| Author |
| Farmingstock |
 Farmingstock Spanner Monkey
| Back to top |
| WD Forte |
 WD Forte World Chat Champion
| Back to top |
| Robby |
 Robby Dirty Old Man
| Back to top |
| stinkwheel |
 Posted: 17:11 - 06 Sep 2024 Post subject: |
You could block all the holes and fill it with evaporust/deox-c then hose it out, then spray a corrosion inhibitor (like waxoyl or ACF50) up in there after painting.
White vinegar would also work and is much cheaper, takes about 24-48h. You'd want to flush thoroughly then neutralise with some bicarb solution if you do this because it'll flash rust almost as you watch once it's drained. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| Stripperbo |
 Stripperbo L Plate Warrior
 Posted: 07:16 - 07 Nov 2024 Post subject: |
For that internal rust, filling the frame with something like Evapo-Rust or Deox-C could be a good move. Just plug the holes, let it sit for a day or two, and then flush it out.
White vinegar works too, though it's a bit harsher—just remember to rinse well and use some bicarb to neutralize afterward, or it’ll rust up again real quick.
Once you’re done with the rust treatment, you could coat the inside with a corrosion inhibitor like ACF-50 or Waxoyl. That way, you’ve got a layer of protection before painting. If you’re into the restoration vibe but want to skip some of the rust battles, maybe look at something like the E Ride Pro SS—all electric and no frame rust to worry about.
| Back to top |
| jeremyr62 |
 jeremyr62 Nova Slayer
| Back to top |
| Ducked |
 Ducked Two Stroke Sniffer
 Posted: 12:11 - 30 Dec 2024 Post subject: |
Aircraft with tubular steel frames use/used linseed oil, so if its good enough for them...cant remember if that was "boiled" linseed (which sets faster) but I'd think inside a frame there wouldn't be a big hurry, and untreated linseed might soak in better, especially where there was already surface rust.
In Taiwan (AFAIK) I cant get linseed so I've been using sunflower as a rust treatment, which also sets but more slowly.
Where there is access, rubbing with aluminium (for example,crumpled foil by hand, or flattened beercan disk in a power drill) with veg oil as a binder generates a metallic "primer" paint in situ. Surfaces roughened by corrosion pick up more aluminium, so its to some extent self-adjusting. The aluminium can also tend to fill in the pits in corroded fork chrome.
I'm not sure whether veg oil is better than motor oil inside a frame, but I'd think a follow-up with MO a year or two after veg treatment might be optimal, and tend to limit mold that might otherwise develop in an enclosed space like the inside of a frame tube. |
| Back to top |
| Ducked |
| Back to top |
The last post was made 1 year, 20 days ago. Instead of replying here, would creating a new thread be more useful? |
