Yamaha XSR 125 seems a bit unstable
Seansmit17
PostPosted: 00:49 - 20 Aug 2026    Post subject: Yamaha XSR 125 seems a bit unstable Reply with quote
My YBR's front end feels wobbly and unstable at 60 in corners but fine other wise
But I just got an XSR 125 and it feels very unstable on the front at more than 40 ish. Any bumps etc and the front end wobbles really easy.
Tyre pressures are good. Is this just the way the bike is or is where some other things I can check over?
Its a 74 plate with only 1080 miles on it. 1300+ now I got my hands on it Very Happy
PostPosted: 07:13 - 20 Aug 2026    Post subject: Reply with quote
A feeling of instability in the front is usually coming from the rear end. So you've done the first thing which is tyre pressure.
Also check wheel alignment, check for play in the bearings (wheel and swingarm) make sure all the bolts are tight on the wheel and suspension, no buckling in the wheel, chain tension correct.
twowheelwonde...
PostPosted: 20:38 - 23 Aug 2026    Post subject: Reply with quote
stinkwheel's covered the mechanical side. only thing i'd add is you said the YBR does it too. two bikes both feeling vague up front usually points at how you're sat, a deathgrip on the bars makes a light one wander. try loosening your arms off next run.
twowheelwonde...
PostPosted: 21:11 - 01 Sep 2026    Post subject: Reply with quote
Front-end wobble that shows up over bumps and in corners on more than one bike points at the steering head bearings first. If they are slightly loose or notchy the front follows every ripple. Worth checking for play by rocking the forks with the front wheel off the ground, plus wheel bearings and tyre profile.
GentleMeadow
PostPosted: 23:07 - 02 Sep 2026    Post subject: Reply with quote
fair enough, definitely worth checking that out before taking it apart further
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 41.96 Kb
