G |
G The Voice of Reason
Kickstart |
Kickstart The Oracle
Posted: 17:02 - 29 Oct 2004 Post subject: |
Not really sure how much good it will do running a cam chain in. Probably worth taking it easy then checking the tensioner is working (or adjust it if it is a manual tensioner).
The principle is exactly the same for a cam chain. However given that it is a single the cam chain must be at the end of the crank so I would be tempted to just use an endless chain.
The tappet is likely to just be a bolt with a lock nut (in effect). You just slacken the lock nut then turn the bolt to get the valve clearance correct then tighten up the lock nut again, then double check the clearance (and do the whole thing again as tightening the lock nut up moved the bolt ).
Robby |
Robby Dirty Old Man
G |
Posted: 18:07 - 29 Oct 2004 Post subject: |
Cheers .
The camchain I've ordered is an endless one, but also comes with a rivvet link.
I presume setting the timing means matching up marks on appropriate gears that the chain goes around?
So, how exactly do I set up the valve clearances?
I have a manual, but it's a scanned german one. |
mr jamez |
mr jamez World Chat Champion
Posted: 18:14 - 29 Oct 2004 Post subject: |
Well if they are anything like mine Turn the engine over until the valve is fully closed (easiest to put it in top gear and push the bike or use the clutch to *jerk* the egine over) then use a feeler gauge to measure the gap between the valve stem and rocker arm, it should slide in with some resistance, kind of like a smooth stiff sliding. If it is incorrect, undo the nut on the adjustment stud, and turn the screw. I triple checked mine, as kickstart said when you tighten the locknut back up it usualy turns the adjustment stud.
On my car, I had to do this in sequence e.g. valve no 8 fully open then check and adjust valve no 1 |
Robby |
Robby Dirty Old Man
Smoto Bob |
Smoto Bob World Chat Champion
Posted: 18:34 - 29 Oct 2004 Post subject: bike |
Easy if you have another engine to look at lol and it you can turn it over by the crank then thats a good sign as well :p
What they all said ____________________ F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
Titz wrote: "..and my 3rd accident was when this police car....." |
Guest |
Guest Brolly Dolly
Kickstart |
G |
Robby |
Robby Dirty Old Man
G |
Posted: 13:30 - 28 Nov 2004 Post subject: |
robby wrote: | Measure the ring end gap to see if they are knackered. |
Haven't got the actual barrel of yet, it /looks/ ok and I don't see how the rings could have got damaged.
Quote: | Did you grind the valves in? Could there be a lot of shit sitting on the back of one of them. |
It was just the tappet adjuster that went, so the same valves, this is the first time I checked.
Quote: | Make sure the cam timing is spot on. Was a cunt to set up on the cb250. |
Took quite a while doing that, double checked it all etc.
Quote: | Does it have a decompressor cable? Will be a cable going from somewhere near the kickstart to up at the cam(s). Disconnect the cable, and make sure the actuator inside the rocker cover isn't jammed holding a valve open. |
Checked that before taking it apart, seemed to be fine.
I may try reassamebling it in the hope that I missed something out or it's just some random occourance. |
Robby |
Robby Dirty Old Man
Kickstart |
G |
G |
Posted: 17:28 - 28 Nov 2004 Post subject: |
Well, think I found the problem.
The valves are not fine.
I can see some light between the exhaust ones when they should be closed.
Looks like they are quite rusty on top as well.
It would seem there is a hole on the head casing between the two exhausts . I presume this was there when I got it . You can't really see it without taking the casing off thanks to the positioning of the frame.
I presume the rust has happened while it has been sitting out in the damp.
What to do now then?
I'm thinking I might try and find a new head, complete, as I don't really feel confident playing with valves (and don't have any of the tools suggested in the manual). I was also wondering about just giving the head to a garage and saying 'sort it'; the local good garage probably doesn't have the 6 week waiting lists it has in summer. |
Kickstart |
Robby |
Robby Dirty Old Man
Hex |
Hex Party Boy
Posted: 20:54 - 28 Nov 2004 Post subject: |
Drill and grinding paste, saves HOURS on lapping valves in.
Put the valve stem in the drill and make sure theres paste on the valve and turn on the drill. Then simply pull the valve to the seat and away and to and away etc etc etc till the majority of the lapping is done. Then finish by hand, ensuring there is an unbroken ring around the valve seat where it has been lapped in. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
G |
Smoto Bob |
Posted: 11:24 - 29 Nov 2004 Post subject: |
G |
Smoto Bob |
Posted: 15:33 - 29 Nov 2004 Post subject: hole |
so i guessing its not actually in the rocker cover lol
And its not in the head and downward so you can see into the combustion chamber
Then its not that bad lol, some high temp araldight
Like here but on the front i am guessing, only seals it from outside world doesnt realy do anything high teck didnt loads of oil come out lol ____________________ F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
G |
Hex |
Hex Party Boy
Posted: 17:51 - 29 Nov 2004 Post subject: |
Bit of epoxy metal... bodgery at its best mate. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
The last post was made 19 years, 153 days ago. Instead of replying here, would creating a new thread be more useful? |
