| YPVSdreamer |
 YPVSdreamer L Plate Warrior
 Posted: 12:08 - 13 Jun 2026 Post subject: YPVS Valve not moving when at high revs |
Hi all,
my 1991 F2 model had just developed a new fault and lost midrange power. The power valve does not move when the bike is revved up to, and held at, 7000 rpm. The valve does the clean sweep when the igition is turned on, returning the valve pulley to the reference point. When the engine starts up nothing else happens. The cables are the correct way round.
The bike pulls hard and fast as soon as I get over 7500rpm, suggesting the valves are stuck in the open position.
Questions:-
As i understand it, the initial reference setting point (holes aligned), corresponds to the valves in the full open position. Is this correct? The exhausts are on with new gaskets and I am reluctant to remove them just to check.
Should the valve move to a closed position when the engine fires, so that low-speed running enjoys a closed exhaust port?
Does the valve move clockwise as the revs rise? To my mind, this seems opposite to the logic, unless the valve should move clockwise, to the closed position when the engine starts running, and then anti-clockwise once the revs rise. Can anyone explain the sequence, please.
Also, what does the group think the fault would be? Lack of signal from the CDI module?
Any help would be greatly appreciated. The summer is here and my bike is in the garage.
Cheers |
| MarJay |
 MarJay But it's British!
| MarJay |
| YPVSdreamer |
| MarJay |
| YPVSdreamer |
| MarJay |
 Posted: 06:49 - 15 Jun 2026 Post subject: |
Zeeltronic is the one everyone uses and it's REALLY good, but it does ideally need setting up to get the best from it. I think the defaults tend to be pretty decent though.
We are very lucky to have access to a quality replica of such a niche item, the people who make it are bona fide geniuses.
However, lots of people are quick to jump to the conclusion you've made about the PV controller. If it cycles OK on start up, then I can't see how it would fail at other times, but I can see how a wiring or earth connection could break down at temperature (i.e. when the engine is hot). You can go for a Zeeltronic, and it may well fix the problem but I'd ONLY be doing that if I had a surfeit of cash and a deficit of time to be honest. The Zeeltronic is cool, and when set up properly you can get a bit more out of even a stock YPVS engine with it but they aren't cheap.
https://www.zeeltronic.com/page/yamaha.php
https://www.mb-designs.co.uk/webshop/road-and-road-racing-bike-specific/yamaha-rd250lc-350lc-350ypvs/ignition/zeeeltronic-pcdi-10vt/ ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| YPVSdreamer |
 Posted: 18:10 - 15 Jun 2026 Post subject: |
Thank you again MarJay,
I agree, and I will be thoroughly investigating all possibilities. Checked the condition and output from the potentiometer in the solenoid unit today, and all is well there.
I am also slowly going through the entire loom to test all connections, replacing the fuse box, which is quite corroded, and which is an overdue bit of maintenance anyway, and you never know, when it all comes back together, it may have sorted it. Forever the optimist.
Zeeltronic does look good, and I have been quoted just under £300, including the programmer and postage. So at that price, it is very much the last resort.
Just to confirm - would you expect the PV pulley to move about 30 degrees clockwise as soon as the engine fires up? I have seen this in a YouTube video, and it would make sense in terms of PV position for low revs. My bike does not do this bit, or move as the revs grow. As stated before, it does the ignition on routine without fault. All very curious.
Thanks for the links. Appreciated. |
