1990 ZZR600 Crank Seal Leak
Diddums
PostPosted: 17:53 - 08 Jun 2025    Post subject: 1990 ZZR600 Crank Seal Leak Reply with quote
Afternoon all. I'm in the process of restoring a 1990 ZZR600 (D model), which I definitely didn't buy whilst under the influece on ebay.
Anyway, I'm using this to learn how to do stuff myself, and today I got it started for the first time, but it's got a leaking crank seal on the right hand side of the engine.
Here's a vid:
https://www.youtube.com/shorts/AZc_ATZKelY
Is it possible to DIY this? Can it be done without splitting the engine? I'd like to give it a go myself if possible, but not really sure on where to start!
Cheers.
PostPosted: 18:37 - 08 Jun 2025    Post subject: Reply with quote
Wow, that's pretty bad. There's a trick I've seen used to sneak crank seals out but I'm not sure if it'll work on your bike specifically, depends how the seal fits and if it has a ridge on it to hold it in position.
Basically, you carefully drill two small pilot holes in the seal and screw self tappers into them. You then wrap a long-ish loop of wire between the two screw heads and use a hammer to tap against the loop and hopefully pull the seal out. Then much ado with bits of pipe to drive the new one in.
My main question is why is it like that? I've never seen a crank seal leaking so badly on a japanese 4-stroke. So is a main bearing on the way out and that's killed the seal? Is the crankcae breather blocked?
Why is oil leaking out when it's running but not when it's parked? It's suggesting to me it's pressurised in there and if the breather's working properly, there should be a slight vacuum in the crankcases.
Diddums
PostPosted: 19:00 - 08 Jun 2025    Post subject: Reply with quote
Thanks for the response! I'm still learning here so apologies for the stupid question, but what am I looking for in terms of a crankcase breather? It certainly seems like the crank is pressurized, so that could well be the cause.
PostPosted: 07:29 - 09 Jun 2025    Post subject: Reply with quote
Again, I'm not familiar with these engines but looking at pictures, there's a thickish black hose coming vertically off the top, back right of the engine. The other end is are generally connected into the airbox somewhere. That should be the crankcase breather. Usually a case of making sure it isn't pinched or blocked. Some have a one-way valve either in the hose or internally so they can blow but not suck.
I suppose one test would be to run it with the oil filler cap off (meaning you can't really get positive crankcase pressure) and see if the leak goes away.
jeffyjeff
PostPosted: 08:34 - 09 Jun 2025    Post subject: Reply with quote
Appears to me that the leak could be between the seal and the counterbore; seal to crank nose might be leak tight. I agree that the leak appears to be pressurized in origin, but probably does not leak at rest because the oil level is below the level of the crank. Could it be that someone has worked on this prior to sale, and that the seal was mis-installed, or even the wrong seal fitted? More targeted, focused observation might reveal more clues.
PS I have used sheet metal screws to remove crank seals before, but instead of wire, a small prybar was used to work the seal loose. Mostly on automotive, but it did work on my BMW R1150. That seal looks a little small for this trick to work. Works best when the seal is encased in a metal ring.
Diddums
PostPosted: 09:51 - 09 Jun 2025    Post subject: Reply with quote
Thanks again. Did a lot more thinking last night and when disassembling the bike I took loads of photos, this is one of them:
https://i.imgur.com/UqRBGi8.png
You can see the black hose popping out of the crankcase at the bottom of this photo, could be the crankcase breather. I also recall when I was disassembling the bike that the hose came off, and I popped it back on. If there's a non-return valve in the hose, it's very possible that I put it on the wrong way around and cause the positive pressure in the case. Further to that, even if I did put it back on the right way around, I also cable tied a plastic bag over it to prevent any debris falling in, which would've also restricted airflow. Not by much as the bag is quite flimsy, and it also certainly had a hole in it when I removed it, but whether that hole was made by me or positive pressure is anyone's guess at this point.
I should also note that I'm the 13th owner of this 35 year old bike with 27k miles on it, so it's very likely that the seal was just rock hard and old and this was the final straw. I've got one arriving tomorrow, hopefully it's a fairly easy job to replace it.
Diddums
PostPosted: 09:53 - 09 Jun 2025    Post subject: Reply with quote
Thanks Jeff. I'll be replacing the seal in the next couple of days so will know then. As per my post above, it's very likely that this is a combination of an ageaing, weak seal and my own stupidity that's caused this, I'll know once I've replaced it.
Diddums
PostPosted: 09:57 - 09 Jun 2025    Post subject: Reply with quote
Just in case anyone's interested, here's a build log of the bike and my learning adventures along the way:
https://forums.overclockers.co.uk/threads/kawasaki-zzr600-progress-thread.19001282/
jeffyjeff
PostPosted: 10:54 - 09 Jun 2025    Post subject: Reply with quote
Diddums wrote:
... it's very likely that this is a combination of an ageaing, weak seal and my own stupidity that's caused this...
