Melted cargo net on exhaust.
Kawasaki Jimbo
PostPosted: 14:21 - 10 Jan 2026    Post subject: Melted cargo net on exhaust. Reply with quote
I’ve melted a cargo net on the OE end can of my 2003 (5PW) Yamaha R1. I hoped it would eventually burn itself off over time but it hasn’t, and I don’t want to scratch the can by scrubbing it. I think the can is titanium but not sure. Neither WD40 nor nail polish remover (acetone in water) cleaned it. Any recommendations? It can’t be the first time this has happened.
https://i.postimg.cc/bwtQw3Hb/IMG_1922.jpg
PostPosted: 16:27 - 10 Jan 2026    Post subject: Reply with quote
Well, if it's a titanium oxide coating, there isn't much solvent-wise that's going to upset it. I'd have thought your acetone would have been the best bet though. How dilute is the nail polish remover?
Carb/contact cleaner for a more volatile solvent. Petrol? Isopropyl aclohol? MEK if you can get it?
Assuming it's titanium oxide, it should be really resistant to even very strong caustic, but I'd try it on a hidden area first.
PostPosted: 17:49 - 10 Jan 2026    Post subject: Reply with quote
Brake cleaner is usually my first port of call with stuff like that. Obviously DO NOT do it when the exhaust is hot, or you might die. Really, it creates phosgene gas if you heat it above something like 300 degrees.
But, it does evaporate quickly, and does clean most anything that can be cleaned.
Islander
PostPosted: 18:29 - 10 Jan 2026    Post subject: Reply with quote
You can buy 100% acetone from Amazon or eBay which should remove it easily.
VFR1200rider
PostPosted: 22:58 - 10 Jan 2026    Post subject: Reply with quote
White spirit?
PostPosted: 00:39 - 11 Jan 2026    Post subject: Reply with quote
The other thing about titanium oxide is it's extremely hard. I doubt a green scotchbrite would mark it. Again, try on an inconspicuious part first.
Kawasaki Jimbo
PostPosted: 19:38 - 12 Jan 2026    Post subject: Reply with quote
I got myself a small bottle of 100% acetone from a pharmacy but it didn’t seem to have much effect. I might have to rub a bit harder before trying the other suggestions. I will update. Thanks.
(Oh, and my mistake, it wasn’t a cargo net, it’s an ‘Oxford Blanket’ rubber mesh used to protect the bodywork from luggage.)
PostPosted: 21:48 - 12 Jan 2026    Post subject: Reply with quote
If it's rubber, you could try some vulcanising solution to soften it. The stuff in the little tubes you get in puncture repair kits. It kind of melts the surface of the rubber then bonds it to other bits of rubber. You'd need to be quick with it though.
Suntan Sid
PostPosted: 20:06 - 13 Jan 2026    Post subject: Reply with quote
This is not a wind up!
If all else fails try some full strength "Jungle Formula" insect repellent.
Try not to get it on any plastic, ie. the indicator in the photo.
Kawasaki Jimbo
PostPosted: 20:38 - 13 Jan 2026    Post subject: Reply with quote
It does make sense!
https://rainbowtech.net/wp-content/uploads/4508-Jungle-Formula-Insect-Repellent-SDS.pdf
Google says,
N,N-diethyl-meta-toluamide (DEET) is a solvent that can damage certain types of rubber, plastic, and synthetic materials. It works as a plasticizer, meaning it can soften, swell, or craze these materials upon contact.
A last resort perhaps, used with great care! Good one, thanks.
Kawasaki Jimbo
PostPosted: 18:04 - 17 Jan 2026    Post subject: Reply with quote
Solvents I’ve tried -
Acetone
WD40
Isopropanol
Contact cleaner
Brake cleaner
Carb cleaner
Isopropanol
HG Sticker Remover.
-each applied with an old face flannel and rubbed, so there was some light abrasion applied too. No scratches.
Rubber glue should also be in that list, rubbed on with a finger, left for a minute or two and then wiped off before it dried.
I also tried ‘bikini-waxing’ it with duct tape, which did pull a bit of rubber off.
Nothing seemed to be doing the trick in isolation but when I finished and put a light on it I could see it was better than the patch I hadn’t touched. I think I need to spend more time on it. Tomorrow I’ll try Jungle Formula if I can get it.
https://i.postimg.cc/7YmHSFP2/IMG_2151.jpg
Kawasaki Jimbo
PostPosted: 20:59 - 20 Jan 2026    Post subject: Reply with quote
Jungle Formula alone had no noticeable effect but now I know the titanium can isn’t harmed by any of these solvents I think a concoction, a soaking and a scrub will do it. I actually work in a chemistry lab but that doesn’t mean I can help myself to materials, more’s the pity.
PostPosted: 08:26 - 21 Jan 2026    Post subject: Reply with quote
Not even a tiny whiff of carbon tetrachloride? Because that would be my goto "I really mean it" solvent. If I could get it. Or dichloromethane (nitromorse when it actually worked).
Kawasaki Jimbo
PostPosted: 21:55 - 21 Jan 2026    Post subject: Reply with quote
Back in the day my old boss thought his company car was running rough and could have water in the fuel, so he helped himself to a Winchester of methanol and emptied it into the tank. The story goes that it went like a bomb for a short while and then he needed a new car.
Even we don’t use carbon tet these days. DCM though, yes I probably could. It looks like you can even buy it online,
https://plasticonline.co.uk/dichloromethane.html
PostPosted: 21:58 - 21 Jan 2026    Post subject: Reply with quote
You'd almost certainly have to provide them with proof you are an industrial user before they'll ship it. At least that's how it goes with the paint stripper
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 89.24 Kb
