Yamaha YBR 125 - Voltage across red and brown wires
Searcher
PostPosted: 13:03 - 14 Apr 2025    Post subject: Yamaha YBR 125 - Voltage across red and brown wires Reply with quote
Hello,
My Yamaha YBR 125 EFI (2007) is not starting. I notice that when the ignition is on, the voltage across brown and red wires in the headlight casing fluctuates between 4 and 12 volts. Is this normal to have fluctuating voltage across these two wires?
Thanks
PostPosted: 16:20 - 14 Apr 2025    Post subject: Reply with quote
No
Searcher
PostPosted: 16:45 - 14 Apr 2025    Post subject: Reply with quote
WD Forte wrote:
No
Thanks for you reply. Any indication on what would cause that?
Searcher
PostPosted: 13:34 - 15 Apr 2025    Post subject: Reply with quote
Wiring diagram of 2007 YBR 125
PostPosted: 14:03 - 15 Apr 2025    Post subject: Reply with quote
I've replaced a few YBR ignition switches so considering its age and that switch has to carry all the bikes electrical power, it's not unfeasible
it's internal contacts may be wearing out
Your voltage readings say across when I'd be
measuring voltagesat with respect to ground
this is confusing and doesn't help
Your 'doesnt start' description isn't helpful either
what does that mean exactly?
When you turn YBR on you should see the lights and neutral light come on
the Eml light come on briefly then go out
and hear the fuel pump prime for a second or two
The headlamp should go off when the starter is pressed and the engine turn and fire up
so what is or isnt happening?
Searcher
PostPosted: 15:06 - 15 Apr 2025    Post subject: Reply with quote
Thanks for your reply. It is raining today, so shall update you with the answers to all questions later. Regarding ignition switch, it was replaced earlier and was working fine with (black and black/ white wire shortened).
The last post was made 1 year, 35 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 47.18 Kb
