Honda Vision Starter relay
Bleeter
PostPosted: 20:32 - 24 May 2026    Post subject: Honda Vision Starter relay Reply with quote
I have a Honda Vision 110 2019.
The bike struggles to start with ignition switch. When it eventually does start it runs fine. New battery installed. I suspect its the starter relay however I dont know which or where it is. There 2 in the fuse box, one small grey (4 pin) ,one larger black (5 pin). They both click on testing. The parts manual does not describe between the 2 relays. Maybe it is located somewhere else in the bike?
I'd appreciate some help identifying
Thanks
jaffa90
PostPosted: 08:43 - 25 May 2026    Post subject: Reply with quote
Google a starter relay switch for a pic, you should be able to check a relay switch with a screwdriver (google). Also check safety cut out switches like on side stand, brake switches. It may be a bad connection between the battery and the bike. A voltage reading at the starter motor may help when pressing the starter button.
Bleeter
PostPosted: 10:40 - 25 May 2026    Post subject: Reply with quote
I did some google hunting and it seems most likely that its the grey relay. I will start with replacing that one first.
I checked the safety switches, all seem ok. Battery connections are good. Cleaned the ground. Ignition switch has continuity.
PostPosted: 21:21 - 25 May 2026    Post subject: Reply with quote
Pretty sure that the Vision has an ACG
(combined starter and altermator)
so it may be a wee bit harder to debug than a conventional type as the ecu is involved as well
what mileage?
I used to have a manual/diagrams for the Vision but not sure I still have but will have a look later.
Bleeter
PostPosted: 14:08 - 26 May 2026    Post subject: Reply with quote
Problem seems to have been solved.
After putting the relays back in the power box and giving the ground wire a fiddle, it now starts first time again. If the problem comes back there is a connection issue somewhere.
Duh Embarassed
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 42.43 Kb
