| NutsyUk |
 NutsyUk Nearly there...
 Posted: 18:43 - 24 Sep 2024 Post subject: Slightly over squeezed the rivet link on the new chain... |
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFK!
Ive a fraction over tightened the rivet link... IE squeezing the plate onto the link. Not the rivet (yet)
I needed to get the job done today, but was fast running out of light and now I have several days of rain
But it took a huge amount of effort to squeeze it on. But I did one last check and found it was a fraction too loose still (calliper tested against the other chain links)
So I gave it one last little squeeze and now Im a fraction too tight and the link is ever so slightly stiff. Sighs......
Is there a way to pull the plate back a little? Im worried if I just jimmy a screwdriver in and wiggle it is going to warp it in all sorts of awful ways.
Any ideas? ____________________ Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold! |
| Nobby the Bastard |
| NutsyUk |
| stinkwheel |
 Posted: 20:06 - 24 Sep 2024 Post subject: |
Move it into the middle of a run, grab the chain either side of the link in your hands and flex it sideways a couple of times. Should free off a little. That's how you do bicycle chains when you've pressed the side plate on. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jaffa90 |
 jaffa90 World Chat Champion
| NutsyUk |
| A100man |
 A100man World Chat Champion
 Posted: 09:57 - 25 Sep 2024 Post subject: |
Meh, try Stink's suggestrionn then leave it.. 'it will ride up with wear, sir'. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| NutsyUk |
| Nobby the Bastard |
| NutsyUk |
| mentalboy |
 mentalboy World Chat Champion
| NutsyUk |
| NutsyUk |
| Nobby the Bastard |
| NutsyUk |
| BanditsHigh |
 BanditsHigh Worse than a woman
 Posted: 20:46 - 26 Sep 2024 Post subject: |
Bit late to the party ... put the chain in a vice with a couple of nuts over the two pins of the rivet link (already riveted size), tighten vice ... the chain/plates will be held in place while the pins are pushed through  |
| Nobby the Bastard |
| BanditsHigh |
The last post was made 2 years, 50 days ago. Instead of replying here, would creating a new thread be more useful? |
