| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| doggone |
 doggone World Chat Champion
| Kawasaki Jimbo |
| Kawasaki Jimbo |
| stinkwheel |
 Posted: 21:36 - 07 Aug 2024 Post subject: |
Yes. I left the ignition on on my trials bike with it parked up which drained the battery. There was JUST enough life left in the battery to get it to fire up on the kickstart but increasing the revs above a fast idle killed the motor. Battery was knackered so any power the alternator was putting out was just getting sucked up by the battery.
Happily, it appeared to be just holding its own at a fast idle (and i know for a fact, that bike needs 8v to make a viable spark so the battery was well and truly goosed). With the extremely low gearing, some fine clutch control and a little foot-paddling to get moving, I managed to limp it home at about 10-15mph. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| blurredman |
 blurredman World Chat Champion
 Posted: 06:48 - 08 Aug 2024 Post subject: |
Most bikes being DC ignition, yes.
One of my bikes has a poorly battery, works fine without lights on- but if I need them for the night I have to keep rpm up whilst waiting at traffic lights. EDIT: That's just for lighting too, ontop of the 5w or whatever that is required for basic ignition. Not to mention all the crap modern bikes require power for... ie throttlebodies and sensors. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| stinkwheel |
 Posted: 09:41 - 08 Aug 2024 Post subject: |
A few companies make reg/recs with built in capacitors. These will allow a bike to run with a dead or even missing battery as long as you can get it fired up initially.
You might struggle to start more modern bikes that require a certain base voltage to power up the electronics and fuel pump for the injectors. If you can get them running (in that case usually requiring a jump or a long bump start), they stay running.
We did this with a mates tiger sport. After a whole lot of faffing with a jump start pack and having it die as soon as you disconnected it due to the terminally fucked battery*, we fitted a capacitor across the battery (I carried one on my bullet road bike after the afore-mentioned trials bike incident). Bike fired up and kept running all the way home.
I fitted a capacitor equipped reg/rec to my bike after that, made by Sparx but Boyer and Lucas also make one. I still carry the capacitor because it's small in case someone else needs it.
*Turns out the battery had been on the way out for a long time and he'd been starting the bike on his jump pack for about a fortnight, this was the day he'd finally sucked every last bit of juice out of it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kawasaki Jimbo |
 Posted: 18:37 - 08 Aug 2024 Post subject: |
The posh fuse holder (between reg/rec and direct battery terminal connection) I fitted explicitly to warn me of such impending events before other bits were destroyed (after last time) failed by simply melting, which was the immediate cause of the breakdown. It must have let more current past than the 30 amp fuse itself. Useless! Now need to check the connectors and work out what caused the excess heat.
https://i.postimg.cc/mrHKPtWv/IMG-1460.jpg
https://i.postimg.cc/FRX83N97/IMG-1461.jpg |
| stinkwheel |
| Kawasaki Jimbo |
| stinkwheel |
| lingeringstin... |
 lingeringstin... Spanner Monkey
| Kawasaki Jimbo |
| stinkwheel |
 Posted: 18:39 - 09 Aug 2024 Post subject: |
You can get a small, self-powered, PCB mounted LED voltmeter with flying wires for a couple of quid.
So cheap, the last time I ordered one, they came in 5 colours and I ordered five so I could choose. Turns out the price was for five, not one so I got five packs of five colours.
No idea where I put them or I'd send you an handful. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kawasaki Jimbo |
The last post was made 2 years, 99 days ago. Instead of replying here, would creating a new thread be more useful? |
