Yamah MT 125 overheating
Texpis
PostPosted: 20:24 - 13 Aug 2025    Post subject: Yamah MT 125 overheating Reply with quote
Hi all
Newby here both to the forum and biking, just passed my CBT and bought a 2017 Yamaha mt it has 40k miles on it.
It overheats (according to the gauge ) it seems a bit random when it does it but mainly on a long stretch in 4th or 5th.
I have changed the thermostat which would not open in boiling water but still the same. I’ve had the water pump out to see if it was worn all was fine the impeller was perfect, while I was there I back flushed the radiator, I have sprayed water through the radiator, I couldn’t find any no info on a bleed screw to bleed the system so I removed the temp sender to bleed it, but no difference.
So before I buy a new radiator any ideas.
Mick
jaffa90
PostPosted: 00:33 - 14 Aug 2025    Post subject: Reply with quote
Any other signs of overheating?
jeffyjeff
PostPosted: 01:14 - 14 Aug 2025    Post subject: Reply with quote
Good point. You sure do not want to replace the radiator if the problem is a defective temp sensor. Measure the temperature of the hose going to the top of the radiator. If the thermostat is not opening, that hose will stay cool. When the 'stat opens, that hose will get hot enough to burn you with prolonged contact. Prolonged operation in 4th or 5th should keep enough airflow going for the radiator to keep the engine at a stable, sub boiling temperature, say around 180F / 82C.
Things to check: make sure that the radiator fins are not blocked and that air can freely flow through the radiator. Also, make sure the radiator pressure cap is functional. Most auto parts stores should be able to test the pressure cap for you. If the radiator fan is coming on when the coolant nears the boiling point, and shutting off a few minutes after that, it would suggest that the system is operating normally. The temp sensor for the instrument panel and the temp switch for the fan are two separate components.
PostPosted: 08:08 - 14 Aug 2025    Post subject: Reply with quote
Odd it's doing it on prolonged, higher speed runs. Normally a defective cooling system would cause more issues at low speeds or in standing traffic. Does it cool back down when you slow down again?
Texpis
PostPosted: 08:32 - 14 Aug 2025    Post subject: Reply with quote
Hi thanks for the replies guys. There are no other signs of overheating, as soon as I slow down or stop the temp comes down. I’ll have a check of all the things you have suggested Jeff.
Mick
that_impulse_guy
PostPosted: 11:07 - 14 Aug 2025    Post subject: Reply with quote
you'll typically have two sensors.
One will be near the thermostat housing...its a resistor that changes its resistance based on heat. This is used for the temperature gauge...because its a smooth change, the gauge can move smoothly up and down (or the computer can display whatever number it wants on your display).
then, near the bottom of the radiator, the one you said you took out, would be another sensor. this is a binary thing...its opens/closed (Well, it grounds) a signal, and this turns the fan on or off.
I can offer two suggestions (well...three).
1) the sensor at the bottom of the radiator, you should be able to unplug the wire and tie it to ground somewhere, and the fan comes on. Ride around...do you still overheat? If no, that sensor was faulty.
2) sometimes...bikes need a bit of burping. Fill up all the coolant everywhere, go for a ride, at least enough to get it hot (20mins?)....come back, let it cool down....fill up coolant again.
3) buy one of these radiator caps, it should fit "most" bikes
https://www.ebay.co.uk/itm/115956298900
it gives you another gauge, in case the cluster gauge is lying to you. BTW, I linked you to a 0.9bar cap...yours may be different...buy the one your bike needs. What is also does it remove the possibility that your radiator cap is stuffed by replacing it with another one of extremely dubious and questionable quality. Your mileage may vary.
PostPosted: 15:44 - 14 Aug 2025    Post subject: Reply with quote
Mick
That's odd. It's usually the other way round. It would make me wonder if the filler cap is dodgy or if there's a very small head gasket leak. Or -as above- if the system isn't properly full.
