C110 where does the 2mm o ring fit ?
Bossboy
PostPosted: 15:40 - 22 Jan 2026    Post subject: C110 where does the 2mm o ring fit ? Reply with quote
Hi All,
gettint there slowly
Have assembled clutch cam, lifter and ball retainer.
My problem now is, i obtained a new 4.3 mm o ring from john oldfield spares, i now ask , where doe it go
No 18 on csmnl drawing
would appreciate advice, its small, i am puzzled
PostPosted: 21:43 - 22 Jan 2026    Post subject: Reply with quote
Again, mostly guesswork and looking at pictures but it looks like there is a countersunk recess on the inside face of the clutch lifter plate (17) which I'm guessing is where that o-ring goes. I'd imagine the clutch screw (11) goes down through the middle of all the clutch lifter parts and protrudes slightly with the o-ring over the end of it.
See if that all fits. It's where it's shown on the exploded diagram so if it fits neatly in the recess on the clutch lifter plate and over the plain end of the clutch screw, I'd say it's a shoe-in.
Bossboy
PostPosted: 18:26 - 23 Jan 2026    Post subject: Reply with quote
will certainlt try, many thanks
Bossboy
PostPosted: 17:29 - 24 Jan 2026    Post subject: Reply with quote
Hello,
Tried it, no go, justdoes not fit anywhere, i am truly puzzled now.
yes, there is a countersunk recess on the clutch lifter plate, this is where, what is known as the clutch pin, these were fitted to later models sits as in photo
I am temted to forget it and just assemble it and see what happens
Trouble is, there is no informative info out there apart from people like yourself trying to help
I did contact honda but they were no help at all, i explained i was restoring the bike, i thought hey would have been glad to help
I might out of interest contact Japan, see what they say
Thank you
PostPosted: 18:51 - 24 Jan 2026    Post subject: Reply with quote
I think its function is to stop oil creeping along the threads between the clutch lifter plate and the clutch screw and finding its way to the outside of the bike along that screw. Pic below of the recess in the lifter plate I'd guess it goes in.
If you don't have one, it can't happen and you don't need it.
Bossboy
PostPosted: 18:47 - 31 Jan 2026    Post subject: Reply with quote
sorry for late reply
Yes, i think you are probably right in what you say
Wow, its been a nightmare the clutch, not much info out thee as you know
I might be back for further help, i so want to get it running and be able to change gear.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 16 - Page Size: 52.67 Kb
