Honda C110 throttle
Bossboy
PostPosted: 20:30 - 03 Aug 2025    Post subject: Honda C110 throttle Reply with quote
Hello all,
Got a C110, the throttle stays open if I let go of it, wondering how I can cure this
Any advice really welcome
PostPosted: 21:29 - 03 Aug 2025    Post subject: Reply with quote
Simple single-pull carb slide...
Disconnect the cable from the carb end and check the throttle twists freely and cable moves back and forth. Check the routing while you're at it for kinks and sharp bends.
Ideally take the carb off the bike. If you turn the carb upside down one would hope the slide would fall out under gravity. Pop it back in and check it moves smoothly, any grit in there? Maybe the needle is bent slightly and hanging up on the needle jet. Slides also have a particular orientation, make sure it's in the right way round Smile
What's the spring like? If it's non original or been cut down it won't have the strength to offset the friction in the throttle cable and more importantly, overcome the pressure of incoming air on the downstroke.
Put the carb back together with the cable and spring. Work the throttle while the carb's still off the bike and see what the slide's doing.
Bossboy
PostPosted: 20:15 - 04 Aug 2025    Post subject: Reply with quote
Many thanks will check everything you have advised
sickpup
Old Timer
PostPosted: 22:04 - 04 Aug 2025    Post subject: Reply with quote
Its likely the cable needs replacing or crap under the throttle tube.
PostPosted: 11:41 - 13 Aug 2025    Post subject: Reply with quote
If I remember correctly, the C110 throttle is one of those internal ones that pulls a metal slug in and out inside the handlebar on a cam peg from the twist grip. So it pulls the cable in and out rather than wrapping it round the twist-grip.
So that mechanism can get gummed up, may just need to be cleaned and lubricated.
That said, it's probably just a sticky cable which either needs to be lubed or replaced.
Bossboy
PostPosted: 21:04 - 12 Nov 2025    Post subject: Thanks Reply with quote
Thanks to you all
Sorry for late reply, never got notification of your answers
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 48.74 Kb
