Changing rear wheel vexation
Mr Hammers
PostPosted: 00:55 - 15 Dec 2025    Post subject: Changing rear wheel vexation Reply with quote
Changed the rear tyre on the Triple today. Puncture at 4.6k, so at least it was near the end of its life and not the start. Tried repairing several times, but that's another post. Anyway, it was lot easier now that a) now i can bolt the tyre changer directly to the workshop floor, and b) i finally bought a bead seater.
https://i.imgur.com/R6IDVmi.jpg
Until now, i've been bolting it to a paving slab which wasn't ideal, and as i didn't want studs sticking out of the floor when not using it, i used drop in anchors so it's all flush.
And the bead seater, wow. What a tool! And by that i mean me for taking this long to get one. Firing out 9 litres of air in an instant going at 700mph is surprisingly violent and very much fun. I made sure i got the button press type too, not the handle, as it's more efficient and, it feels more like a gun Smile
https://i.imgur.com/C4GkTKt.jpg
So while all that was easy and quick, what was a lot harder was getting the bloody wheel back on again. Man. I just couldn't get it between the swingarm and caliper without that sodding bush falling out, trying to line it up with the brake bracket. Getting darker and harder to see all the time which didn't help. It's never been this difficult before, usually it's a bit of a pain, but this was so much longer. With an embarrasing amount of swearing and the kind help of the lodger i managed to sort it in the end, but i can't help thinking there's got to be a trick to this that i'm missing.
https://i.imgur.com/bNTKXCK.jpg
So, any tips?
A Guide To Powerbands
mentalboy
PostPosted: 01:43 - 15 Dec 2025    Post subject: Reply with quote
Lag it up with grease and find a friend/lodger to help, even a small child would suffice.
Make mine a Corona.
PostPosted: 14:52 - 15 Dec 2025    Post subject: Reply with quote
As above, stick it on with grease. aka "engineers glue".
Kawasaki Jimbo
PostPosted: 18:58 - 15 Dec 2025    Post subject: Reply with quote
Imgur says “Content not viewable in your region.” (East of England.)
to v or not to v
PostPosted: 19:25 - 15 Dec 2025    Post subject: Reply with quote
its to protect the children.
Moto Guzzi V7.
PostPosted: 20:31 - 15 Dec 2025    Post subject: Reply with quote
Same - perhaps its just us brussel pickers they don't like.
Mr Hammers
PostPosted: 14:45 - 16 Dec 2025    Post subject: Reply with quote
Good point, and i'll be honest i didn't drench it in grease as much as i usually do. That said, it was still a very tight fit and it still would've been quite tricky, but yeah, shoulda done that.
I was sort of half hoping that someone would say something like 'ahh you want one of these' and point to some clever bit of kit. Smile
Not sure why imgur are saying it's not viewable..? Haven't done anything different to what i usually do, and there are no settings to restrict it as far as i can see. I did read something recently about Imgur having an issue with that new pos online safety bill, maybe something to do with that..?
andys675
PostPosted: 15:03 - 16 Dec 2025    Post subject: Reply with quote
I feel your pain I've been there with street triples
I can't remember exactly what the solution was but it did involve:-
removing the rear caliper from the hanger, put the caliper back on after the wheel is in
and use a plank under the wheel to raise it up into position
hope this helps
to v or not to v
PostPosted: 20:38 - 16 Dec 2025    Post subject: Reply with quote
Imgur simply blocked the UK rather than comply with the ridiculous "protect the children" id laws.
Moto Guzzi V7.
Mr Hammers
PostPosted: 14:08 - 18 Dec 2025    Post subject: Reply with quote
Think i should've done this...but as it was getting darker every minute i didn't want to start taking bits off in the dark. But next time, i think i will! Cheers! Smile
Yeah, that's what i thought, but was a bit confused why it seemed to work at all, if not quite for everyone.
The only good thing about that law is that i've found running a vpn through Albania means no ads! Laughing
lingeringstin...
PostPosted: 01:02 - 12 Feb 2026    Post subject: Reply with quote
I know this is after the fact but a mate of mine used to wrap a ratchet strap around the tyre and squeeze the tyre onto the rim so it beaded and then shoot enough air into it to keep it on the rim and remove the ratchet strap for final inflation.
Back when I worked fixing truck tyres from a van at the roadside we used to spray the inside of the tyre with a liberal dose of carb cleaner and then quickly spray a little trail of it on the ground leading about two feet away from the tyre and then put a lighter to it.
Boom! The tyre would instantly inflate, sometimes leaping off the ground a bit and then we'd hit it up with the air hose from the air tank before the tyre could cool enough to unbead itself again.
Truck tyres usually had around a hundred PSI so our air tank was pretty vicious, fed by an air conditioner pump as we drove so we always had insane air pressure in the tank.
Health and safety be damned.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 72.13 Kb
