| SirEdward |
 SirEdward Could Be A Chat Bot
 Posted: 18:37 - 04 Jun 2011 Post subject: *Bought, pics ->* Suzuki GSX-R 750 SRAD, buying advice ha |
Lo,
I'm looking into a particular gixxer 750, a year 2000 model. What should one look out for, when it comes to mechanical problems? Bike is 15k miles, FI, new spark plugs, air filter, aesthetically looks mint.
Thanks ____________________ "Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
Pardot Kynes in "Appendix I: The Ecology of Dune""
| Paulington |
 Paulington World Chat Champion
 Posted: 19:06 - 04 Jun 2011 Post subject: |
Hey,
Keep a look out for the standard things, no cracks in the frame/swingarm/subframe/rims. Not too much pitting in the forks and that the stanchions or the entire fork is not bent. Make sure the engine number matches the V5 and that the V5 is genuine and matches the address of where you are etc.
Scratches in paintwork, make sure if it has any stickers on it that they aren't hiding a dent as that's the main reason people put them on in the first place..
When you get there, say hello, shake hands or whatever and then PUT YOUR HANDS ON THE ENGINE AND EXHAUST. If it's hot just walk away as you cannot get a true representation of how it starts from cold. If you want to try it again tell him you'll come again tomorrow and you want it to be stone cold upon arrival.
If you take a look here, it's a very comprehensive guide of things to look out for and what to do when viewing a motorcycle.
As for things specific to an SRAD, a lot of them get tracked so look for things odd/out of place. Such as:
Lots of tyre changing marks on the rims.
Make sure the mileage matches the logbooks as it could have had the speedo changed at some point if it has been tracked.
Check that the brakes don't bind and that the discs aren't warped, you feel that as pulsing in the brake lever if it's pretty bad as you brake.
Hope that helps! ! ____________________ "Four wheels move the body, two wheels move the soul."
CBT: 27/08/08. Theory: 04/09/09. Module 1: 16/09/09. Module 2: 01/10/09. |
| P.addy |
 P.addy Red Rocket
 Posted: 19:15 - 04 Jun 2011 Post subject: |
If that's the gsxr750y then I own that model.
Mines on 30,000 miles. Engine has had a rattle for a while but I got it looked over today... He said it's got a slightly loose header pipe. Sorted that.
Check rear suspension... It's quite low and picks up loads of crap. The gearbox on mine is pretty smooth... But I've heard some get clunky if hammered.
It's FI but has manual choke and idle screw... Check these work.
Check condition of forks... Leaks will cost you a bit unless you can DIY.
Pretty shit on fuel if you ride sensible... If you don't...it plummets even more  |
| SirEdward |
 Posted: 19:21 - 04 Jun 2011 Post subject: |
It does come with a tailcone piece, could've been a track bike. It is indeed a gsx-r 750y (2k model), and ##Paddy## shit on the fuel, shit for a sportbike, or average? Should I go for an R1 instead then.
Appreciated, both Paulington & ##Paddy##. ____________________ "Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
Pardot Kynes in "Appendix I: The Ecology of Dune"" |
| Seb |
 Seb World Chat Champion
 Posted: 19:49 - 04 Jun 2011 Post subject: |
Check the state of the front subframe, most specifically the metal bracket that goes between the forks and yokes from the front of the frame to the clocks. That frame seems to be the first thing to get smashed up in a crash and the last thing to get replaced afterwards  ____________________ 2010 Triumph 1050 Sprint ST |
| SirEdward |
 Posted: 09:42 - 05 Jun 2011 Post subject: |
##Paddy##,
what is the first thing to succumb to rust? I know the full exhaust system is stainless steel, how's the build quality: bolts, steering mechanism components, bearings?
I'm getting sick of rusty Hondas.
| P.addy |
 P.addy Red Rocket
 Posted: 10:04 - 05 Jun 2011 Post subject: |
| SirEdward |
 Posted: 10:44 - 05 Jun 2011 Post subject: |
Hot damn, looks squeaky-clean for a 11 year old bike. I'll return the favour, if and when I settle the deal.
