Prepping for Winter
synaptyx
PostPosted: 00:58 - 12 Oct 2004    Post subject: Prepping for Winter Reply with quote
I've done a search, but turned up nothing (maybe I'm just rubbish at searching).
Is there a good solid guide around here somewhere detailing specifics of good winter prepping for your bike? If I manage to get my head out of my arse I should get this done pretty soon right? What do I do with bits that already look a bit rusty? What kind of exhaust paint is best? Which bits do I paint anyhoo? Oil aside, what other fluids need looked at? The black plastic bits round the lower part of my forks (round the bits the top of the forks slide into) are looking cracked, what are they? Do they need replacing? I did get a scotoiler recently, so that's the chain taken care of, or is it? It's looking a bit loose, but I don't know for sure.
Any and all advice appreciated.
Resident tech n00b.
mr.z
PostPosted: 03:19 - 12 Oct 2004    Post subject: Reply with quote
Fist things first, if you intend doing anything to your bike, get a manual, haynes, clymer or the factory manual if you can.. because it will save you any nasty supprises when something flys accross the garrage when your not expecting it, or you end up takeing something off that needs the seal replaceing... (which you never have unless your expecting to)
First thing to do is fill the fuel tank... whattt? yes really, it wont go rusty with a full tank, but when you get to summer dont use that manky stale petrol, put it in a reasonably full car...
Switch the fuel off, run the bike till it dies, that (as far as i know) empty the carbs and fuel system, that way it wont get gunked up...
Take the battery off, being very carefull if you have an injected bike (because it wont do your ecu much good afaik...)
The little plastic bits are fork shrouds, a comprimise between clean forks and not looking crap (i.e. gaiters, but they do keep you forks in top condition) all they do is stop dirt getting at your forks, which can scratch them, which = knackered fork seals within 5 minutes of changeing them and allot of hassle... you really dont want pitted forks... if they are keeping the filth off and are not about to fall off then dont worry about them.
The chain should have a certain ammount of play (it depends allot on your bike) at the tighest point, move the wheel arround while you push against it, it will tighten up, this is where you mesure the play from... if its loose (which it probably is, they stretch) the adjustment bolts need to be tightend or loosened *equal ammounts, you can get the laser alligned, this will make your chain last a allot longer apparently...
Thats all i can think of really, appart from oiling any controll cables... i might have missed allot out but thats probably what i'd do... but then i don't Razz
*very important, if its not alligned properly it will kill your chain and sprockket fast, could result in iffy handleing at best and explodeing chains at worst...
Jaz
PostPosted: 06:38 - 12 Oct 2004    Post subject: Reply with quote
Unless, like my Bandit 6, you dont have an off position.
The manual states you should fill the tank, add some additive to stop the fuel killing your engine, run it for a while to mix it, then de-fuel the carbs.
Shame it does not mention how to do this !
Not that I want to winter my bike but anyone know how to do this ?
synaptyx
PostPosted: 07:33 - 12 Oct 2004    Post subject: Reply with quote
Thanks!
I was more meaning what should I do to keep 'er running nice and looking after the physical condition in the winter. Smile No garage you see, the poor beast is sitting out on my front path.
Ninja
Caption Abuser
PostPosted: 08:19 - 12 Oct 2004    Post subject: Reply with quote
As I'm using mine as much as possible, I'm currently washing/ covering it with that Scottoiler all over protective spray (FS385?) - I've been recommended liberal doses of WD40 as an alternative.
James
4 wheels transport the Body ... 2 wheels transport the SOUL
stryker
PostPosted: 08:28 - 12 Oct 2004    Post subject: Reply with quote
For starters you need to check you have antifreeze in your coolant. Is your bike water cooled?
All through the winter I'd regularly wash the thing to ensure any road salt is removed (make sure to wash in all the nooks and crannies) and then dry the bike, then wipe all down with a clean oily rag. (get yourself a can of wd-40 or general maintenance oil spray).
Someone will have better details for this but you may need to check your tyre pressures as they will be running cooler in the winter. This stuff would of been in the manual if you had it.
mr jamez
PostPosted: 09:25 - 12 Oct 2004    Post subject: Reply with quote
Well a waterproof cover is probably a good idea and if you keep everything polished it shouldn't corrode. If you keep it clean, and don't let the salt just sit in the bike, It will probably be ok. Perhaps if the frame is prone to rust you could brush a bit of waxoyl on there, don't spray it though because if it gets on anything that will get hot it will produce lots of smoke Smile
map
Mr Calendar
PostPosted: 09:27 - 12 Oct 2004    Post subject: Reply with quote
zero wrote:
...empty the carbs and fuel system, that way it wont get gunked up...
