feckn mice!
to v or not to v
PostPosted: 15:05 - 28 Mar 2026    Post subject: feckn mice! Reply with quote
mice have been using my bike during the winter. found a load of nuts under the seat. at least one wire has been chewed through and now the bike wont start.
i know next to nothing about electrics so i guess im going to have to get someone else to fix this problem.
who should i use, dealer, local garage, vehicle tech, any suggestions?
im gutted to say the least.
Moto Guzzi V7.
jaffa90
PostPosted: 15:20 - 28 Mar 2026    Post subject: Reply with quote
I suggest an auto electrician, also send the bill to whoever is feeding the birds.
to v or not to v
PostPosted: 15:40 - 28 Mar 2026    Post subject: Reply with quote
that would be me!
Moto Guzzi V7.
PostPosted: 15:51 - 28 Mar 2026    Post subject: Reply with quote
Firstly I'd dab a bit of solder on the break or bridge it in some way to see if that is the only reason for the bike not starting
If so, the repair is pretty straightforward
you need to open the connector and find the type, it looks lika a pin/barrel, but I may be wrong it may be a flat pin type.
Whatever, get a new pin/barrel crimp on male of female connector,
crimp it on to 100mm of suitably rated cable cut back the tape to give yourself room to patch it in and solder/sleeve it in and re wrap
When you get details if the pin/barrel thingummy jig in question, get the pics/dimensions and go from there
the bike and a wiring diagram might help
I see a solid orange wire on my monitor, if that's correct my yamaha diagrams suggest it's the cable beween one bank of coils and the ignition control unit
to v or not to v
PostPosted: 18:38 - 28 Mar 2026    Post subject: Reply with quote
thanks for the advice, but ive never used a soldering iron in my life. would probably do more harm than good.
yes its a solid orange wire. i believe the part it goes into is where you plug the diagnostics tool to update the ECU.
Moto Guzzi V7.
jeffyjeff
PostPosted: 21:01 - 28 Mar 2026    Post subject: Reply with quote
Mice look like they have been eating well! There is something about wiring insulation that mice find appetizing. I keep my bike in a garage that is bordered by an open field, and I've seen mice droppings occasionally on the garage shelves. I set out two tuna tins with mice bait pellets, and the evidence of mouse activity has decreased significantly. Except one time I came back after a 4-month trip to California and all of the mouse bait had been eaten (but no other evidence of infestation at all!)
Raffles
PostPosted: 22:20 - 28 Mar 2026    Post subject: Reply with quote
What a pity that you didn't post a few hours earlier as I was in Southampton this morning and could have popped round and taken a look.
Anyways, electrics aren't that mysterious/complicated and WD Forte has given mostly good advice.
If you unwrap the loom tape and unwind the orange wire from the others then you will probably gain enough slack wire to not have to patch a piece of wire in.
Make a start on it (following WD's advice) and if/when things get tricky, come back to us.
If you employ the services of a sparky then it will cost you a few pretty pennies, especially so if he has to come to you.
to v or not to v
PostPosted: 06:09 - 29 Mar 2026    Post subject: Reply with quote
Sods law Rolling Eyes
Moto Guzzi V7.
PostPosted: 12:05 - 29 Mar 2026    Post subject: Reply with quote
Maybe have a ring round the bike and car garages, see if anyone wants to drop by on their way home and earn some beer money.
Kawasaki Jimbo
PostPosted: 12:57 - 29 Mar 2026    Post subject: Reply with quote
to v or not to v wrote:
I believe the part it goes into is where you plug the diagnostics tool to update the ECU.
I think it is the OBD but aren’t those connectors usually a dead end (capped but not live) until a diagnostic tool is connected?
This is on the Moto Guzzi V7, right? Have a look at the 8th post on this thread - https://www.guzzisti.de/forum/topic/6830-usb-steckdose-f%C3%BCr-v7-850-stone-centerario/
to v or not to v
PostPosted: 13:04 - 29 Mar 2026    Post subject: Reply with quote
its the OBD so i guess its dead?
yes its the Guzzi.
i think im going to have to take the side panels off and look for further damage.
Moto Guzzi V7.
to v or not to v
PostPosted: 13:31 - 29 Mar 2026    Post subject: Reply with quote
thank you for pointing out that its a dead end connection Jimbo.
i just went out and tried the bike again. after flicking the kill switch a couple of times and then trying the start button a few times the bike fired up Thumbs Up
its not been started since September, which probably explains the initial reluctance.
today is a good day.
Moto Guzzi V7.
lingeringstin...
PostPosted: 20:01 - 06 Apr 2026    Post subject: Reply with quote
When I worked at a bike shop somebody brought in their VFR750 that wouldn't start after having been sat over the winter and we discovered a rather substantial nest had been built in the airbox.
to v or not to v
PostPosted: 20:52 - 06 Apr 2026    Post subject: Reply with quote
little feckers are still in the garage. not having any luck with the traps. Mad
Moto Guzzi V7.
jaffa90
PostPosted: 23:37 - 06 Apr 2026    Post subject: Reply with quote
I suggest not touching the traps or bait with bare hands, with mice / rats and mole traps i use nitrile gloves and rub the traps with soil.
PostPosted: 06:55 - 07 Apr 2026    Post subject: Reply with quote
I'm a dab hand at setting mouse traps but Mrs stinkwheel said she wanted to use live catch traps so I got some of these: https://www.amazon.co.uk/dp/B0CP847PTB
No success initially but then I put nutella in them and they were practically queuing up.
to v or not to v
PostPosted: 09:07 - 14 Apr 2026    Post subject: Reply with quote
thanks for the tips Mr Stinkwheel.
the traps you linked and Nutella are working a treat. Thumbs Up
Moto Guzzi V7.
recman
PostPosted: 19:52 - 25 Apr 2026    Post subject: Reply with quote
You could always borrow my Border Terrier, he chomped his way through a nest of the little bastards at the bottom of our garden a couple of weeks ago.
to v or not to v
PostPosted: 09:52 - 26 Apr 2026    Post subject: Reply with quote
got the wires back together. is there a simple way to test the connection to make sure that its working?
Moto Guzzi V7.
blurredman
PostPosted: 07:13 - 27 Apr 2026    Post subject: Reply with quote
Plug it in and start it?
Short of a multimeter Laughing
to v or not to v
PostPosted: 18:41 - 27 Apr 2026    Post subject: Reply with quote
i dont have anything to plug into it.
i do have a multimeter though, and no idea how to use it.
Moto Guzzi V7.
blurredman
PostPosted: 06:52 - 28 Apr 2026    Post subject: Reply with quote
No I mean plug the plug back in ?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 117.13 Kb