I've had bikes before which had a tiny jetting leak through the head gasket which only happened when the engine was under heavy load. This would pressurise the system with exhaust gas and force coolant out into the expansion bottle. In the early stages it would then refill itself again as the speed dropped. In the latter stages as it got worse, it would piss coolant out of the bottle then land up underfilled.
Can you see the expansion bottle or reach any of the coolant hoses when you're riding? If the bottle is filling up significantly (it normally only fills up when the engine is really hot in slow traffic) or if the coolant hoses are getting rock hard, this could indicate an issue. Even feeling the hose with the bike stationary can give you an indication, if the rubber hose becomes really firm as you rev up the bike, it can indicate a head gasket leak, or at least suggest you need to investigate further.
An improperly sealing filler cap or one with a weak spring can cause similar symptoms, most people just change it out early doors because it's cheap and easy to do.
Texpis
PostPosted: 12:31 - 15 Aug 2025    Post subject: Reply with quote
Cheers again guys I’ve run the bike on tick over until it got to temp (sits at middle temp for ever fan doesn’t come on)both sides radiator hoses were hot, so thermostat okay will try you’re other suggestions and get back
Mick
Texpis
PostPosted: 22:49 - 21 Aug 2025    Post subject: Reply with quote
Okay to finish this off after a lot of trying to diagnose it ends up an intermittent fault on the connector to the fans some how at speed the fault occurred stopping the fan, when stopping the bike the fan was on, cleaned and tightened the connector.
Rode for 2 hours temp rock steady, I am shocked at how much the fan is needed to regulate the temp I would have thought at hi speed the air through the radiator would be sufficient but obviously not.
Mick
jeffyjeff
PostPosted: 04:14 - 22 Aug 2025    Post subject: Reply with quote
Texpis wrote:
I would have thought at hi speed the air through the radiator would be sufficient but obviously not.Mick
At high speed the air through the radiator should be sufficient to keep the engine cool. If the fan comes on even at speed, something is not right. Could be airflow obstruction through the radiator: debris, bent fins, obstruction, etc. Could be insufficient water flow through the radiator: bad thermostat, bad water pump, obstruction in a radiator hose. Check your pressure cap. A broken cap can result in localized boiling that reduces coolant capacity to carry away heat. But failed pressure caps result in low coolant level as coolant pisses out to the overflow container. Something is not right with your cooling system. Further diagnosis is advised.
PostPosted: 07:54 - 22 Aug 2025    Post subject: Reply with quote
Agreed. I've had many water cooled motorbikes and the only time the fan ever comes on is either after prolonged, low speed riding in hot weather or after suddenly slowing right down or stopping after intense thrashing. The only time I've found the fan on while riding normally was when the head gasket blew on my GPZ500.
Texpis
PostPosted: 08:36 - 22 Aug 2025    Post subject: Reply with quote
I would have thought the same hence the post but, brand new radiator with new cap, water pump removed and checked like new, new thermostat and temp sender checked in boiling water. Rode it for an hour and half last might different speeds temp stayed rock steady which is the first time since I got the bike
Mick
jeffyjeff
PostPosted: 02:50 - 25 Aug 2025    Post subject: Reply with quote
I don't mean to belabor the point, and beg pardon if I come across as unrealistically stubborn about this (not my intention); but ask you to think about this for a moment. Your engine has to reach approximately 100 degrees C before the fan will turn on, and it is not cooling down enough to turn the fan off (normally around 93 degrees C). In a well-functioning cooling system, the radiator can reject enough heat for the thermostat to control the engine temperature within a range of around 82-92 degrees C.
Once your thermostat opens fully, it sends all the coolant to the radiator without restriction and can do nothing more to cool down your engine. Your thermostat is doing nothing to control your engine temperature. It has opened fully and is now a spectator in your cooling system as the temperature continues to climb until the radiator fan turns on and stays on. You may not be overheating your engine, mate, but you are constantly running it at the very upper reaches of its design limits. Something is not right. If your bike was mine, I would be looking at it again. All the best.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.26 Sec - Server Load: 2.76 - MySQL Queries: 13 - Page Size: 81.13 Kb
