Mobile signal boosters… worth it?
CrypticCrud
PostPosted: 23:44 - 15 Nov 2025    Post subject: Mobile signal boosters… worth it? Reply with quote
We live in a dip on the outskirts of nowhere and all networks have terrible signal / speeds.
I’ve been looking at purchasing one of those kits you stick a receiver up high outside & a box on the inside? Booster kit presumably?
I’ve seen prices vary between £2-400 but am unsure what to look for.
Does anyone have knowledge / advice please?
TIA
DISCLAIMER advice may or may not be taken!
CBT - Aug24, Theory - Jun25, Mod 1 - Jul25, Mod 2 - Sep25
Kawasaki Z125 > Honda Z125 > GSX-R600 Y
panrider_uk
PostPosted: 01:05 - 16 Nov 2025    Post subject: Reply with quote
Can't you use wifi calling?
CrypticCrud
PostPosted: 02:02 - 16 Nov 2025    Post subject: Reply with quote
I could if i had broadband!
PostPosted: 10:48 - 16 Nov 2025    Post subject: Reply with quote
I did experiment with a mobile router at one point. Basically a wireless router you put a sim card in. It then provided a wifi network in the house and you could plug normal DECT phones into it which make and receive calls like a normal house phone using the mobile number.
My reasoning was that I also have very patchy mobile reception in my house (it gets one network downstairs and a different one upstairs) but I could locate the router where it got a good signal.
It was really an experiment to see if I could do away with the fairly expensive landline/broadband and just use mobile internet and calling instead. It worked fine but the 4G speeds were intermittant, prone to cutting out and even at best not as fast as the wired broadband.
Also, despite it always having a good signal strength, you couldn't always get a call in or out, the connection would keep dropping while still showing 4 bars of signal. This was pretty much the same as with the mobile phone itself. I concluded that even with a good signal, there clearly isn't enough bandwidth on the mobile mast it's connecting to to reliably get internet and make phone calls. As such, in my location, a mobile phone is effectively useless as a reliable means of communication. I will need to come up with some solution when the landlines eventually get cut off, probably going to be a VOIP phone.
Obviously, this isn't exactly what you want because the SIM is in the router meaning you can't take it away with you (although you might be able to get an extra SIm for cheap from some providers?). Just a different take on the tech and a warning that in poor coverage areas, even if you do get a signal, it's no garauntee you'll be able to actually make phone calls.
PostPosted: 17:04 - 16 Nov 2025    Post subject: Reply with quote
I was at Waterloo station the other day and had almost max 5G bars on my phone, still couldn't get on the Internet reliably Sad It seems you need a good signal and a mast that isn't overloaded.
sickpup
Old Timer
PostPosted: 19:09 - 16 Nov 2025    Post subject: Re: Mobile signal boosters… worth it? Reply with quote
TIA
May not be legal to do.
Most boosters are actually rebroadcast units and need OFCOM approval.
This is a minefield complete with absolutely huge financial penalties if you get things wrong.
PostPosted: 19:22 - 16 Nov 2025    Post subject: Reply with quote
Lousy mobile signal and no broadband to the property?
Satellite internet is the answer you're looking for.
CrypticCrud
PostPosted: 22:38 - 16 Nov 2025    Post subject: Reply with quote
We can get broadband I just choose not to pay for something that I’ll barely use.
I’m not sure why when you can buy the kits legally.
https://www.mobile-signal-boosters.shop/repeater-35/
PostPosted: 01:24 - 17 Nov 2025    Post subject: Reply with quote
"The Nikrans LCD-130 is a GSM mobile booster, designed to enhance signal strength and improve call quality. Operating at a standard 900 MHz frequency"
Thinking
https://www.myamplifiers.com/gsm-repeater/
Seems to be more suitable.
sickpup
Old Timer
PostPosted: 02:06 - 17 Nov 2025    Post subject: Reply with quote
Because the kit isn't illegal to own, it is often illegal to use.
Bad website example, they're not in the UK.
Feasty
PostPosted: 09:38 - 17 Nov 2025    Post subject: Reply with quote
It's all a shit-show. I didn't realise this until very recently, so mobile providers can literally lie to our faces...
Network configuration: Many phones will display the 5G icon when they are connected to an older 4G network that is supporting a 5G signal (called non-standalone or NSA 5G). Your phone may connect to this "5G" icon even if it's not using the faster 5G data streams.
Availability of 5G infrastructure: True, high-speed 5G requires a dense network of towers, which is not yet widespread. Even in cities, coverage is often patchy.
Automatic network switching: Your phone automatically connects to the fastest available network. If a fast 5G connection isn't available, it may seamlessly drop to a 4G connection, even if the 5G symbol is still visible.
Marketing perception: The 5G icon can be a way for service providers to create the perception of a 5G connection, especially when the actual speeds are not yet matching the advertised potential.
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
CrypticCrud
PostPosted: 10:51 - 17 Nov 2025    Post subject: Reply with quote
https://mobilesignalsolutions.co.uk/ in Chelmsford.
CrypticCrud
PostPosted: 10:53 - 17 Nov 2025    Post subject: Reply with quote
Might help the whole building
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.02 - MySQL Queries: 16 - Page Size: 85.97 Kb
