Aprilia RS660
FF68 This post is not being displayed because the poster is banned. Unhide this post / all posts.
andys675
PostPosted: 16:26 - 07 May 2025    Post subject: Reply with quote
I've sold loads, many went on the track for super twins
teach you a lot about holding corner speed
very early bikes recalled for new engines as the rods weren't heat treated, won't be any around that haven't been fixed
mid 2023 they had a batch with dodgy water pump seal, again they will all be fixed by now
if used on the track I've seen one that the oil pressure regulator dropped off in the sump which killed the entire engine, but never on a road bike, to fix this it needs lockwiring with the sump off
plastic tank, not yet an issue, E5 so no venting through cap and one or two had issues with tank pressure
as for racing they're pretty safe standard or with a full system sub 100hp at the back wheel but those who've tuned then above that have destroyed many engines
12k valve service a bit fiddly as you have to remove the cam wheel bolts which are obscured by the frame and then wind the cam to relieve pressure on the valves before removing it
The last post was made 1 year, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.46 - MySQL Queries: 14 - Page Size: 36.99 Kb