Thanks once again. ____________________ "Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
| P.addy |
 P.addy Red Rocket
| SirEdward |
 Posted: 10:51 - 05 Jun 2011 Post subject: |
Hah, I saw the dent, was talking about the frame/subframe & misc metal parts - look clean, rear brake caliper might need some scrubbing, though.  ____________________ "Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
| P.addy |
 P.addy Red Rocket
 Posted: 10:53 - 05 Jun 2011 Post subject: |
| SirEdward |
 Posted: 21:27 - 08 Jun 2011 Post subject: |
https://img89.imageshack.us/img89/6029/dsc00050zm.jpg
https://img834.imageshack.us/img834/2121/dsc00052ku.jpg
https://img90.imageshack.us/img90/926/dsc00053su.jpg
Ou-la-la. There was no RH spoiler on at that time due to *fap, fap, fap* work on the bike. Love it, turned out to be 25k miles, never crashed, though, some scratches on the right side due to a devil-of-a-kid dropping it in the presence of his father (previous owner).
I'm going to tap this bitch with GPS alarm and Adamantium locks.  ____________________ "Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
| Chalky. |
 Chalky. World Chat Champion
| SirEdward |
| The Tot |
 The Tot World Chat Champion
| Alex A |
 Alex A World Chat Champion
| johnsmith222 |
 johnsmith222 World Chat Champion
| Redoko |
 Redoko World Chat Champion
 Posted: 02:24 - 10 Jun 2011 Post subject: |
Liking the colour scheme.  ____________________ "Let's face it, this is not the worst thing you've caught me doing."
Sudika Sportsman SK50QT > Gilera DNA50 > Honda CBR125 RW7 > Kawasaki Zephyr750 > Suzuki GSXR600 > Honda Hornet CB600F '51 |
| SirEdward |
| The Tot |
 Posted: 18:59 - 10 Jun 2011 Post subject: |
I'm glad you're happy with your purchase so I'm in no position to slag it off or pick holes in it.
But you're missing the point I made about your butchered front fairing.
Compare your side profile with the one below.
https://www.icenimotorcycles.co.uk/images/Project%20pictures/GSXR%20600/after.JPG
Have a look at your nose cone and then have a look at the one on your bike. I see 3 things
The most obvious is that the fairing does not extend all the way up - it's been hacksawed hence why he's put tape or trip over the fairing edge and cheapo mirrors.
There's no H-Frame/fairing support. The ONLY reason why not to have this is if it's snapped in a major crash and been bent. He clearly didn't want to replace it so decided to butcher the fairing instead.
You definitely WILL not be able to put a double bubble screen on it because you'll run out of fairing- the screen WILL not stay secure with the top two bolts missing - ride at any sort of speed and it will start to flap. Put a standard screen on it (double bubble if you must) and you may find that the fairing doesn't have the full coverage.
I think it's a case of a seller knowing they've got an enthusiastic buyer and telling half-truths or just blatant lies. Did you have anybody "experienced" with you to check the bike over, because anybody would have spotted that a mile away.
25,000 miles... maybe a substantial amount on track given the calibre of the bike. Just don't want you to find out in 2 months time that the bike was a lemon. I think he's described it as mutton dressed as lamb. ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| UKRedwing |
 UKRedwing Trackday Trickster
 Posted: 20:31 - 10 Jun 2011 Post subject: |
Lol did OP not notice his 'modified' front end?  |
| Seb |
 Posted: 20:50 - 10 Jun 2011 Post subject: |
Given the top brace is gone, I'd suggest you check over the headlight and clock bracket I mentioned before rather closely, if it's mint then it might have been a moment of madness from someone trying to make the bike look more modern, if it's patched up then it's almost certainly the result of a crash.
Personally I wouldn't panic too much frankly, they are far from fragile bikes, just ask Mattspratt about the ordeals his 600 survived  ____________________ 2010 Triumph 1050 Sprint ST |
| SirEdward |
 Posted: 21:02 - 10 Jun 2011 Post subject: |
| P.addy |
 P.addy Red Rocket
 Posted: 21:08 - 10 Jun 2011 Post subject: |
| SirEdward |
 Posted: 21:11 - 10 Jun 2011 Post subject: |
1200, practically 'traded' a spare Honda CBF-500 for it. Also, ##Paddy##, yours appears to be not the Y model, K1 have a digital speedo - does yours?  ____________________ "Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
The last post was made 15 years, 141 days ago. Instead of replying here, would creating a new thread be more useful? |
