YPVS Valve not moving when at high revs
YPVSdreamer
PostPosted: 12:08 - 13 Jun 2026    Post subject: YPVS Valve not moving when at high revs Reply with quote
Hi all,
my 1991 F2 model had just developed a new fault and lost midrange power. The power valve does not move when the bike is revved up to, and held at, 7000 rpm. The valve does the clean sweep when the igition is turned on, returning the valve pulley to the reference point. When the engine starts up nothing else happens. The cables are the correct way round.
The bike pulls hard and fast as soon as I get over 7500rpm, suggesting the valves are stuck in the open position.
Questions:-
As i understand it, the initial reference setting point (holes aligned), corresponds to the valves in the full open position. Is this correct? The exhausts are on with new gaskets and I am reluctant to remove them just to check.
Should the valve move to a closed position when the engine fires, so that low-speed running enjoys a closed exhaust port?
Does the valve move clockwise as the revs rise? To my mind, this seems opposite to the logic, unless the valve should move clockwise, to the closed position when the engine starts running, and then anti-clockwise once the revs rise. Can anyone explain the sequence, please.
Also, what does the group think the fault would be? Lack of signal from the CDI module?
Any help would be greatly appreciated. The summer is here and my bike is in the garage.
PostPosted: 12:45 - 13 Jun 2026    Post subject: Reply with quote
It's been a minute...
When I had one of these, the issue I thought was a dodgy YPVS valve was actually a bad earth that I solved with a pattern wiring loom. The symptoms weren't exactly the same though. Mine would open, it's just it would open when it decided to, not when I decided to, which meant the bike was like a bucking bronco to ride.
Have you removed and decoked the valve? Does it move smoothly? Have the YPVS cables become stuck or swapped maybe?
I can find a workshop manual on the internet quite easily but it's in French for some reason.
PostPosted: 12:52 - 13 Jun 2026    Post subject: Reply with quote
https://davestestsandarticles.weebly.com/uploads/4/8/4/5/4845046/yamahard350_fii_nii_ypvsmanualen.pdf
Try that, page 146 I believe.
YPVSdreamer
PostPosted: 13:01 - 13 Jun 2026    Post subject: Reply with quote
Thank you MarJay. I will check that out.
The cables are definitely the right way round, and the valves are clean able to move freely when the cables are slacked off.
I'm tending toward a poor or missing signal from the CDI unit. Not sure how to test this though.
Does anyone know how to do that? I have a multimeter, and that's about it.
PostPosted: 14:28 - 13 Jun 2026    Post subject: Reply with quote
First thing I'd do is take each multi way connector apart one by one and then check each pin to see if it's got good contact or is corroded.
YPVSdreamer
PostPosted: 12:48 - 14 Jun 2026    Post subject: Reply with quote
So, an update.
I have figured out that the CDI feeds the same signal to the tacho and the YPVS control unit. The tacho is working just fine, and the grey line between the tacho and the YPVS is connected (becomes yellow and black at the YPVS controller end).
All other electronics are working just fine.
I think I have to conclude that there is a fault with the YPVS controller circuit board. Perhaps one of the components has given up after 35 years. This would not be too surprising, I guess.
The valve does the initial bizz buzz at start up, but no movement as the engine builds revs.
Does anyone know of a good replacement system for the PV controller?
PostPosted: 06:49 - 15 Jun 2026    Post subject: Reply with quote
Zeeltronic is the one everyone uses and it's REALLY good, but it does ideally need setting up to get the best from it. I think the defaults tend to be pretty decent though.
We are very lucky to have access to a quality replica of such a niche item, the people who make it are bona fide geniuses.
However, lots of people are quick to jump to the conclusion you've made about the PV controller. If it cycles OK on start up, then I can't see how it would fail at other times, but I can see how a wiring or earth connection could break down at temperature (i.e. when the engine is hot). You can go for a Zeeltronic, and it may well fix the problem but I'd ONLY be doing that if I had a surfeit of cash and a deficit of time to be honest. The Zeeltronic is cool, and when set up properly you can get a bit more out of even a stock YPVS engine with it but they aren't cheap.
https://www.zeeltronic.com/page/yamaha.php
https://www.mb-designs.co.uk/webshop/road-and-road-racing-bike-specific/yamaha-rd250lc-350lc-350ypvs/ignition/zeeeltronic-pcdi-10vt/
YPVSdreamer
PostPosted: 18:10 - 15 Jun 2026    Post subject: Reply with quote
Thank you again MarJay,
I agree, and I will be thoroughly investigating all possibilities. Checked the condition and output from the potentiometer in the solenoid unit today, and all is well there.
I am also slowly going through the entire loom to test all connections, replacing the fuse box, which is quite corroded, and which is an overdue bit of maintenance anyway, and you never know, when it all comes back together, it may have sorted it. Forever the optimist.
Zeeltronic does look good, and I have been quoted just under £300, including the programmer and postage. So at that price, it is very much the last resort.
Just to confirm - would you expect the PV pulley to move about 30 degrees clockwise as soon as the engine fires up? I have seen this in a YouTube video, and it would make sense in terms of PV position for low revs. My bike does not do this bit, or move as the revs grow. As stated before, it does the ignition on routine without fault. All very curious.
Thanks for the links. Appreciated.
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 59.9 Kb
