Bump and wax.
struan80
PostPosted: 23:04 - 02 Apr 2025    Post subject: Bump and wax. Reply with quote
Hello.
Does softening the bump and rebound rear damping reduce the ride height when at a stand still?
Increasing the preload. If I understand correctly it is compression of the spring using a .C-spanner to turn the grooved rings on the shock body?
I've got my new bike on order and have got the low seat and lowering link oprion but want the bike as low as possible as I'm short arse.
Pros and cons of chain oil and wax. I gave up on the scotoiler, messy blooming thing. Thinking about wax as it is 'cleaner'.
PostPosted: 06:39 - 03 Apr 2025    Post subject: Reply with quote
No, adjusting the damping alters the speed the suspension changes position, not the position itself.
Altering the preload will adjust loaded ride height but also alters sag.
Changing suspension settings to alter ride height is probably a bad idea, it will affect handling because they are all settings to keep the wheel on the road.
Rear ride height adjustment is best done by either fitting a different length shock or different tie bars if it's a monoshock.
If you drop the rear alone, you will also alter the rake angle which will slow down steering and if taken to an extreme, can make the steering "flop" to either side when corrnering. You would ideally also alter front ride heigh the same amount, usually by dropping the forks through the yokes. This keeps the rake angle the same but can come at a cost of reducing ground clearance and clearance between the wheel and the front of the bike. So there is a point of diminishing returns.
struan80
PostPosted: 15:30 - 03 Apr 2025    Post subject: Reply with quote
Thanks good explanation. I don't want to mess with the geometry. I may get my suspension set up correctly by a specialist, based on my weight.
I'm thinking you need three people. Me on the bike someone else holding the bike and someone measuring the sag. Laughing
PostPosted: 16:51 - 03 Apr 2025    Post subject: Reply with quote
Or a cable tie round the fork tube.
That said, if you've calculated the correct spring rate based on the bike and rider weight then set the static sag, the rider sag should be in the correct ballaprk.
I use the calculator tool on https://racetech.com/
If I was pissing with ride height, in an ideal world, I'd check the rake angle with one of those angle finder tools before I started, set the rear ride height then adjust the rake angle back to where it was by sliding the forks through the yokes.
Lowering it will shorten the wheelbase slightly too so if it feels too exciteable on corners, you might want to rake it back out a touch. More likely to be an actual issue on a very sports orientated bike which is pushing the rake angle as it is.
PostPosted: 20:06 - 03 Apr 2025    Post subject: Reply with quote
+1 for getting it set up professionally especially if you have fancy suspension.
My Street Triple R was awful out of the box. I played around but couldn't get it right. In the end I went to one of those suspension specialists at a track day and it was brilliant once they had set it up right for me. I'd have never got it that good in a month of Sundays.
Triumph Trophy Launch Edition
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 46.8 Kb
