Not a bike, but wifies Tourneo brake issues. Help.
PostPosted: 19:03 - 03 Dec 2024    Post subject: Not a bike, but wifies Tourneo brake issues. Help. Reply with quote
Ford Tourneo Connect 2016 1.5 diesel. I need some help from any resident mechanics, car gurus or people who have any experience of this problem. A bit of an epic story -
Wifies Tourneo Connect (Transit based thingy) seemed to lose power while she was driving it. Turned out front nearside brake caliper had siezed on according to RAC who ferried it back to our local Formula 1 who had just serviced and fitted new tyres.
They replaced the brake caliper, both front discs and pads and gave it her back.
A few hundred miles later exactly the same thing happened, brakes seized on, RAC recovered it back to Formula 1 again. RAC man was pretty scathing in his report saying they hadn't looked for an issue, just replaced the damaged bits.so I had a rather epic rant at them not least because it frightened the life out of wifie when the brakes jammed on.
Formula 1 fitted a new front flexi incase it had collapsed internally. This didn't cure the brake binding so they stripped everything down and found the driver side rear had been binding as well and needed rebuild. They did this and on testing said the front left and back right brakes were still binding and reckoned it must be the ABS modulator/pump unit at fault and they weren't equipped to do this repair and it should go to Ford.
So I very gingerly drove it home as they said it only locked up if you braked hard. Rolling Eyes Anyway I got it home and it's now on the drive. It's so far cost me a grand for brake parts and labour (including a substantial discount from Formula one) and all pads and discs and two calipers are new so I don't want to wreck them.
So to my questions. Are they probably right with the ABS unit failure. I have had absolutely no warning lights up in respect to this fault and would have expected an ABS failure to come up. Bearing in mind that the brake system on most cars is split so if you get a failure you still have some brakes does the fact front left and rear right are binding point to something else, maybe master cylinder?
Please anyone with any ideas however outlandish. I dread to think how much it will cost me if I simply say to Ford, come and get it and sort it out.
Many thanks for reading if you haven't fallen asleep by now!!!
Triumph Trophy Launch Edition
PostPosted: 19:49 - 03 Dec 2024    Post subject: Reply with quote
Braeks on 4 wheeled vehicles are on two seperate lines, Left front/rear right and right front/rear left so its got to be something that is affecting the whole line. That really just limits it down to the ABS pump or the master cylinder.
I would suspect the master cylinder, The ABS pump should only become involved when a wheel locks or slowws dramtically compared to the others.
Triumph Sprint ST 1050
PostPosted: 20:23 - 03 Dec 2024    Post subject: Reply with quote
Sort of what I was thinking as well. Also I can't see the ABS unit failing without warning lights going christmas tree but I don't know enough to be sure.
PostPosted: 20:33 - 03 Dec 2024    Post subject: Reply with quote
A seal kit for the master cylinder would be vastly less than a ABS pump as well.
jaffa90
PostPosted: 23:17 - 03 Dec 2024    Post subject: Reply with quote
It looks like a common problem, just google
( Brakes not releasing on Ford Tourneo Connect 2016 1.5 diesel.)
PostPosted: 23:34 - 03 Dec 2024    Post subject: Reply with quote
Edited to say sorry, that was harsh but I've googled and got nowhere. Just getting frustrated with the whole thing.
PostPosted: 02:34 - 04 Dec 2024    Post subject: Reply with quote
Phuctyfiono I only drive old bangers
But this post from
https://www.fordtransitusaforum.com/threads/2019-ford-transit-connect-front-right-brake-sticky.96206/
suggests the ABS modules are often to blame
"I wouldn’t say I figured it out. But I gave up on spending money. Here was my solution. For starters. I’m 99% sure it’s the ABS module that’s going bad in these vans. Part was around 2,000$ and it’s not a job I was willing to do.
The thing is buried deep in the engine bay. Too deep for this guy. So I started playing with fuses. There are 2 30A fuses under the hood in the engine bay. One of for ABS. One for traction control. Pull either one you get the typical dash lights (traction control, brake light and ABS light) but if you pull the ABS, you also loose you speedometer. Odometer and all the dash cluster stuff.
BUT
if you pull the little 5A fuse marked for ABS / Traction Control. It will disable the system. (Still get dash lights, but speedo and everything work as they should) and with this fuse pulled it not longer allows the ABS module to activate. Allowing me to drive as if I always should have been able to.
Get some electrical tape and cover over those lights. I should have know buying ford would turn out this way. Sorry ford lovers. Everything built like crap now. Not just fords."
Other posts:
We've had several of these do the same thing. F/L & R/R will lock after bleeding brakes and pressing the pedal once they lock up again. It turned out that the ABS Module gets jammed up and needs to be replaced. Ran tests with scan tool and didn't fix issue had to replace part and have ford recalibrate it. Hope this helps
#35 · Jun 22, 2024
Same for me. 3k worth of work and c parts
PostPosted: 06:04 - 04 Dec 2024    Post subject: Reply with quote
But this post from
BUT
Other posts:
#35 · Jun 22, 2024
Ah fuck, that certainly looks like the problem. One good thing from that is if I pull that 5 amp fuse I can drive it to where ever I need to take it without the risk of it locking up on me. Thumbs Up
Robby
Dirty Old Man
PostPosted: 08:39 - 04 Dec 2024    Post subject: Reply with quote
More importantly, if you pull that 5a fuse you can diagnose the problem. If you're sure it is the ABS pump, and it's a common failure, you should be able to get a remanufactured unit and have it fitted by a local garage.
