| jeffyjeff |
 jeffyjeff World Chat Champion
 Posted: 16:34 - 08 Jun 2025 Post subject: YBR Fork Oil Change |
https://live.staticflickr.com/65535/54575078048_e81c6eccd1_z.jpg
This is my motorcycle; a 2015 YBR125 purchased new and placed in service in 2019. It has 21000 km on the clock. I use it to explore back country roads here in northern Morocco, and for that purpose it has served very well indeed. I service the bike using the Haynes manual as my primary reference. There are instances where Haynes is cryptically ambiguous regarding service intervals; draining and refilling the fork oil is one such instance. "After a high mileage the fork oil will deteriorate and its damping and lubrication qualities will be impaired." Although I do not personally consider 21k to be particularly high mileage, ten years is about as long as I care to leave any fluid in continued service…so it is out with the old and in with the new.
I am not new to this task, having changed out fork oil my Honda VFR's and PC800. The first time I did this job, I was shocked at how crappy the fork oil appeared when drained from the Honda forks, like sully gray machine oil with a metallic sheen to it. Literally, it reminded me of metallic paint and it was the same on all three Hondas. That is what I was expecting to drain out of my YBR forks, but no. The oil was black as overcooked coffee; no hint of metal suspended in the fluid whatsoever.
https://live.staticflickr.com/65535/54575081846_3c1d24a42f_z.jpg
I pumped the forks to evacuate all of the internals, and hung them upside down to drain completely. Then I carefully measured out fresh 10wt fork oil in a graduated cylinder. The new oil is clear and colorless, like vegetable oil. Haynes says 163cc should result in a fluid level of 142mm with the spring removed and the fork tubes fully seated. I drained a few cc's to obtain the required 142mm level, and reassembled the fork with the spring, washer, spacer, and cap. Then repeated with the opposite fork leg.
Since I was in it this far, I proceeded to remove the steering stem and check out the bearings. The bearings were in good physical condition, but bone dry. There was only a trace of dry caked grease on the bottom bearing cage. I smeared the races with Bardahl multipurpose grease and coated the bearings for assembly, then fit the stem and torqued down the adjuster nut by feel (no torque wrench, just a hook spanner). Haynes says 33 Nm to seat the bearing and 22 Nm final setting. I'm confident that I got it close. Bottom line, no wobbles and the bike tracks straight and well balanced.
Assembly went uneventfully, but once I got the bike underway, something felt…off. I initially thought the tire was out of balance, and even went so far as to check the pressure. Finding no abnormality, I hit the road again. It feels like the motorcycle is super sensitive to small imperfections in the road surface; when I struck a speed bump, wham! It hit me. IT'S THE OIL!
Changing my fork oil has made my bike significantly more sensitive to road surface imperfections. Given the conditions of the roads in my area here in Morocco, that might not be such a good thing. I know that I have the right quantity of oil in the forks, and I know it is the recommended viscosity. I'm amazed at the drastic effect that new fork oil has made in the quality of my ride. It doesn't feel unsafe; the bike tracks better than ever. Maybe I just became acclimated to a soft, spongy front end. I hope that after a few hundred kilometers I will become accustomed to a new (improved?) level of front-end performance. ____________________ History shows again and again how nature points out the folly of men - BOC |
| Robby |
 Robby Dirty Old Man
| jeffyjeff |
| lingeringstin... |
 lingeringstin... Spanner Monkey
| DJP |
 DJP Crazy Courier
| jeffyjeff |
| Ayrton |
 Ayrton World Chat Champion
| sickpup |
 sickpup Old Timer
| that_impulse_guy |
 that_impulse_guy Scooby Slapper
 Posted: 11:06 - 10 Jul 2025 Post subject: |
last year I rebuilt the forks on the NS400R with new stanchions, sliders, seals etc and used ATF to fill them up. Said to do so in the workshop manual. Works lovely. ____________________ Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R |
| A100man |
 A100man World Chat Champion
 Posted: 12:22 - 10 Jul 2025 Post subject: |
I tend you use ATF cos
a) Cheaper
b) You get more in a bottle (usually 1l and not 500ml) as most often you need 251 ml per leg or something
c) Use it for two stroke gearbox oil. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
The last post was made 1 year, 87 days ago. Instead of replying here, would creating a new thread be more useful? |
