Any linux geeks? Transferring home directory to new PC
PostPosted: 11:49 - 20 Aug 2025    Post subject: Any linux geeks? Transferring home directory to new PC Reply with quote
I've bought a new PC which has an SSD and HDD installed. I'm going to install LMDE.
My current PC has the linux install on an SSD and the home directory on a seperate HDD (which I bought fairly recently and is bigger and faster than the HDD in the new one).
There is a slot available for the old HDD. Is there a way of installing linux on the new PC but keeping all the data on the old HDD, just using that as the home directory? I'd use the one it came with as a scratch drive.
I'm not sure if I should do this at the point of partitioning the new install or if I should keep the old HDD to one side then do a switcheroo once the system's setup.
to v or not to v
PostPosted: 12:09 - 20 Aug 2025    Post subject: Reply with quote
Linux forums are a good place for info. i used to run the mint version and their support forum was excellent.
Moto Guzzi V7.
PostPosted: 14:01 - 20 Aug 2025    Post subject: Reply with quote
The way I'd approach it...
1) Get the new system up and running - logins, passwords, printer drivers, etc. - until you're happy the essentials work.
2) Add the old drive to the system and verify it's working, e.g.
List block devices: lsblk -o +partuuid
3) Take a look at your filesystem table
cat /etc/fstab
There's loads of ways to do things after that but it boils down to either editing fstab or seeing what the systemd approach is this week.
PostPosted: 18:23 - 20 Aug 2025    Post subject: Reply with quote
Thanks for that.That makes enough sense for me to have a crack at it. Swithcheroo it is.
PostPosted: 16:33 - 23 Aug 2025    Post subject: Reply with quote
cat /etc/fstab
Probably what I'd suggest, quickest cleanest way.
Old drives are always spares to me, the data is all I care about, would have it mount as a second disk and just do some symlinks to access it. But above is what I'd do at a standard level.
Jmoan
PostPosted: 14:37 - 09 Sep 2025    Post subject: Reply with quote
Shame it doesn't come with a proper manual built in, like most things to do with programs or games these days.
and no,man pages don't count.
blurredman
PostPosted: 09:02 - 22 Sep 2025    Post subject: Reply with quote
Gone are the days of proper manuals. Sad
https://i.ebayimg.com/images/g/Lf4AAOSwHpBlG3U1/s-l400.jpg
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 54.28 Kb
