CBF125 - The Wobble
Zen Dog
PostPosted: 23:38 - 11 May 2025    Post subject: CBF125 - The Wobble Reply with quote
Denizens of the Workshop, your wisdom please. I bought a 2011 CBF125 off my mate's partner about a year ago, just for a bit of fun. She'd dropped it and lost confidence, and I wanted something I could absolutely thrash while staying vaguely within legal speeds.
It's been great (I mean it's awful, but I enjoy it and it's simple and reliable), but when I got it the handlebars weren't quite straight. It was only slight, and I assumed that the aforementioned drop was responsible and had slightly bent the bars, and didn't pay too much attention. A couple of months later it went over in the wind and properly bent the bars. So I bought replacement bars, but after fitting... the handlebars still weren't straight. So it was time to employ the time honoured technique of slightly loosening all the bolts in the front end, and holding the bike straight while repeatedly bonking it into a wall. This had the desired effect and the handlebars are now straight. I thought all was good until during the celebration/final testing phase, I took my hands off the bars, and they started behaving just like this - https://www.youtube.com/watch?v=O88djeVP4Bk
Clearly something isn't right. The bike feels fine to ride, just the same as before, although with perhaps a tiny feel of twitchiness as you pass over the fully upright position when switching lean from one side to the other. As long as you keep your hands on the bars, this weird exponential tankslapper doesn't occur, and it's easy enough to correct when it does. But I'm probably going to be selling this bike soon, and I don't want to sell it to some poor learner with some kind of inherent stability issue. So, so far I've checked -
Arrow Tyre pressures.
Arrow Rear wheel alignment. I measured this from the axle to the end of the swingarm, and if it's out, it's no more than a millimeter.
Arrow Head bearings. Feels fine on the ground, and smooth as silk with the front end in the air. I can't feel any notchiness at all.
Things I haven't done yet -
Arrow Get the wheels balanced, particularly the front.
Arrow Check the bolts again. I did all the bolts up to the specificed torque settings again when I did the wall bonking, but I should probably check them all (caliper/mudguard/axle/triple tree fork pinch bolts) again.
Arrow Check the overall straightness of the bike. I've never had a technique for doing this that I had any real faith in. Just getting the handlebars perfectly straight (and keeping them there) at a standstill is a hassle (though I know a few ways to do this), but accurately measuring "parallelness", particularly when front/rear tyres have different widths, with bits of wood and some string, just never seems satisfactory. I have just thought of a way involving a laser level on the front tyrewall though...
Any other suggestions would be very welcome.
PostPosted: 23:46 - 11 May 2025    Post subject: Reply with quote
That kind of thing usually originates in the back end somewhere.
Been through and checked all the bolts are tight? Tyres properly seated on the bead? Bushes in the rear suspension got any play in them? Wheel and sprocket carrier bearings in good order? (if you haven't had the wheel out, you haven't checked)
blurredman
PostPosted: 07:49 - 12 May 2025    Post subject: Reply with quote
Don't take your hands off the bars? Some of my bikes do this fiercely.
that_impulse_guy
PostPosted: 08:59 - 12 May 2025    Post subject: Reply with quote
the banging against the wall technique I used on my 50cc loads of times. I'm older now and realise there is actually a step2 to this technique.
I know a lot of folks have opinions about this guy, but I'm just putting this video here to save me typing alot of words.
https://www.youtube.com/watch?v=pNEmOqY02EU
rpsmith79
PostPosted: 09:42 - 12 May 2025    Post subject: Re: CBF125 - The Wobble Reply with quote
Have you tied actually putting a straight edge against the rear wheel to check alignment, rather than replying on the measurement of the adjusters
Zen Dog
PostPosted: 11:29 - 12 May 2025    Post subject: Reply with quote
Then there's something wrong with them. It's not like I do this all the time. But the other day my phone came off the mount on my 800 because I hadn't quite clipped it in correctly, I needed one hand to catch the phone and the other to open a pocket to chuck it in. You should be able to ride no-hands without ending up in a ditch, even if riding no-hands isn't something I'm planning on doing.
rpsmith79 wrote:
...rather than replying on the measurement of the adjusters
I will be checking this again, but I didn't rely on measuring the adjusters, as I know they aren't always accurate.
blurredman
PostPosted: 12:09 - 12 May 2025    Post subject: Reply with quote
That doesn't happen to me- if I need directions I stop and get the a-z out of my pocket Laughing
Not saying your concerns aren't an issue- I just got used to it. It can be many things you may or may not looked at yet. You've checked tyre pressures and you're thinking about wheel balancing but what about the tyre itself - is it worn oddly? Some tyres are known to scallop etc. What's it got?
