| Author |
| Bossboy |
 Bossboy Two Stroke Sniffer
| Back to top |
| MarJay |
 MarJay But it's British!
| Back to top |
| stinkwheel |
 Posted: 11:42 - 16 Apr 2026 Post subject: |
As above, they are a cradle frame like a C90 so it can go in from the bottom, a jack of some sort under it should be fine, once you have one bolt in, you can pivot and wiggle it about with the jack to get the others lined up.
Alternatively, you'd probably be able to take the front wheel out, sit the engine on a block and lower the frame down on top of the engine.
Or recruit a second pair of hands, one to lift and hold the engine, the other to get the first bolt through. I find attaching the kickstart greatly helps doing this, because you can use it as a handhold. The lifter stands astride the bike (take the seat off to make this easier) and lifts the engine right hand on the kickstart, left hand under the alternator cover or cylinder barrel. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| Bossboy |
 Posted: 18:45 - 16 Apr 2026 Post subject: |
| stinkwheel wrote: | As above, they are a cradle frame like a C90 so it can go in from the bottom, a jack of some sort under it should be fine, once you have one bolt in, you can pivot and wiggle it about with the jack to get the others lined up.
Or recruit a second pair of hands, one to lift and hold the engine, the other to get the first bolt through. I find attaching the kickstart greatly helps doing this, because you can use it as a handhold. The lifter stands astride the bike (take the seat off to make this easier) and lifts the engine right hand on the kickstart, left hand under the alternator cover or cylinder barrel. |
Job done, I used wooden packers to get the right height, went in like a dream, many thanks |
| Back to top |
| Bossboy |
 Posted: 18:47 - 16 Apr 2026 Post subject: |
| Back to top |
| Bossboy |
| Back to top |
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 51.18 Kb
