Chinese CG engine clone horrid noise coming from.. The head?
Mony
PostPosted: 11:16 - 16 May 2026    Post subject: Chinese CG engine clone horrid noise coming from.. The head? Reply with quote
Hello, the noise seems to come from the valves and its so loud that it drowns out the engine noise. I replaced the entire head with one thats the same spec and i also replaced the rocker arm which did not really work at first becuse the little valve adjustment screws didnt have enough movement to be adjusted correctly, so i put 3 washers of the same size under the 3 rocker arm bolts underneath the rocker arm. I dont know if thats it or not?? I adjusted the valves to 0.10MM,and both cus i dont have a smaller feeler. Video of it attached thanks so much.
slowasyoulike
PostPosted: 21:12 - 17 May 2026    Post subject: Reply with quote
Why did you replace the head?
cresad
PostPosted: 19:36 - 18 May 2026    Post subject: Reply with quote
Sounds more like exhaust noise
Adam
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.3 - MySQL Queries: 14 - Page Size: 34.31 Kb
