Aprilia RS125 Rotax 122 balancer Shaft Timing/Markings
supra3turbo
PostPosted: 18:48 - 01 Jan 2026    Post subject: Aprilia RS125 Rotax 122 balancer Shaft Timing/Markings Reply with quote
Hi All,
I am getting this spare engine back together, and the book says one thing, and ive seen people online do it differently, which is the correct way?
I have noticed in the manual it says to align the marks on the ends of the crank shaft and the balancer shaft exactly (1) with each other, but this engine was assembled with just the outer gear teeth markings (2) aligning, which one is correct? The haynes manual shows to align both shaft end marks (1) exactly, but if i do that, the teeth markings (2) dont align at all, and the manual makes no mention of the outer gear teeth markings. Do i align the shaft markings, or the teeth markings.
Thanks - joe
Hoda CBR 600 FX stolen from stalybridge 2017/2018 black
Current Project Suzuki RG125 Cafe Racer
jaffa90
PostPosted: 22:39 - 01 Jan 2026    Post subject: Reply with quote
https://www.youtube.com/watch?v=U4md9VkpAKk&t=2242s
Is this yours? This has markings on both shafts and both inner parts of the plastic gears, then you line up the outer parts of both plastic gears.
supra3turbo
PostPosted: 00:44 - 02 Jan 2026    Post subject: Reply with quote
Yeah this is one of the videos I've seen, but why would the Haynes manual only tell you to line up the marks on the shafts and have them pointed to eachother? If I do that the teeth markings don't line up, it's strange but ill just line the markings on the teeth up as it was assembled, strange the Haynes manual doesn't mention these markings, only the ones on the ends of the shafts
jaffa90
PostPosted: 01:14 - 02 Jan 2026    Post subject: Reply with quote
This pic may help as well.
jeffyjeff
PostPosted: 07:06 - 02 Jan 2026    Post subject: Reply with quote
Are the gears are indexed to the shafts so that they only fit in one position? There may be a missing or dissimilar spline on the shaft and the gear that allow the gear to mate with the shaft in only one orientation. If that be the case, I would be inclined to trust the gear marks as I assemble the engine.
If the gears are not indexed to the shafts, then the orientation of the gear marks in relation to crank position is totally random. Your photograph appears to show 16 teeth on the splined shaft (secured by the snap ring). That suggests the gear can go on the shaft 16 different ways, only one is the correct position. If that indeed be the case, I would be inclined to prioritize the marks on the shafts.
Bottom line is that when the crankshaft is turned to position the piston at top-dead-center (the uppermost of it's vertical travel) you must be able to orient the camshaft so that the tappets ride on the base of the camshaft (not the nose of either cam). That would be the point where you can set the valve lash, and that is the point where your timing marks should align.
jaffa90
PostPosted: 10:06 - 02 Jan 2026    Post subject: Reply with quote
jeffyjeff, it`s coming up as a 2 stroke engine not 4.
supra3turbo
PostPosted: 14:24 - 02 Jan 2026    Post subject: Reply with quote
Hi all,
I've had it confirmed, you line the gears up on the shafts then line the teeth marks up together, odd that Haynes don't show that but apparently that's correct.
Thanks for the help Smile
jeffyjeff
PostPosted: 18:14 - 02 Jan 2026    Post subject: Reply with quote
Doh!
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 56.01 Kb