I'm going to assume that disabling the ABS is an MOT fail, so removing the fuse is not a long term solution.
Has it had regular brake fluid changes?
PostPosted: 10:43 - 04 Dec 2024    Post subject: Reply with quote
3 times in the last month due to this ongoing problem. Crying or Very sad I'm not sure beyond that. It's not a normal service item changing the brake fluid is it.
PostPosted: 11:41 - 04 Dec 2024    Post subject: Reply with quote
You might just need to bleed the system. I put something on the "Dear Auntie" section about the wife's Grand C-Max, similar issue: brake locked on, the front much more than the diagonal opposite at the back it seemed.
https://www.bikechatforums.com/viewtopic.php?t=334801
tl;dr laptop + cheap software + OBD2 lead allows an automated brake bleed (some function of the ABS unit apparently) that works. The normal pump brake pedal while fiddling with the brake caliper nipple does not.
PostPosted: 12:08 - 04 Dec 2024    Post subject: Reply with quote
Polarbears ongoing saga and expense at local garages makes me wonder how useful they are.
It appears they're doing a lot of swap and hope at his expense while a few seconds googling gets much better info
in telling us how the ABS modules on Connects can be a massive PITA.
As Robby says, just pulling a 5A fuse and driving it will quickly and cheaply give an indication whether the ABS is to blame or not
PostPosted: 12:37 - 04 Dec 2024    Post subject: Reply with quote
Hmm, I stand corrected.
PostPosted: 13:24 - 04 Dec 2024    Post subject: Reply with quote
Your logic was fine. This isn't logical as Mr. Spock would say. Laughing
PostPosted: 13:32 - 04 Dec 2024    Post subject: Reply with quote
I missed that thread (or probably senility has crept in and I forgot about it). Very useful. I'll pull the fuse first to confirm that the ABS is actually at fault and then if that's the case I will have a play with the software as you did. I've nothing to lose and a a lot to gain. Thanks again for that. Thumbs Up
I take it the fault didn't come back?
PostPosted: 16:11 - 04 Dec 2024    Post subject: Reply with quote
The disc and pads were cooked on the affected wheel. I took no chances and replaced disc, caliper, pads and flexi-hose but in hindsight the caliper and hose were probably salvageable.
Not had any problems since getting all the air out with the software. People were suggesting master cylinder or ABS unit on Ford owners' forums but BCF had the correct answer Smile
Worth bearing in mind: regardless of what your fault actually is, this software bleeding procedure will need to be done at the end anyway. For the cost of a couple of bottles of brake fluid it might be worth trying first. Of course, inspect pad and disc wear as well. If you're giving it to a garage to do, ask them how they bleed the brakes on this sort of Ford. TBH it looks exactly the same as my wife's Grand C-Max but with a square arse. Same year, same engine too.
PostPosted: 18:23 - 04 Dec 2024    Post subject: Reply with quote
Well, pulled the 5a ABS fuse and no change as in the brakes take a few seconds to unbind after hard braking. Of course I suppose that could be because the ABS unit is stuck in a certain position or something, I don't know. Our drive is a slight slope and if I put the brakes on hard then release, you can feel the brakes dragging slightly as they release and then the van starts to roll down the drive.
It's certainly driveable but having had new discs and pads I don't want to fcuk them up straight away.
I'm going to go down the software route that Easy suggested but even if that works I'm a bit worried that it will seize up again as the first time it happened was straight out of the blue.
Hey ho, I can see this being an epic and expensive journey. Thanks all for help and suggestions.
Robby
Dirty Old Man
PostPosted: 20:40 - 04 Dec 2024    Post subject: Reply with quote
It should be, it's every 2 or 3 years on my car.
PostPosted: 20:45 - 04 Dec 2024    Post subject: Reply with quote
Note: the brakes might not be "releasing" in the sense you're thinking, as in the pistons easing back and taking pressure off the pads. What's probably happening is you're shaving a layer off the pad surface Shocked
P.
PostPosted: 23:03 - 05 Dec 2024    Post subject: Reply with quote
Exactly what happened on family members ford c max, send the abs control.unit for recon, £200 or so, then bleed when back, you can manually bleed but easier to plug in the free ford diag stuff.
PostPosted: 23:21 - 05 Dec 2024    Post subject: Reply with quote
Cheers Paddy. Thumbs Up
sickpup
Old Timer
PostPosted: 16:10 - 13 Dec 2024    Post subject: Reply with quote
That might apply to new cars but I've never seen that on older cars. Its odd as if you had a failure on one circuit it would mean the car would pull to one side or the other on braking.
All the systems I've played with, each circuit did an axle pair.
blurredman
PostPosted: 16:53 - 13 Dec 2024    Post subject: Reply with quote
Indeed, my 205 does front right, rear left and vice versa. But I'm really not sure whether I like this because under quick braking the car does verge to the one side before the other side picks up. All factory lines, though might swap some lines around for more traditional front/rear balance. Though I see why it has been done, to maximise the braking force in the case of a failed line, but the quick take up of the one front disc before the other side's front disc is disconcerting if one doesn't know about it.
PostPosted: 17:37 - 13 Dec 2024    Post subject: Reply with quote
sickpup wrote:
That might apply to new cars...
Diagonal pairing would only be possible for with an all disk-brake system. My Skoda is disks up front and drums at the back. Barely more than a decade old!
blurredman
PostPosted: 20:42 - 13 Dec 2024    Post subject: Reply with quote
Not at all. Valves can equalise pressure on the lines. Drums on the back of my split diagonal 205.
The last post was made 1 year ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 137.02 Kb