Jaz wrote:
...then de-fuel the carbs...
Word of warning. Emptying the carbs can cause the diaphrams to persish/crack. They're usually not too cheap to replace either.
Best put fuel stabiliser in the tank and run engine till sure mixed through carbs. Leave and then run weekly.
If you keep running the bike make sure you start it long enough to full warm it up and ensure all the condensation is out of the exhaust.
If you're using the bike over winter suggest you invest in power washer to keep the salt and crud at bay (don't use near wheels).
Also think about using the anti-corrosion/preserving spray stuff. The FS365 from scottoiler gets good press.
HTH Smile
map
Mr Calendar
PostPosted: 09:34 - 12 Oct 2004    Post subject: Reply with quote
Ninja wrote:
...I've been recommended liberal doses of WD40 as an alternative.
No, don't do it. WD-40 is a good quick start fix, not a long term solution. (hint, WD stands for Water Displacement).
The WD-40 will create a sticky film which will attract more gunk and crud and you'll be worse off than if you hadn't bothered.
HTH Smile
Sadie
PostPosted: 09:35 - 12 Oct 2004    Post subject: Reply with quote
Hints & tips for protecting your bike from the bad weather in winter
Degrease bike really well with Gunk or Jizer, pour some into an old bowl and use an old paintbrush to work it in well.
Wash the bike with car shampoo really well, use an old toothbrush to get in awkward areas. Hose off with clean water.
When dry and clean and looking at its best then:-
Polish tank/mudguards/seat surround with car polish
wipe over rubber (inc sides of tyres) and black plastic with Armour all protectarant.
Put a large dob of Vaseline into a metal tin/tray and heat up till vaseline is liquid (be carefull it is very flammable)
Paint the now liquid Vaseline onto all nuts/bolts brackets/frame bits and anywhere that gets road crap on.
Now spray all the bike except brakes/tyres/seat/lights with WD40, do it so it is dripping off the bike. Don't be afraid to spray lots on.
Lube your chain really well (after cleaning it)
That's it now you can ride it for weeks in-between cleaning it and it should come up like new, the Vaseline can be a pig to get off but at least your bike is not corroding.
With experience comes age.
iCraig
PostPosted: 15:33 - 12 Oct 2004    Post subject: Reply with quote
Waxoyl is another good thing to coat the bike with liberally in the awkward places.
I have been know to cover the swing arm and other vunrable areas in it to stop things corroding.
WD40 is also good for keeping things in tip top condition and its also a bloody good degreaser.
Another point other people haven't mentioned if your not going to be using it for a long while try and get both wheels off the floor so the tyres are touching the floor and sitting in stagnant water or picking up lots of moisture.
Also if you intend to keep her outside get a bloody good cover that reflects UV light and keeps the rain/wind/snow/hail off, or do what my mate did and get an old blanket to keep the bike warm as he put it and then put the cover on it. Wink
dandit
PostPosted: 15:38 - 25 Oct 2004    Post subject: Reply with quote
or just do what I do ride the thing and wash it regulary.................. says me the person who has only washed his bike once in 4 months but I will be doing it more often anyone know if that stuff works (the one you spray on the engine start it up and it covers most of the bike with a protective film)
WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE I STILL HAD 3 GEARS TO GO OFFICER. Currently riding a naked cbr 600 and driving a 52 plate 2litre tdci mondeo
map
Mr Calendar
PostPosted: 09:42 - 26 Oct 2004    Post subject: Reply with quote
Came across the following advice and remembered this thread.
Unfortuately I can't find the author. If anyone knows I'll credit it.
The wording would indicate it came from our ex-colonial cousins across the pond.
The best solution is to move someplace where you never get snowed in more than 3 days at a time. A man has to have his priorities. If for some inexplicable reason this is not an option for you, here's an alternative.