Zen Dog
PostPosted: 14:57 - 12 May 2025    Post subject: Reply with quote
The front I had changed about 6 months ago, and the bike is so light it's barely worn the molding knobbles off. It's basically brand new. The rear though, could be a factor. It's an old conti go and it's got plenty of tread left, but there's a bit of age related cracking on the sidewall, and it has a slow puncture. I was thinking about replacing it anyway so it's probably a good idea to just get on with doing that.
blurredman
PostPosted: 08:46 - 13 May 2025    Post subject: Reply with quote
Can I have it? Embarassed Laughing
Zen Dog
PostPosted: 19:42 - 15 May 2025    Post subject: Reply with quote
I had a look at the rear end generally yesterday. For a start, I gave it all a damn good wiggle, and I can't detect any play in anything, horizontal or vertical. Rear suspension feels smooth with minimal damping (but I suspect thats normal). So I had the rear wheel out.
https://i.imgur.com/cNMHCxjl.jpeg
Bearings on the wheel are smooth, as are the ones for the sprocket carrier. Cush drive rubbers appear normal. Drum brake wearing evenly and in good nick.
https://i.imgur.com/FzM4RvFl.jpeg
Swingarm is definitely rusty in multiple places, but nothing structural. The only thing I found that didn't look exactly as I'd expect is the right-side swingarm mount. There's more of a gap between the bits than I'd expect. But even then, nothing is loose. I regreased the rear wheel assembly and put it all back together and torqued the axle up as specified. Took the bike out afterwards and it's just the same, still wobbling.
https://i.imgur.com/HzocxuAl.jpeg
I've ordered a new rear tyre so I've get that changed and balanced on the weekend. Maybe I should get them to balance the front at the same time, just to exclude that as a possibility. Thinking
What's the step 2? I watched the video and it shows the steps I used (except I forgot to loosen/tighten the centre nut, and I did wall bonking not lunging), but other than that I followed the procedure in the video.
PostPosted: 19:59 - 15 May 2025    Post subject: Reply with quote
Have you checked the subframe bolts (if it has a bolt on subframe). I got a horrible wobble on my VFR once as i was leaving a campsite and it turned out I'd lost one bolt and another was loose. Bike was all over the place. Hadn't noticed at all on the way there but I'd been hooning so my arse wasn't really on the seat much.
Zen Dog
PostPosted: 20:08 - 15 May 2025    Post subject: Reply with quote
It's all one big chunk of steel, so that's one issue I can definitely rule out. Unless the frame is cracked... Very Happy
Genuinely interesting that the sensation wasn't immediately obvious as a subframe issue though, and felt like the bike itself had a problem.
Robby
Dirty Old Man
PostPosted: 07:39 - 16 May 2025    Post subject: Reply with quote
You've done the obvious stuff, which gets everything aligned if everything was straight to begin with. Now you need to check what is bent.
First, easiest step is to see if the wheels line up. I hate using string for this, I use a couple of long bits of 2x4 held together by some very long bolts or threaded bar. The lengths of wood are clamped around the rear wheel, then I can get a decent measure on how out of true the front wheel is.
If the front wheel is out of true, I then check the forks. I don't have a shortcut here, I just strip them down and check the stanchions for straightness by rolling them on something flat. A sheet of glass is ideal, but a paving slab is pretty close. If it appears to roll and not behave like a banana, I'm happy. I put a straight edge against the fork lowers, but I've never had trouble with them, it's always been bent stanchions for me.
For the swingarm it's often difficult to find a suitably straight edge to check, so I just measure and compare what I can from side to side. I do remove the front swingarm bolt and rear example, to roll them on my workbench and look for bending like on a stanchion.
Then wheels. The axle is mounted in my vice, with the vice gripping the nut and the axle pointed straight up. The wheel sits over the axle, so I can spin it. I mount up my dial guage pressing against the rim, and spin the wheel to look for runout. The correct allowed amount of runout is recorded in the Haynes. For a general rough idea, I don't worry about 1mm and I do worry about 4mm. I check the wheels with or without the tyres mounted.
If all of that is straight, then it could be the frame, but I can't measure a frame. Best I've managed is removing everything and seeing if it goes twang when I remove a major stressed member, like the engine. Or seeing if it's difficult to replace the engine, when it relies on 3 long bolts going through the frame in 3 different places. Those holes don't line up on a bent frame.
So I would take it all apart, measure what I can, then put it all back together. I will generally find the problem when I measure, or when I try to put it all back together.
The most bastard part of the whole job is routing the clutch and throttle cables. I can never get that right. I also tend to replace the handlebars as a matter of course, just in case they were the problem all along.
Lots and lots of grease on reassembly. The factory never use enough, and I want this to be better than new.
On a CBF, all of the above is only a day's work. Good to order fork seals and oil before the stripdown, they are the only bit I know I can't re-use.
Zen Dog
PostPosted: 16:17 - 01 Jun 2025    Post subject: Reply with quote
So, the story continues (very slowly as ever).
I've had the rear tyre changed, but I wasn't able to get it balanced, as the balancer at my usual bike shop has a spindle which is too large for the wheel. Rang a couple of other places, one didn't do tyres, and the other could do it, but had run out of wheel weights and was waiting on replacements. So I need to wait.
