you could ride up to 250cc on L-plates so that's what people wanted. Same reason as learner bikes are now almost all 125cc, they make 100 and 110cc bikes but people in the UK don't buy them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| lingeringstin... |
| stinkwheel |
| Nobby the Bastard |
| A100man |
 A100man World Chat Champion
 Posted: 14:34 - 07 Aug 2024 Post subject: |
| Nobby the Bastard wrote: | The only question that comes to mind is 'Why the fuck go to that sort of bother over a fucking Benley engine?' |
I take your point but you should see the efforts people go to with Beetle engines ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Nobby the Bastard |
| lingeringstin... |
| lingeringstin... |
| lingeringstin... |
The last post was made 2 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
