ts50x0 Spanner Monkey
The Tot World Chat Champion
Posted: 21:53 - 08 Nov 2004 Post subject: |
I did my CBT on one of those - utter shits - the tach was all over the place and not reading correctly - i musta been doing warp speed . It does however have a gear indicator - but useless when you have the sun shining on it. It produces a tad less than a genuine Honda, but chinese bikes are cheap and cheerful, until they break - my advice - stick with HON-DA! They'll be bulletproof! ____________________ The Tot 2007 Yamaha R1 4C8 2002 Yamaha FZS1000 Fazer &
www.youtube.com/Titot182 for your bike gear reviews and pop punk covers
Earl Of Easycore Pop Punk Will Never Die! |
mchaggis World Chat Champion
Posted: 23:46 - 08 Nov 2004 Post subject: |
Well... I've had no problems with a Hongdou (see my profile for the pic), apart from a few key things. The rev counter went crazy, all the way around the clock, and eventually the needle managed to fall off after I'd fixed it... The speedo drive is sticking and hopping, it was stuck not going over 42 for a while last week, eventually I managed to unstick it doing 60 on a dual carriageway for a few minutes.
A bulb blew after 150 miles. It was an obscure Chinese type which I could not get here. They are also less powerful than the Honda CG125, mine does 55-60 wringing it's neck, and geared up.
Resell value? Assuming it stays alive long enough I imagine it'll get passed down the family for my siblings to learn to ride on. Maybe after that if the frame and things have rusted to pieces, I'll take the engine and build me a dune buggy or something.
On the plus side, it's extremely crashproof. I've crashed it (to various degrees) four times, once seriously, twice binned it (gravel and wet roundabout), and once caught the footpeg in the verge as I was coming to a standstill. Not an item has been damaged. Scrapes and a couple of dents, and that's your lot. I accidentally dropped it moving it when I slipped on moss the other day; the clutch lever was ever so slightly bent, after effectively dropping onto it from perhaps 4 feet. Having said all that, a CG is very probably just as crashproof, though said CG snapped a mirror at 0mph.
Mine's really really comfortable with much better suspension than (the 11 year old CG I am comparing it with) though.
Still, I'd just get a CG125 for less than £800, and sell it when you do your test, perhaps losing maybe £100 max. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush. |
pipnet11 Brolly Dolly
Full Bananas Renault 5 Driver