1. Find a nice place for your bike to spend the winter. You want to avoid water condensation. Water condensing in the engine or exhaust pipes can cause rust. You can guard against water condensation by keeping your bike somewhere where the temperature doesn't change so very much, like never below 50f. Your living room is a great place, although if you're married, I concede that your wife will likely have a different view on this point. A heated and secure garage would be good. An unheated garage is next best. Outdoors under a waterproof tarp where the bike is sometimes in the sun is the worst possible location. The daily heating and cooling under a waterproof tarp is guaranteed to cause water condensation. Avoid wind, dripping water, damp and musty places, and vermin. Another thing to avoid is a garage holding a dryer which is not vented to the outside. Make certain your dryer is vented, or you'll pay an extraordinarily high price. Unvented dryers have been known to lead to completely siezed up motors.
2. Completely wash the bike and dry the bike. Wax the bike and polish all the shiny bits.
3. Clean and lube the chain.
4. Gasoline oxidizes as it ages. This produces varnish as a byproduct, which is bad for carburetor jets and fuel injector outlets. To avoid this use a fuel stabilizer. Add the amount recommended on the bottle in the tank and fill the tank completely with gasoline - a full gas tank won't rust internally. Run the engine for a couple minutes to warm up the engine oil and to get the stabilizer into your carbs/fuel injectors.
5. Now that the engine is warm, you can change the oil and filter. Water in your crankcase oil will combine at room temperature with sulpher to form sulpheric acid. This is a bad thing. The sulpher mostly gets into the oil as combustion by-products, so if the oil is new, this is not a problem. Synthetics have a big advantage here: the increased film strength of synthetic oils means it takes considerably longer for the oil to all drain down to the oil pan, so when you finally do start your engine there's still a little oil on all the bearings. If you drained out normal oil and replaced it with synthetic, you have to start the motor and run it for 30 seconds to get the synthetic oil pumped all throughout the motor.
6. If you have carburetors, turn off your fuel and drain your float bowls.
7. Some people like to remove the spark plugs, put a tablespoon or two of oil into each cylinder, and turn the engine over a couple times. The idea here is to coat the iron cylinder sleeves and iron piston rings with oil to help protect against rust. It's been about 10-20 years since Japan, Germany, Italy, or Milwaukee shipped an engine with iron cylinder liners or iron rings, so this is not really necessary anymore. Doing this makes the bike harder to start in the spring, obviously.
8. Spray Pledge furniture wax on any chrome, or polished or raw aluminum.
9. Clean and treat all leather.
10. Treat plastics and vinyl with Armorall. If you really want to go nuts, you can armorall your tires and hydraulic hoses too.
11. Put some motor oil all over the front fork tubes. Get on the bike, hold the front brake and bounce the bike up and down to work the front suspension. This will keep the rubber seals from drying out and protect the exposed fork tube.
12. Check your battery, make sure it’s full. If not, add distilled water. Use a trickle charger every four weeks or even better, get a "Battery Tender" and leave it on 24/7.
13. Check your radiator level, add aluminum safe antifreeze as necessary.
14. Put the bike on it's center stand to take as much weight off the wheels as possible. The tires don't like to sit in one place with weight on them for a long time. This is a bigger problem if you live in a city with smog, as the ozone makes this problem a lot worse. On the center stand the bike is almost balanced, so the rear tire is in the air and the front tire has only maybe 50 pounds on it.
15. Use plastic wrap and rubber bands to seal the outlets of the mufflers. Also seal the engine air intake, if you can get to it.
16. Use a good breathable motorcycle cover to keep the dust off. Don't use plastic covers, they trap moisture. An old sheet works great.
17. Before you start the bike again, remember to remove the plastic from the exhaust pipes and airbox inlets, and wipe the Pledge wax off the exhaust pipes. If your memory is as bad as mine, you might tape a note to yourself over the ignition keyhole. You don't have to worry about the fuel stabilizer, it will just burn away.
18. You can just leave the bike in this condition for many months. You don't have to worry about valve springs - modern valve springs that are made to allow the engine to rev to 8000+ rpm won't sag. If you're so desperate for a motorcycle fix that you simply have to start it, make certain to run it for at least 5 minutes or so. Starting your engine for, say, 30 seconds is a bad idea - you pay the extra wear and tear price of starting an engine where the oil is cold and has all sunk to the sump, and you don't heat the oil and exhaust up enough to boil off sulpherics and water vapor. Remember to open the garage door while the engine is running.
HTH Smile
The last post was made 22 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 90.45 Kb
