Fix one, another fails... (speedo this time)
Bomberman
PostPosted: 16:44 - 12 Nov 2004    Post subject: Fix one, another fails... (speedo this time) Reply with quote
Rolling Eyes
Well hell. Just this very morning I picked up my bike which had had a new monoshock fitted and the steering head bearings replaced (Well, fixed, the previous owner had removed a few balls Confused). Drive bike home and it feels beautiful Thumbs Up
Sit about for a while and the sun comes out and the roads begin to dry off nicely so I think "Get petrol, then disappear on the A57 for a while" Very Happy Good plan Thumbs Up But not...
Arrow Half a mile in I notice my speedo has gone completely mental and no amount of tapping at the dial will fix it Wink Basically it just oscillates wildly over a range of 10 milesish. It's roughly near my actual speed, but won't go over 40ish, and I did exceed 40, so remarkably unsafe Thumbs Down
Anyone? Please someone say squirt x with WD40 and it'll be fine Wink
mr jamez
PostPosted: 16:51 - 12 Nov 2004    Post subject: Reply with quote
Is it driven off the front wheel or sprocket?
Not to hard a job to check it if is on the front wheel, you can unscrew the cable from the speedo then spin the front wheel to make sure that is going round ok. As for the speedo drive, you will need to take off the front wheel to get at it. If it is broken it will be pretty obvious, it is only two gears, check the whole cable out as well obviously.
kasandrich
PostPosted: 16:54 - 12 Nov 2004    Post subject: Reply with quote
If its working but jumpy, then it probably wants oiling, wd40 may do it in the short term, but in the long term some heavier oil would be better, like engine oil, or gear oil.
Richard
CBR1000FM
mr.z
PostPosted: 16:55 - 12 Nov 2004    Post subject: Reply with quote
I completely know the feeling, mines been the same, one thing after another, rev counter went and havent fixed it, i think replaceing stuff jinxes you or soemthing?!?!
Anyways... I think your cable is dead, or getting close to dead, my cg did the exact same thing, i'm presumeing its a gear driven and not an electric speedo? hopefully a £10 cable should fix your speedo, you will need to get the drive off the front wheel (or whereever its driven from, what bike have you got?) and where it joins into your clocks, probably behind the headlight, hope you have some good screwdrivers!
That will fix it, make sure to grease/oil this one properly, oiling your cables every so often will save things like this happening.
If it dosent fix it its new clocks time its hugely unlikely they are knacked though
kasandrich
PostPosted: 16:57 - 12 Nov 2004    Post subject: Reply with quote
As per Zero's posting a new cable for about a tenner is a possibility, but I was trying to save you money, by avoiding the new cable.
Richard
CBR1000FM
Guest
PostPosted: 17:04 - 12 Nov 2004    Post subject: Reply with quote
they always used to warn against using thin oil in speedo cables as it could get sprayed up inside the actual clock.
Bomberman
PostPosted: 17:31 - 12 Nov 2004    Post subject: Reply with quote
Many replies Very Happy
Firstly, sorry! It's a 1989 TZR 125. I'm starting to be an idiot for not mentioning that Rolling Eyes
Ok, firstly, it is run off the front wheel and is just a bsic gear mechanism.
Kasandrich I wouldn't call it jumpy at all. It moves very smoothly, but wildly. Pulling the cable off the drive and the clock revealed a goodly amount of grease on each end too. However, I have no idea how old this cable could be Confused
zero, same problem? Hmmm. A replacement cable would be a nice easy fix Thumbs Up
This incident has brought me to a very basic realisation Embarassed How the hell do I get either wheel off the floor? No centre stand (and I have no paddock stand or anything like that). I've read about resting the block on wooden boxes which would be fine but for the fact that my exhaust runs underneath the bike for its length Confused
Reevo8
PostPosted: 17:42 - 12 Nov 2004    Post subject: Reply with quote
Axle stands under the exhaust? Resting on the exhaust shouldnt cause a problem!!
Bomberman
PostPosted: 18:19 - 12 Nov 2004    Post subject: Reply with quote
Reckon? Fair enough, it's just the thing looks feeble to me...Confused
Reevo8
PostPosted: 18:32 - 12 Nov 2004    Post subject: Reply with quote
If its in a garage, you could always suspend it by threading some heavy duty rope through the forks, and tie it to the garage support beams!! You could try this as well as the axle stands for extra safety!!
Bomberman
PostPosted: 18:59 - 12 Nov 2004    Post subject: Reply with quote
Heheh, thanks for the ideas Very Happy Sadly, I have no axle stands, and the garage has no beams Thumbs Down Very Happy Ah well, I'll work something out.
Just out of interest, does anyone else think it's a little coincidental that my bike has work on the steering head bearings and then that very day the speedo fails? Or am I just being pissed off? Probably.
Another Q., is there a specific way the cable should be fitted? I notice one end has a retaining "blob" (for want of the correct word Very Happy). That end to speedo, wheel or does it not matter?
Guest
PostPosted: 20:02 - 12 Nov 2004    Post subject: Reply with quote
Usually the ends are completely different - there's a 'square' end where it fits into the speedo and a forked end at the wheel.
