SYM Wolf 125 valve adjustment?
Ducked
PostPosted: 03:56 - 27 Jan 2025    Post subject: SYM Wolf 125 valve adjustment? Reply with quote
Like an old Honda cb125.
Wee round restrictive valve adjustment ports in the head, obstruction by the frame, and tiny originally square but a bit rounded adjusters.
A PITA, IOW
Is there anything better than cranked pliers for the adjuster?
I thought an adjustable spanner closed down but mine wont fit
Worth getting needle nose mole grips?
[/list]
jeffyjeff
PostPosted: 06:19 - 27 Jan 2025    Post subject: Reply with quote
Google "motorcycle valve tappet adjusting tool"
They come in various sizes. The one I use on my YBR is from Motion Pro; 8mm socket for the locknut with a knurled 3mm square drive finger adjuster. Works a treat. Way more precise than trying to hold that square adjuster head with pliers while you tighten the locknut, especially when access to the assembly is through a hole barely 35mm diameter.
https://live.staticflickr.com/65535/54290708660_0343f36a25_c.jpg
Ducked
PostPosted: 07:03 - 28 Jan 2025    Post subject: Reply with quote
OK, thanks, I'll look into that, though I'm in Taiwan, so it'd probably have to be ordered from overseas even if it is made here.
Meanwhile I got a miniature adjustable spanner that I'm just about to try.
A tap handle might be found to fit on the adjuster but I think the wee port would probably be too restrictive for it
cresad
PostPosted: 14:24 - 28 Jan 2025    Post subject: Reply with quote
I found a set of small metric spanners were the best 5 - 10mm
Ducked
PostPosted: 06:19 - 31 Jan 2025    Post subject: Reply with quote
Pretty sure this is smaller than 5mm though I havn't tried to put a vernier caliper on it and perhaps should.
I have a couple of sets of "ignition" spanners, which I suppose were for the wee adjustment nuts on points based distributors, though I dont remember using them for that, and they dont seem to fit either.
The wee adjustable wasn't great but did work after a fashion, certainly a lot better than pliers
PostPosted: 11:05 - 04 Feb 2025    Post subject: Reply with quote
I use one as in the pic below
you can get the part number and probably find that easily enough
https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Fruggedroads.co.uk%2FWebRoot%2FStore15%2FShops%2F00cbb604-5d1c-407e-8207-580e14387ec5%2F5CF9%2F404F%2F24FE%2F5F0A%2F7B36%2F0A48%2F3535%2FE52C%2F077080030400_ml.jpg&f=1&nofb=1&ipt=2f5dc0de9fb071f4368062d230e644c64f68a254f015cbf4419d1b47cb9101d0&ipo=images
Ducked
PostPosted: 05:50 - 13 Feb 2025    Post subject: Reply with quote
Thanks, Looks nifty, though there could be a risk that SYM chose a different size for the clone than on the Honda original, as they did on flywheel sproket,which meant that a Honda compatible forcing tool wouldnt fit.
I'll leave it for now, since the fuelling is not currently looking fixable anyway.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 51.62 Kb
