| lingeringstin... |
 lingeringstin... Spanner Monkey
 Posted: 20:58 - 07 Jun 2023 Post subject: explain timing lug on flywheel |
I want to modify my ignition timing.
On things like the standard Honda CMX electronic ignition and charging system you have the inner bit with the coils and the outer flywheel that spins round them.
There's a little raised lug on the outside of the flywheel. On the inside of the engine case is a sender unit bolted in place so the lug on the flywheel passes by it. That's how the fixed timing works and in bog standard form it works fine.
HOWEVER...
My modified CMX250/253FMM-ish engine abomination has a couple of mil or more shaved off the barrels/head for reasons of different piston accommodation (more poop to the pop).
This means the cam is just that little bit closer to the crank, with the cam chain slack is taken up by a manual adjuster. This means the cam is slightly rotated backwards so it opens the valves SLIGHTLY later than normal. It's not enough to hurt anything apart from the fact that it makes starting the bike by electric starter a hassle. Cold engine and electric starter doesn't play together well with the starter clutch.
I found another flywheel that was identical in every way to the standard ones I've got apart from the fact that it's ignition timing lug was positioned about 10mm behind where a standard lug is. I figured this would retard my spark slightly and make for easier starting so I tried it and it worked beautifully. Engine starts without any starter clutch clattering or occasional exhaust expulsions, so my theory was correct. But it's now slightly too retarded ignition and I want to advance it just a smidgen, somewhere between the two.
Other flywheels for both single and twin engines that use similar stators as this have longer timing lugs or they're in a slightly different place. Why? My thinking is the position of the lug on the flywheel dictates timing, as illustrated when I fitted a flywheel with a slightly clockwise lug placement and it tamed my starter shenanigans. But why are some some lugs longer than others on engines that use virtually the same alternator, CDI and sensor placement?
I know the lug passing by the sensor is what triggers the CDI, but why are some of them longer? Does it have anything to do with the CDI capacitance loading up, which would mean a longer lug would push more charge to the CDI?
I have never fully understood the reason why the ignition timing lug on the flywheel is the size it is. Does the sensor for the CDI (bolted in the engine case) do it's thing immediately as the lug begins to pass by, or is it at the point where the lug is already going away from the sender in it's rotation? Where exactly does the spark happen, and why are the lugs different lengths?
If you ground off the leading edge of a lug would it make any difference to ignition timing, or it it only at the trailing edge where the spark takes place? |
| Nobby the Bastard |
| WD Forte |
 WD Forte World Chat Champion
| stinkwheel |
 Posted: 22:56 - 07 Jun 2023 Post subject: |
Would it not be whichever bit of the lug is next to the sensor at the point the spark happens. I'd imagine it would take so little time as to be nearly instantaneous? So you could have a look with a strobe.
I think the standard mechanical way of slightly fucking with electronic timing by a few degrees is to use an offset woodruff key. Or there's nothing to stop you just missing the key out and locking the flywheel down wherever you feel like it (other than the obvious absolute faff of holding everything in position while you do so).
Or you could slot the holes for the pickup and move it a bit. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| lingeringstin... |
| lingeringstin... |
| lingeringstin... |
| stinkwheel |
 Posted: 07:47 - 08 Jun 2023 Post subject: |
Early electric start enfield bullets are very hard on starters and had a habit of destroying sprag clutches by kicking back on a cold-start.
One of the solutions they came up with was an electronic spark delay box you plugged in which made it miss the first spark on startup. This meant it had to have done at least one complete rotation before sparking so the engine was already spinning over quite quickly before it attempted to fire. I'm not 100% sure how they achieved this.
However knowing how you historically like a contrary and over-complicated startup procedure, you could probably achieve this manually with an intermittant kill switch that earths the coil that you could hold down as you spin over the engine then release when it's got some momentum up. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
| WD Forte |
| virus |
 virus World Chat Champion
| stinkwheel |
 Posted: 18:50 - 08 Jun 2023 Post subject: |
Or you could slot the pickup and with an unholy arrangement of springs, strimmer cable and bowden cables, retro-fit your motorcycle with an advance/retard lever on the handlebars. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| virus |
 Posted: 18:23 - 09 Jun 2023 Post subject: |
| stinkwheel wrote: | Or you could slot the pickup and with an unholy arrangement of springs, strimmer cable and bowden cables, retro-fit your motorcycle with an advance/retard lever on the handlebars. |
That sounds perfect for OP and his batshit mental voodoo ways of making things somehow work  ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| lingeringstin... |
| lingeringstin... |
| lingeringstin... |
| lingeringstin... |
 Posted: 17:27 - 10 Jun 2023 Post subject: here comes trouble |
So when I held the bog standard flywheel next to the unknown flywheel with the slightly different lugbump on it here's what I got. The difference between the two is about 8 to 10mm. The unknown flywheel's lug starts roughly about halfway along from where the standard one does (see marker line in pic).
https://i.postimg.cc/fW54yWCF/3.jpg
The lug on the flywheel (same on all Honda or clone engines of this kind, CB125T, CMX250, Jinlun JL-11 etc.) is about 17.5mm long. I'd show the oddball unknown flywheel for comparison but it's on the bike and I can't be arse to take it off, but apart from the lug position they're identical.
The unknown flywheel with an identical sized but more reversed positioned lug works better, but it's not ideal. It's slightly retarded for my liking so I want to nudge the timing forward a bit and the only way I can see to do that is to grind off about 1/4 of the leading edge of a standard "too advanced" flywheel lug.
That will shorten the overall length of the lug by a quarter. I don't know if this is going to work because I don't know when the CDI actually fires. If it fires DURING the time the lug is passing the sensor then this might work. But if it fires only as the lug is breaking away from the immediate proximity of the sensor then this won't make any different to the timing. |
| stinkwheel |
| WD Forte |
| stinkwheel |
| lingeringstin... |
| lingeringstin... |
| WD Forte |
| lingeringstin... |
 Posted: 18:17 - 15 Jun 2023 Post subject: |
After absorbing all the previous information I decided that the bump on the flywheel was probably the instigator of a square wave triggering thing, so the obvious way to retard the ignition would be to hack a bit off the leading edge of the bump.
Turns out this appears to be correct because after doing that to retard the timing a bit and subdue the shocking starter clutch malarky brought on by the consequences of my shortened top end, it all worked perfectly fine. The bike starts nice and runs well.
I still have no idea why the standard bump on a standard flywheel of this type is the length it is but I suspect it's not because of some kind of rocket science or White Man's Magic, it's probably just down to "because that's how we made it" in Hondaspeak.
So there you have it, folks. Due to the way the engine cases are designed you can't really just slot the bolt holes on the sensor and move it around very easily so the other alternative for timing adjustment is to fiddle about with the of the bump on the flywheel. Of course this is completely unnecessary on a bog standard engine that I haven't molested in unspeakable ways out of curiosity.
I suppose it's a good thing I'm not a goat farmer.
(Do ANY of these linky image things actually work?)
[url=https://postimages.org/][img]https://i.postimg.cc/gJGHkKS0/P1000815.jpg[/img][/url]
[url=https://postimages.org/][img]https://i.postimg.cc/cLQ3gn8t/P1000816.jpg[/img][/url]
https://ibb.co/rHkWsMs
https://ibb.co/9rYgk6C |
| stinkwheel |
The last post was made 3 years, 75 days ago. Instead of replying here, would creating a new thread be more useful? |