"Research is what I'm doing when I don't know what I'm doing." Wernher von Braun. Cheers to you for challenging your comfort level. for trusting your skills and doing something that you never did before. The world could use a little more of that. Wink
Diddums
PostPosted: 13:10 - 09 Jun 2025    Post subject: Reply with quote
Yeah, I've fiddled with stuff for as long as I can remember, and only broken a few things beyond repair!
People on my Facebook post are saying that this oil is perfectly normal and forms part of the engine's lubrication system, seems a bit of a stretch to me!
PostPosted: 16:26 - 09 Jun 2025    Post subject: Reply with quote
If it can't be done from the outside, splitting one of those engines isn't a horrible job. I mean, it's not fun and will push your comfort level a long way but it's a horizontally split engine so you can take it out, flip it upside down and take the bottom off without having to strip the entire engine like you do with vertically split engines.
A plastic bag over the breather can't have been helping. I have a breather on one of my bikes (a very different one to yours mind) which periodically got the end of the hose pinched over before I rearranged everything. It used to literally piss oil out of every gasket and seal when it happened.
jeffyjeff
PostPosted: 09:42 - 10 Jun 2025    Post subject: Reply with quote
Diddums wrote:
....People on my Facebook post are saying that this oil is perfectly normal and forms part of the engine's lubrication system, seems a bit of a stretch to me!
Do the folks on your Facebook page have more knowledge and expertise in this matter than we do? I hope so. Why would the Kawi engineers purposefully send oil out to the right-side engine case where the magnetic ignition pick-up resides? What might be the reason for that when a properly functioning crank seal could keep that space clean and dry? There appears to be a massive drain passage behind the pick-up, and the oil flows straight to it, but why? Sometimes oil is used for purposes other than lubrication, like cooling the stator windings on some bikes. The position of the ignition pick-up in relation to the oil drain suggests the pick-up is bathed in oil during normal engine operation. Did a volume of oil leak out when you removed the cover? Did the 1990 Kawi engineers feel a need to cool the ignition pick-up? Am I overthinking this? This is most curious.
Diddums
PostPosted: 10:27 - 10 Jun 2025    Post subject: Reply with quote
It doesn't look that bad to be honest, and I'm more than happy to DIY it! The whole point is to learn this stuff Smile
Diddums
PostPosted: 10:29 - 10 Jun 2025    Post subject: Reply with quote
I can see the logic of what they're saying, but it just doesn't feel right. There was also no oil in that area when I initially removed the cover, and the oil was really thin due to being full of petrol so it just adds more weight to the theory that this is borked and needs sorting!
I very much doubt that this pulse generator needs cooling tbh. Hopefully the seal arrives today and I can start pulling it apart to see what's up.
I'll update when I know more, thanks for the help!
PostPosted: 11:04 - 10 Jun 2025    Post subject: Reply with quote
It's possible, wet alternators are a thing. I presume you have a workshop manual, there is usually a lubrication flow chart in them somewhere.
Is there a return passage for oil that gets in there?
Is it actually a seal or is it just an o-ring?
PostPosted: 11:36 - 10 Jun 2025    Post subject: Reply with quote
It's only a timing sensor/pickup no alternator (like my XJ) I doubt very much it's supposed to be wet - looks like a seal form the vid.
Diddums
PostPosted: 19:00 - 12 Jun 2025    Post subject: Reply with quote
A bit more theorising and faffing this afternoon. After pulling the pulse generator wheel off, I had a close look and it does look like these holes are oil scavenging ports:
https://i.imgur.com/LG9CkD1.jpeg
https://i.imgur.com/U63KB3M.jpeg
This coupled with what looks like rathre old oil stains in the casing means I bolted the cover back on, topped it up with oil and fired it up. Either it seizes and I have to yank it apart anyway, or it works. So far, so good:
https://youtube.com/shorts/S6rT1YYNcyE
This weekend I'll flush and seal the tank, clean the airbox and bolt it all together properly. Then balance the carbs, do an engine flush and replace the oil and filter with the final stuff. The current oil is sacrificial Castrol stuff.
Assuming there's any oil left in it of course Very Happy
PostPosted: 10:44 - 13 Jun 2025    Post subject: Reply with quote
Ah.. now it doesn't look like a seal Embarassed
Diddums
PostPosted: 19:53 - 17 Jun 2025    Post subject: Reply with quote
So definitely not an oil seal then Very Happy
It's starting to take shape, finally the fruits of my labour are starting to pay off. Genuinely an awesome feeling, can't recommend it enough.
https://www.youtube.com/watch?v=rrjncXYQErU
Fullers1845
PostPosted: 15:25 - 18 Jun 2025    Post subject: Reply with quote
Very satisfying getting an oldie going again.
My brother-in-law has one of those, a '93 model that he's had for 30 years now!
You can pick one up for buttons, nice comfy bike, lovely engine - good for cruising about but absolutely flies at high revs if you ask it.
Honda CB125F, Kawasaki ZX6R J1, 1978 Kawasaki KZ650, 1922 Sheffield-Henderson Blackburne grasstrack/sprint
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 117.75 Kb
