Bogs out at 8 to 10 k rev
flojoe
PostPosted: 10:39 - 12 Mar 2025    Post subject: Bogs out at 8 to 10 k rev Reply with quote
Hi All i have purchased a used Triumph daytona 675 2012 that was turned into a street triple after been down the road think as it was cheaper to get parts , anyway the issue i am having is it has full power up to 10k rev and seems to bottom out there Feels like it is restricted I cant see anyone restricting a daytona . Anyone have anyone similar issue
rpsmith79
PostPosted: 10:45 - 12 Mar 2025    Post subject: Reply with quote
Does it rev right up to the limiter, which should be around 12,500 i think
It is a cable throttle, and if it has been down the road a rebuilt, it would be worth checking the cable is linked properly and not kinked or something
Pete.
PostPosted: 18:04 - 12 Mar 2025    Post subject: Reply with quote
Change the air filter.
a.k.a 'Geri'
PostPosted: 15:33 - 15 Apr 2025    Post subject: Reply with quote
I wonder if this is to do with the absence of the Ram Air. I remember back in the mists of time G (remember him?) had a ZX9R that he streetfightered, and it wouldn't run right unless he put the ram air tubing back in place. I wonder if there is a sensor in the intake, or the airbox is designed to work under a certain amount of pressure or something?
Considering what has been done to the bike it seems like a fairly obvious place to start.
Fullers1845
PostPosted: 09:27 - 23 Apr 2025    Post subject: Reply with quote
I'm on a couple of zx6r Faceache pages and this is really common, the carb vents must be at the same air pressure as the intake ducting overwise they bog down under load.
Apparently even when done correctly the streetfightered ones often don't perform as well due to the carbs being designed and set up for ram air.
Honda CB125F, Kawasaki ZX6R J1, 1978 Kawasaki KZ650, 1922 Sheffield-Henderson Blackburne grasstrack/sprint
The last post was made 1 year, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.91 - MySQL Queries: 15 - Page Size: 44.66 Kb
