| A100man |
 A100man World Chat Champion
 Posted: 15:56 - 28 Feb 2025 Post subject: Brake Fluid change - Sprinter Van |
I read worrying things about ABS pumps.. yet some folk post that they let it drain through 'gravity' with the bleed screws open, Some pressure the resevoir, some the old school 'UP' 'DOWN' with an assistant - which is what I've done in the past.. This is the first 'modern' vehicle I've had to do this with. Alas, Youtube is not much help...
Thoughts? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| dransy |
 dransy World Chat Champion
| A100man |
 Posted: 00:22 - 01 Mar 2025 Post subject: |
| dransy wrote: | With my vivaro , granted its an 06 but still has abs ive just always bled the brakes like I always have done . I'm no mechanic by any means but surely abs pumps will only be active with the engine on anyway ?
I replaced all the brake fluid about 6 months ago with a pipe and bottle and just pressing the pedal down |
Ta.. I'll probly do just this.. I believe the ABS pump 'super bleed' requires some OBD device input too so ... ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| doggone |
 doggone World Chat Champion
| blurredman |
 blurredman World Chat Champion
 Posted: 01:48 - 02 Mar 2025 Post subject: |
Indeed, seeing as you're not actually opening up the lines by say replacing pipes or hoses or calipers etc, then the bleeding process in itself I should have thought should not trigger computer shit to go boop boop bap bap. Just don't get ahead of yourself and forget to keep topping up the reservoir.. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| A100man |
 Posted: 09:55 - 02 Mar 2025 Post subject: |
Ok .. just to put this to bed I found this.
Essentially there two levels of bleed.
Standard/regular and 'Exceptional'.. Exceptional requires the operation of an OBD system in this case Mercedes Xentry..
| Quote: | Being 2y beyond the recommended 2y interval for my 1st flush, I ended up performing the following break bleeding procedure:
Pressure bleed at 10psi; Rear right (1/4l) -> Rear left (1/4l) -> Front right (1/8l) -> Front left (1/8l)
followed by
Pressure bleed at 10psi with Xentry "exceptional bleed sequence" (bleeds with ABS and break pedal actuation ); the sequence here is Rear left -> Front left -> Front right -> Rear right; Total break fluid consumption was 1.5l
=> total break fluid consumption for both bleeds combined was 2.25l
In Xentry its explicitly stated that exceptional bleeding should be done only after regular bleeding has been done first and only if regular bleeding did not yield a good result (i.e. a spongy feeling) |
| Robby |
 Robby Dirty Old Man
The last post was made 1 year, 233 days ago. Instead of replying here, would creating a new thread be more useful? |