Bomberman
PostPosted: 20:17 - 12 Nov 2004    Post subject: Reply with quote
That's interesting. Not on this bike though by the looks of things as both ends on mine are square and look to all intents and purposes identical. (I bought a new one and its the same too). As above the only difference is a "blob" to stop the cable being pulled through in one direction.
Guest
PostPosted: 20:23 - 12 Nov 2004    Post subject: Reply with quote
That'll be at the bottom (wheel) end then I reckons
mchaggis
PostPosted: 22:07 - 12 Nov 2004    Post subject: Re: Fix one, another fails... (speedo this time) Reply with quote
I've exactly the same problem, down to the T. It wobbles plus or minus 5 mph at about 45, by the time it gets to 55 it can't decide whether it's doing 40 or 70... Rolling Eyes It got stuck at 42 a while ago too, it just wouldn't increase any more despite my going down a steep hill. It's a gear driven drive, so perhaps a replacement CG125 drive cable would do...
Both ends on my cable are round though, the top one screws to the clock, and the bottom one is held in place by a screw running through a groove around its circumference.
I must not be a troll...
Mmmm, Guinness
mr jamez
PostPosted: 23:46 - 12 Nov 2004    Post subject: Reply with quote
Personaly I wouldn't risk an axle stand under the exhaust Confused the best way I have found is to shove a pole through the frame and use axle stands and other stuff under that.
pipnet11
PostPosted: 00:08 - 13 Nov 2004    Post subject: Reply with quote
An effective but slightly dodgy way of supporting the bike if you have no centre stand is 2 bottle jacks, side by side under the engine. This is difficult though 'cos you've got to get them to rise at the same time by the same amount. Easier said than done.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
mchaggis
PostPosted: 00:29 - 13 Nov 2004    Post subject: Reply with quote
And here I was thinking shoving a tree trunk under the crankcase might be a bad idea... Laughing All it needed was someone to hold the bars so the whole thing didn't fall over, and the front wheel came out and went back in without too much trouble. Paddock and centre stands are a lot better though.
Mmmm, Guinness
Bomberman
PostPosted: 17:20 - 13 Nov 2004    Post subject: Reply with quote
Aaaarrrggghhh!!!! I am so close to kicking the hell out of my bike at the moment! Evil or Very Mad
Right. Is there a knack or correct way of fitting the speedo cable? God knows I've tried many times, but now I get no response from the speedo itself at all (with both the old and the new cable).
Shove the cable into the speedo and spin it and it registers, so the speedo seems OK. Shove the other end into the front wheel gear bit, and there's resistance so I'd guess at that bit being OK too. Put them both together and nothing happens at all! (Well, an occasional flicker Rolling Eyes).
Or am I just so mechanically inept that I can't even fit a new speedo cable?
Missed out on a beauty of a day for riding today too Crying or Very sad Thumbs Down
Guest
PostPosted: 22:18 - 13 Nov 2004    Post subject: Reply with quote
It's unusual, but not impossible, that the gearbox drive is shot. Look down the hole and spin the wheel to see if anything's turning (it should be)
Then fit the cable to the drive box and spin the wheel again to check that the inner cable is turning. If it is, then fit the speedo end.
binge
Emo Kiddy
PostPosted: 23:41 - 13 Nov 2004    Post subject: Reply with quote
have you actually driven it while connected at both ends. I thaught i had that problem but it was becase i couldnt spin the wheel fast enough.
I got so frustrated with it.\
good luck... Ben
PostPosted: 01:02 - 14 Nov 2004    Post subject: Reply with quote
Which bike is it? Could be the speedo drive (the NSR one is notorious).
Bomberman
PostPosted: 04:00 - 14 Nov 2004    Post subject: Reply with quote
Well, shite. Again I don't know what to do with it. I have spent a bloody fortune on this machine! Evil or Very Mad (relative admittedly, but being a bastard student you don't have much to fart around with Crying or Very sad and I've worked like a tit).
Kickstart, it's a TZR 1989 F plate build.
binge, oh yes I have. All around the locale to see if it is working vaguely. And no Thumbs Down
Guest, possibly nearest to the problem, but I really don't know Thumbs Down
I'm pissed at the moment. Sorry. Gotta hit the bed soon... in fact, now...
binge
Emo Kiddy
PostPosted: 22:49 - 14 Nov 2004    Post subject: Reply with quote
Sorry for such a short message earlier, I was on a touch screne keyboard and couldnt be bothered to type much.
If it is turning at the clocks when you spin the cable with your fingers at the wheel end, and turning at the clock end when spinning the wheel, but when they are together it dosent work, it sounds like the inner cable may be a tad too short and not gripping both ends together.
I had a similar problem, what i did was fit it on at the wheel securely. then at the clock end, push your little finger (or a screwdriver) into the cable to push the inner cable down into place so its secure at the drive end. then fit it to your clocks.
Good luck...
Ben!
Bomberman
PostPosted: 19:01 - 16 Nov 2004    Post subject: Reply with quote
I just had a mechanic sort it out, as I couldn't get it to work and they happened to have a speedo gearbox drive in (they'd had it in the back for 14 years Very Happy). First thing he asked me was "What caused all the damage?", followed by "did a mate put the wheel back on?". Hmmm.
Cue Bomberman's sudden shift of garage loyalty Evil or Very Mad
Thanks to all for the replies and advice Thumbs Up
The last post was made 21 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 133.86 Kb
