CB400 1994 clocks
Texpis
PostPosted: 18:36 - 01 Dec 2025    Post subject: CB400 1994 clocks Reply with quote
Hi all I have bought a 1994 Honda cb I believe a cb 1. It’s been renovate and looks lovely. The problem I have is the speedo is damaged and looks like it’s a cheap Chinese copy it has a red lettering on a black background. Is there a decent aftermarket clock set i have been looking at these
https://www.ebay.co.uk/itm/146976573450
Annoyingly these look the same
https://www.aliexpress.com/item/32918584698.html?spm=a2g0o.productlist.main.2.347bTVAKTVAKOP&algo_pvid=c8609fba-43cf-47db-b0de-2450cc4f17ad&algo_exp_id=c8609fba-43cf-47db-b0de-2450cc4f17ad-1&pdp_ext_f=%7B%22order%22%3A%225%22%2C%22eval%22%3A%221%22%2C%22fromPage%22%3A%22search%22%7D&pdp_npi=6%40dis%21GBP%2149.53%2139.77%21%21%21449.90%21361.25%21%40211b430817646105892758029ea6a3%2166022581545%21sea%21UK%210%21ABX%211%210%21n_tag%3A-29910%3Bd%3A6982dd80%3Bm03_new_user%3A-29895%3BpisId%3A5000000187682296&curPageLogUid=IOslrnuMttaq&utparam-url=scene%3Asearch%7Cquery_from%3A%7Cx_object_id%3A32918584698%7C_p_origin_prod%3A
These are mine
PostPosted: 21:30 - 01 Dec 2025    Post subject: Reply with quote
The red on black looks OEM to me. The black on white is the Chinese knock off.
Texpis
PostPosted: 22:00 - 01 Dec 2025    Post subject: Reply with quote
I wonder if they are the original clocks in a cheap housing the kpm reading is right according to to its mots over the past 10 years. Is the original housing metal?
PostPosted: 23:14 - 01 Dec 2025    Post subject: Reply with quote
CB1's I think were only made until about 1992, what you have is more likely to be a CB400 Superfour. A pic of the bike might go a long way to helping.
It does look like the standard bike has a chrome bezel but I've not found many pictures to confirm.
Texpis
PostPosted: 23:19 - 01 Dec 2025    Post subject: Reply with quote
Ha yea I could be wrong very new to bikes here’s a pic. That’s when it was at the dealers
PostPosted: 23:26 - 01 Dec 2025    Post subject: Reply with quote
It’s a super four which has chrome bezels around the clocks
Texpis
PostPosted: 23:33 - 01 Dec 2025    Post subject: Reply with quote
So are the originals cheep thin plastic or chromed metal? It may be the original if it is great.
PostPosted: 10:52 - 02 Dec 2025    Post subject: Reply with quote
Chromed Metal? On a 90s Japanese bike? No chance. I'm sure it'll be plastic.
PostPosted: 11:35 - 02 Dec 2025    Post subject: Reply with quote
By the way, a Superfour is a great bike. It looks cool, has an absolutely bulletproof engine and should ride really nicely, be quite comfortable and be a great all round bike. Congratulations sir! Yellow as well, not many of them about. You've done very well indeed.
Texpis
PostPosted: 21:25 - 02 Dec 2025    Post subject: Reply with quote
Thanks marjay my first big bike I was out on the bike today great fun
PostPosted: 08:53 - 08 Dec 2025    Post subject: Reply with quote
Worth noting the clocks in these housed the speed limiter too, id probably not touch them. Cuts at 180kmh, not that you'll see it much but thats where many derestrictions happen.
Texpis
PostPosted: 20:20 - 14 Dec 2025    Post subject: Reply with quote
Hi all thanks for all the replies 2 small problems remain any help would be great
The clocks have 3 leds 1 for the kickstand, 1 for oil light one for water temp.
The kickstand light now works
The water temp it looks like the sender is an analogue sensor for a bike with a water temp guage. But I don’t seem to be able to find a water temp switch for the light( not the radiator fan switch) any ideas?
The oil pressure switch I guess should be on when engine not running and go of when the pressure rises but I can’t find the oil p switch is it hidden away somewhere?
Frog
PostPosted: 13:02 - 21 Dec 2025    Post subject: Reply with quote
Probably won't help very much but just in case... I'm very much not a mechanic, but have a CB400 (roughly 92 as far as I can tell, but not entirely sure as it was imported).
It has the three lights on the clocks, and the only temperature switch I've known on it is a thermostat in the rad. The bike did have some modifications before it got to me - notably I have an on-off switch on the bars for the fan rather than anything automatic which may or may not be original - so can't be 100% there isn't another sensor which was there and now isn't.
Pic is left-hand side of the bike, but thermostat isn't original.
HTH Thumbs Up
CBT 23/09/10 - Theory 19/03/11 - Mod1 19/04/11 - Mod2 06/05/11
Bikes: CBF125 (sold 30/10/10-25/09/12) - CB400 24/06/11 (broken) Sad - ER6-f 25/09/2012 Very Happy
PostPosted: 20:53 - 21 Dec 2025    Post subject: Reply with quote
Frog wrote:
stuff..
Welcome back - how've you been?
Texpis
PostPosted: 12:10 - 24 Dec 2025    Post subject: Reply with quote
Hi frog thanks for the reply mine has a Seder in the radiator but mine switches the fan on. The other sender is under the tank in the thermostat Housing.
To put this to bed With what I found. My clocks I believe are original but the housing is from china this housing comes with the three led lights water, oil and kickstand and includes the electronic to switch them on( basically a resistor to lower the voltage)
The two electronic boards I have the wiring does not correspond the the wiring on the bike.
I got the kickstand and the oil light to work by rewriting the plug.
The water temp sender as far as I can assert is the correct one (tried a couple of suppliers and they only had the analog one for my year of bike ) I believe the original electronics had a circuit to switch the light whe a certain voltage come from the sender, this circuit is missing from the Chinese board.
I could have fitted an aftermarket switch for the light but I decided a preferred a gauge so that’s what I fitted probably not to everyone’s taste.
Frog
PostPosted: 15:03 - 31 Dec 2025    Post subject: Reply with quote
A100man wrote:
Frog wrote:
stuff..
Good thanks... you're right it's been a while though. Too much work and not enough riding Sad
lingeringstin...
PostPosted: 04:04 - 29 Jan 2026    Post subject: Reply with quote
I found out years ago that a speed was not an MOT item. It's "un-testable" at MOT time so I don't even have one now. I just use a phone as a satnav and it has a speedo built in.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.53 - MySQL Queries: 16 - Page Size: 99.95 Kb
