Mismatched innertube mystery
 Topic moved: from The Workshop to The Cycling Forum by stinkwheel (24 Dec 2024 - 08:14)
Poita
PostPosted: 04:04 - 24 Dec 2024    Post subject: Mismatched innertube mystery Reply with quote
I have a bike that is a bit of a Frankenstein, just a knockabout push iron.
About six months ago, I got a flat so checked the info on the tire and bought an innertube replacement online.
When I went to fit it, I found there was overlap as you can see in the photo.
I squished it in, pumped up the tire and within a day I had a flat again.
Fool that I am, I forgot to check the tire for the cause of the flat and found a piece of wire still lodged in and removed it.
I bought a new innertube according to the info on the tire but again it had the same overlap.
It worked ok for six months but now I have a flat again and thought I'd better check here as it seems I'm buying innertubes that are too large for the tire/wheel.
Would be grateful for any insights as to where I'm going wrong.
I have also posted the two innertube purchases that I made which were too large.
PostPosted: 09:13 - 24 Dec 2024    Post subject: Reply with quote
Looks like the correct tube for the tyre. I think you're fitting it wrong.
One bead on. Insert partially inflated tube (so it's round) into the tyre, valve through hole but NOT fixed down, it's ok to put the nut on the end so it doesn't fall out. Mount the second bead. Then inflate, pushing the valve stem up into the tyre as you do so so it doesn't get trapped under the bead.
I just leave the nut off the valve stem, it serves no useful purpose and can cause the tube to tear round the valve more easily if pressure is low.
jaffa90
PostPosted: 11:34 - 24 Dec 2024    Post subject: Reply with quote
The tyre and the tube size match but what size is the rim?
https://www.youtube.com/watch?v=fNO3o2JVMTo
PostPosted: 11:40 - 24 Dec 2024    Post subject: Reply with quote
Well, as the tyre wwasn''t falling of the rim before the puncture....
Triumph Sprint ST 1050
The last post was made 1 year, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Cycling Forum All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.66 - MySQL Queries: 16 - Page Size: 40.15 Kb