In the meantime, I thought I'd check the straightness, using some method I actually felt confident in. So I got a couple of lengths of 2m angle steel tube. They aren't perfectly straight (a slight bend from being cut I guess) but as long as I took that into account (aligning the bend up) they were seemingly perfectly parallel. So I drilled a couple of holes for threaded bar, just to help align everything, and created the "Parallelorizer". I got the bike upright, raised the Parallelorizer on a couple of wooden blocks (just so it would interact with more of the rear wheel) and lined it all up at the back.
https://i.imgur.com/v28FHLZl.jpeg
https://i.imgur.com/dIfFa7nl.jpeg
At the front, results were not good. The front was clearly offset to the left.
https://i.imgur.com/mSA4R2ul.jpeg
https://i.imgur.com/QEwuATRl.jpeg
https://i.imgur.com/1yMRTPsl.jpeg
https://i.imgur.com/HPnRQfdl.jpeg
The chain adjusters at the back were out by a couple of mm when I measured again, but correcting this didn't seem to make the bike visibly straighter at all. I guess the bike must be at least slightly bent. I don't think even incorrectly arranged front wheel spacers or similar would account for this difference. Anyway, I decided to get the wheels parallel, so I loosened the rear axle, wound off the right adjuster a bit, and booted it forward. A couple of adjustments later, and it looked like this -
https://i.imgur.com/OHz6xpFl.jpeg
https://i.imgur.com/jWXYYi2l.jpeg
So I tightened it all back up (strangely, I had to loosen the rear brake slightly as it started binding) and then took it out. And....... the wobble is still there.
Wheel balancing next.
doggone
PostPosted: 17:59 - 01 Jun 2025    Post subject: Reply with quote
I think some bikes do have designed slight offset from new but it does look suspicious.
random google search wrote:
When the ZRX1100 became the 1200 they wanted to fit a fashionable wider rear wheel so they offset the rear approx. 6mm.
Basically they offset the wheel to the disc side by 1/2 inch so they could leave the chain run as is.
Robby
Dirty Old Man
PostPosted: 18:08 - 01 Jun 2025    Post subject: Reply with quote
At a guess, you had to adjust the rear brake because the wheel is now on the piss.
Looks bent. My first thought was a missing spacer, but it's pushed over to the speedo drive side where the speedo drive is the spacer.
Zen Dog
PostPosted: 18:45 - 01 Jun 2025    Post subject: Reply with quote
I think you're right. When I adjusted it I did wonder, if it had been out of alignment the whole time, maybe the shoes had worn to compensate and now some previously unworn part of the shoe was coming into play. But the shoes looked good and wearing normally last time I had the back wheel off. So yeah, I think you're right. I'm going to adjust it back when I have wheels off for balancing.
If that doesn't work, not sure I can be arsed dismantling the whole bike. I've already got one in bits...
PostPosted: 19:03 - 01 Jun 2025    Post subject: Reply with quote
You can balance the wheel yourself. You just need it mounted on the level axle and free to spin. You could even do it in the bike with the brake and cush-drive removed so the axle is in place and the wheel is just running on it. I've done it on a couple of axle stands before.
You will need a piece of chalk and some weights.
Spin the wheel. Mark which bit is at the bottom when it stops. Spin it again. If the chalk mark lands up in the same place, add weight opposite the mark. Spin it again. If the chalk mark lands at the bottom, add more. If it lands at the top, you added too much. Keep going until it stops at a random place each time or you're adding/subtracting tiny bits of weight and it keeps switching top or bottom because then it's only off by that tiny bit.
PostPosted: 08:12 - 02 Jun 2025    Post subject: Reply with quote
My varadero did this, only with the top box on with something in it. I didn't figure out why but it was always when it was on. So weird.
Zen Dog
PostPosted: 10:41 - 02 Jun 2025    Post subject: Reply with quote
Actually, that's a really good shout. I do have a massive top box on most of the time. Will give it a test with it removed. Thumbs Up
doggone
PostPosted: 15:42 - 02 Jun 2025    Post subject: Reply with quote
Unless it was somehow miles out I can't see it being anything to do with wheel balancing, I usually fit my own tyres and don't bother so long as any weights already there stay in place.
Zen Dog
PostPosted: 18:56 - 02 Jun 2025    Post subject: Reply with quote
Paddy gets a HobNob in the flavour of his choice (milk chocolate obviously but there are deviants out there on the interwebs).
Top box removed. Wobble gone. I'm sure others might have suggested it as the problem if I'd actually mentioned I had a massive top box fitted. And even more, I should have thought about whether having a top box so large that the bike looks like the Starship Enterprise reversing when it comes round the corner, would have possibly had a detrimental effect on stability.
But I didn't. Thanks to everyone who contributed. At least that's one issue sorted. Very Happy
PostPosted: 20:15 - 02 Jun 2025    Post subject: Reply with quote
At least you know you have good wheel bearings.
PostPosted: 16:57 - 05 Jun 2025    Post subject: Reply with quote
Big win, absolutely no idea why mine did it. Was at 77k, new front and rear bearings, steering bearings were ace, suspension was all refreshed... just got mad wobble.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.64 - MySQL Queries: 13 - Page Size: 140.37 Kb
