GN250 Scraping noise at idle after stator swap -Troubleshoot
bikebusy
PostPosted: 19:54 - 13 May 2026    Post subject: GN250 Scraping noise at idle after stator swap -Troubleshoot Reply with quote
Hi everyone,
I’m chasing a repetitive, mechanical scraping sound on my Suzuki GN250. The bike is silent when I hand-crank the engine with the spark plug out, but the noise returns once it’s running.
What I’ve done/checked so far:
    Stator: New unit installed. Continuity is good between all three yellow pins; no shorts to ground.
    Flywheel: Cleaned inside and out; no metal debris or "witness marks" found on the magnets or rotor.
    Gasket: Tried both 0.8mm and no gasket (dry fit). Hand-cranking was silent without a gasket, but the 0.8mm version didn't stop the noise at idle. the bike came with a much thinner gasket (paper like) but considering the replacement kit came with a thick gasket, I thought that was the way to go. I can't seem to find definitive information on gasket thickness.
    Clearance: Pickup coil and internal wiring look clear with no obvious scuffing. Stator bolts are tight (Loctited).
    Oil: Fresh oil and filter are clean—no new metal shavings.
    Starter Gears: The noise sounds loudest through a stethoscope at the center inspection cap. The idler gear is meshed with the starter clutch gear.
I've been using Gemini AI to troubleshoot the issue (which I acknowledge is not ideal) and it states that there could be a washer missing from the idle gear. However when I check the blowout diagram there is no washer present.
https://www.suzukipartshouse.com/oemparts/a/suz/50d3ed40f8700230d8b4b2df/starter-clutch
what I'm trying next is making a paper gasket to see if the difference in clearance will have an effect. if that doesn't solve it, I'll have to check her in with a mechanic as I'm at my wits end.
Thanks for any leads.
Suzuki GN250 2005
Kawasaki Jimbo
PostPosted: 22:58 - 14 May 2026    Post subject: Reply with quote
The AI also suggests loose starter clutch bolts or a failing starter clutch.
Off topic but I’m not sure searching the web and summarising the results should count as AI.
PostPosted: 19:44 - 15 May 2026    Post subject: Reply with quote
Spot on! Its a (very?) smart search engine but does no 'original thinking'. A handy tool but not much intelligent about it.
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 36.5 Kb
