Honda CG125 Torque arm nut
skullzandwebb...
PostPosted: 02:24 - 08 Nov 2024    Post subject: Honda CG125 Torque arm nut Reply with quote
Hi, first post on here!
I bought a 2002 Honda CG125, but on closer inspection I realised that the bike is missing the nut that's supposed to hold on the torque arm to the rear drum brake.
I'd like to know what size/type of nut I need to order, and if there's anything else missing like a washer perhaps?
Any help would be greatly appreciated as I cant find this information for the life of me, and don't currently have the Haynes manual.
Thanks!
jeffyjeff
PostPosted: 05:22 - 08 Nov 2024    Post subject: Reply with quote
https://www.cmsnl.com/honda-cg125-1995-s-england_model2608/partslist/F__1000.html You can see the assembly in the attached drawing. The bolt is special; shoulder where it goes through the rear brake housing, with a hole for a cotter pin that prevents the nut from backing off. Drawing depicts a 2002 Honda CG125.
https://live.staticflickr.com/65535/54124573881_640130778a_c.jpg
PostPosted: 20:45 - 09 Nov 2024    Post subject: Reply with quote
The nut itself is just a standard M8 hex nut though.
I'd imagine the bolt is still there? On my previous small Hondas, it's been a very tight fit in the hub and is usually galled into the alloy, it would usually need to be hammered out (if you had any reason to want to remove it).
As above, someone clearly forgot to re-fit it because it should have a split-pin through the bolt preventing the nut from coming off. A large diameter M8 washer (looks like form C from the picture )and a rubber washer under the nut.
PostPosted: 22:35 - 09 Nov 2024    Post subject: Reply with quote
According to that cmsnl fiche
8 is a rubber washer
(M6 will do as it will deform and stretch over the shoulder)
12 is an M6 washer
15 is an M6 nut
19 is a 2mm x 15mm split pin
all very common
PostPosted: 00:01 - 10 Nov 2024    Post subject: Reply with quote
12 is an M6 washer
15 is an M6 nut
all very common
It's an M8, not M6
PostPosted: 01:59 - 10 Nov 2024    Post subject: Reply with quote
cmsnl says M6 but whatever, still simple.
PostPosted: 10:07 - 10 Nov 2024    Post subject: Reply with quote
It doesn't. Look again.
PostPosted: 13:12 - 10 Nov 2024    Post subject: Reply with quote
FAKE NEWS!!
I said it was M8 but someone snuck in and changed my words AGAIN!
More nasty rassis biggitry and anti scooty boi hate going on here
as usual,
trying to make it look like I read no 14's spec when it was no 15
skullzandwebb...
PostPosted: 16:55 - 12 Nov 2024    Post subject: Reply with quote
Thanks for the help M8's Wink
Is it worth paying the £15 shipping fee from cmsnl?
Seems a bit much to pay almost £26 for items that are like £6.50 together lol
Any UK retailers that might stock them perhaps?
skullzandwebb...
PostPosted: 16:58 - 12 Nov 2024    Post subject: Reply with quote
Some images here, just for reference
Bolt is still there
https://media.discordapp.net/attachments/786765406198693920/1305935889007902750/IMG_0901.jpg?ex=6734d713&is=67338593&hm=8be9ac8c55c6818234f53a1748cddd04b010304e186931d284723e044ff5bf55&=&format=webp&width=490&height=654https://media.discordapp.net/attachments/786765406198693920/1305935889771532309/IMG_0900.jpg?ex=6734d713&is=67338593&hm=504d826b66c174fb797b8977c76606ed48303783367a13bd990a0fb5673b7648&=&format=webp&width=490&height=654
https://media.discordapp.net/attachments/786765406198693920/1305935890857725952/IMG_0899.jpg?ex=6734d713&is=67338593&hm=a6e1b1802c4f1d730ae6953353c1be28d8c1cde16d9b977d53d21aa2f0685c13&=&format=webp&width=490&height=654
https://media.discordapp.net/attachments/786765406198693920/1305935891650314251/IMG_0898.jpg?ex=6734d713&is=67338593&hm=30767ce9c732a95911be1d0bdf869f7c099c1e42327297aa4529274c253e3c3c&=&format=webp&width=490&height=654
PostPosted: 18:33 - 12 Nov 2024    Post subject: Reply with quote
I think the snapped off split pin is still in the end of the bolt. You should be able to drift it out with a fine punch because it'll be soft steel.
blurredman
PostPosted: 19:12 - 12 Nov 2024    Post subject: Reply with quote
Just buy a single locknut from any independant hardware store for like 20p?
The last post was made 1 year, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 74.8 Kb
