Small bike with a remote reservoir front master cylinder?
PostPosted: 12:04 - 25 Jan 2026    Post subject: Small bike with a remote reservoir front master cylinder? Reply with quote
I'm looking to replace the front m/c on my Enfield bullet special. The tuono one I have displaces too much volume for a single calliper making the lever action very stiff. I'm also thinkig it would do a great job on the 6-pots on my VFR.
Looking for a bike with a single disc up front (or dinky little brakes) and a master cylinder with a remote reservoir so I can find one at a breakers.
Has to be a remote because there is a fair bit of other stuff to cram onto the handlebars, there isn't really room for a built-in reservoir.
PostPosted: 22:45 - 05 Feb 2026    Post subject: Reply with quote
Aprilia RS125 seems to be a decent bet... but whether or not you'll find one, maybe an RSV4 125?
PostPosted: 00:36 - 06 Feb 2026    Post subject: Reply with quote
I found an RS125 one after trawling through ebay used master cylinders looking at pictures. It's a bit shonky but it was also cheap. I'm pretty sure those brembo ones take a generic brembo seal kit.
It was cheap enough that I can check if it fits and if it's too far gone, I can get a better one and it was worth the price for the spare lever.
PostPosted: 14:46 - 16 Feb 2026    Post subject: Reply with quote
I'd thought it was a brembo, turns out it's a grimeca. Anyway, good deal, £15 for the complete master cylinder and lever with a clutch lever and perch included too. A bit tatty on the outside but like new inside. It'll cklean up. Same again for a seal kit and £4.99 for a reservoir.
Works way better, there's some travel on the lever now.
Also put the tuono one I did have fitted to my VFR, not road tested because it's due an MOT but the lever travel and feel is great compared to the OE master cylinder I was using (designed for 2-pot sliders, it was still like hitting an unlit skip but you had to go closer to the bars than was ideal to get there).
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.4 - MySQL Queries: 13 - Page Size: 41.2 Kb
