GPz750 Fuel Problem?
Grumpy Grandad
PostPosted: 14:00 - 03 Feb 2025    Post subject: GPz750 Fuel Problem? Reply with quote
Hi Everyone
I've just had my 85 Reg GPz750A3 Re-Commisioned after a 15 year lay up. A local freelance Mechanic did the spannering, as I didn't want to screw it up!
On the Fuel side he did the obvious Cleaned out the Fuel Tank and Relined it.
Stripped, Cleaned, Balanced and fitted a New Carb Service Kit.
Stripped, Cleaned and fitted a New Fuel Tap Kit.
Fitted New Spark Plugs.
Plus what else you'd expect. New Oil & Filter, New Air Filter, New Brake Fluid etc.
I've put 800 miles on it since Sept 24, just to restore my faith in it (although I've owned it since new) and to regain MY own confidence, as I've been off the road bike wise for the same period!
TBH it's performed pretty well. Recently however it seems to have developed a problem at lower revs. When coming down from higher revs/speeds it gets to about 4000 rpm, and then acts as if it needs a breather and doesn't want to rev, as I'm attempting to change down.
Previously it's struggled for a bit caught it's breath and then once it revs up into the higher revs it's fine.
Yesterday however it continued to slow down, refusing to rev, and eventually stopped. I switched off waited a bit then it started up and revved up ok. My first thoughts were, '' Something's not right with the carbs'' however I'm not a mecanical genius.
Any suggestions appreciated, and any recommendations for a suitable in-line fuel filter would be great.
Cheers. Ride Safe!
PostPosted: 14:45 - 03 Feb 2025    Post subject: Reply with quote
Whats the fuel flow to the carbs like?
Triumph Sprint ST 1050
RhynoCZ
PostPosted: 15:41 - 03 Feb 2025    Post subject: Reply with quote
Sounds like fuel starvation.
1) You say the tank is relined. Did you check the tank breather is working properly, meaing not blocked?
2) Did you fit an inline fuel filter? If you did, get rid of it right now. I owned '88 GPz550 and the moment I put a filter there, thinking I'm doing the right thing, that's when all the fuel issues started.
3) Does your GPz run the vacuum fuel tap? If so, you either put it back together wrong or you have insufficient vacuum in the system to open the tap properly. This could be bypassed by using the PRI position of the tap.
EDIT: WARNING! Do not leave the tap in the PRI (prime) position when you don't ride the bike. It's like leaving a regular (non-vacuum) fuel tap in ON position = free flow of fuel. If the float valves fail, you'll leak the tank through the carbs on the ground when the engine is off. Don't ask me how I know. Laughing
4) Rebuild the carbs again, make sure to set correct float height.
PostPosted: 15:45 - 03 Feb 2025    Post subject: Reply with quote
What was the air temperature like?
Could have been carb icing. What you described is exactly what would happen and air-cooled bikes from the 80s were quite prone to it. Even more so if they had pod filters. Later liquid cooled kawasakis had part of the coolant system plumbed through the carb bank specifically to prevent it.
Happens most in low air temperature, high humidity conditions. Not necessarily below freezing as the fuel vapourising off the needle tip drops the internal temperature a fair bit. So close to freezing is most likely, especially if humidity is high. Ice crystals form on the tip of the throttle needle due to high air flow which kills the engine. Usually happens when you close the throttle after a period of wide open throttle (and therefore high air flow). Engine stutters then cuts out. All returns to normal after about 30 seconds when the ice melts.
EDIT: Other thing that occurrs to me is sticking needle valves due to ethanol corrosion. Happened to my KLE500 in only a few months. Happily you can buy replacement ethanol safe ones with viton tips. The corrosion on the needle valve would be obvious on inspection, especially with a recently cleaned carb. That said, the service kit may have contained new needle valves.
Kawasaki Jimbo
PostPosted: 18:21 - 03 Feb 2025    Post subject: Reply with quote
Late 90s carb’d Kawasakis too, and the extra plumbing designed to warm the carbs doesn’t work sufficiently.
bypass2
PostPosted: 20:57 - 08 Feb 2025    Post subject: Reply with quote
vacuum pipe may be split
Grumpy Grandad
PostPosted: 08:42 - 09 Feb 2025    Post subject: Reply with quote
Thanks for the replies everyone.
I wasn't ignoring you, I didn't realise I'd had any replies, just getting used to the site mechanics LOL.
I was looking at the ''No New Messages'' Doh!
Grumpy Grandad
PostPosted: 08:57 - 09 Feb 2025    Post subject: Reply with quote
[quote="stinkwheel"]What was the air temperature like?
You could have hit the nail on the head SW Thumbs Up
I've been out & about in 5-8 degrees and it's always happened after a good blast. Then I've got the sypthoms you describe.
Cheers!Chequered Flag
Grumpy Grandad
PostPosted: 09:21 - 09 Feb 2025    Post subject: Reply with quote
RhynoCZ wrote:
Sounds like fuel starvation. Thumbs Up Agree
I'll check it out
Haven't fitted one yet, I was asking for a Recommendation. Very Surprised as I've normally fitted them in the past with no problem. I've got a Y Reg GPZ 55o as well ... in bits! Rolling Eyes
Yes it does. When it's spluttered in the past I've pulled over and switched the tap position, which solved the problem, then switched back when it's revving ok.
Yep Me Too! I remember years ago coming out to the bike to find Fuel dripping out from under the front sprocket cover! Sad That was a seal failure though, Not me Honest Very Happy
Something I've considered, but I'm not that confident dealing with carbs. Thought I'd try the simple options first.
Cheers. Chequered Flag
Grumpy Grandad
PostPosted: 09:23 - 09 Feb 2025    Post subject: Reply with quote
I'll check it out. Easy/Cheap solutions I like. Thumbs Up
Cheers Chequered Flag
Grumpy Grandad
PostPosted: 09:16 - 16 Mar 2025    Post subject: Reply with quote
Could have been carb icing. All returns to normal after about 30 seconds when the ice melts.
Update on the Fuel Situation:
I think it must have been Carb Icing as you suggested. Funnily enough as I continued to search OLD posts I saw one of yours suggesting the use of Silkolene FST so thought I'd give it a try.
That seems to have done the trick (or it's warmed up a bit!). Just got to figure out an easy way to add it to the fuel either after/before going for a blast and riding to the Petrol Station to fill up..... to get the correct mixture. Don't want to be riding around with a bottle of FST stuffed down my jacket Very Happy
I'm sure I'm over thinking it Shocked
Not sure whether to stop using it as the weather really starts to warm up? I've read that it's pretty good for keeping the carbs and engine cleaner .... Any thoughts?
Chequered Flag
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 73.57 Kb
