Suzuki DR350 cam and sprockets...
Sigean
PostPosted: 10:59 - 21 Aug 2025    Post subject: Suzuki DR350 cam and sprockets... Reply with quote
I have a Suzuki DR350. It's a "FrankenSuzuki"... the frame is a 1997 model, the engine being from 1991. It has had many previous owners, most of them monkeys, so I am not working on a "clean sheet", and I have had to correct all of the old faults it had. However, it now starts well, "ticks over" like a Swiss watch, will rev to around 5000rpm, but beyond that the engine falters and loses power.
I have changed all the electrical equipment for new items (coil and plug lead, stator, ignition trigger, CDI (I now use an Ignitech unit, a programmable version which allows connecion to a laptop to observe running conditions. This did not identify any problems with the ignition)). The carburettor is clean and jetted correctly - I have also tried larger main jets to see if this had any beneficial effect. It didn't.
Having addressed all obvious possible causes for the running problem, I am now looking elsewhere for a solution. One aspect of the engine I have been unable to check is the camshaft and cam sprocket. I note from the DR350 parts list that there are two types of camshaft:
- part numbers 12711-14D01, 12710-14D70 for models L,M,N,P and R,S,T respectively,
and two types of sprocket:
- 12741-26B00, 12741-14D50 (for LMNP and RST, respectively)
Given the different part numbers for these components I guess they might not be interchangeable. A mismatch might create the engine problem I experience, possibly by altering the valve timing?
Does anyone out there on planet DR350 know how I might identify the sprocket and cam? Are there any obvious markings I should look for?
Any thoughts would be welcome...
Kind regards, Sigean
PostPosted: 18:34 - 27 Aug 2025    Post subject: Reply with quote
Quite niche - try thumpertalk forum..
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.88 - MySQL Queries: 16 - Page Size: 33.1 Kb
