Cav |
Cav L Plate Warrior
Posted: 17:10 - 23 Nov 2004 Post subject: My Aprilia RS125 keeps over-heating. |
I have a Aprilia RS125 Tetsuya Harada and I'm having problems with it over-heating.
When going along in open air, it runs at around 70 degrees C which I believe is the correct temperature for an RS125. If I hit traffic, it seems to ok for a while. It'll stay around 80-90 for a few minutes. As soon as the temperature hits 90, it seems to rocket and before long I have coolant escaping from the cap and dripping onto the engine which causes a lot of steam.
I have checked that there are no airlocks in the coolant, and that the air vents are clear. Apart from this, the bike runs perfectly.
Is it expected to overheat like this? I know that it doesn't have a fan on the engine and the only way it cools down is from air in-take, but surely they're not designed to get so hot? It has reached the high 90s many times and today it went slightly above 100 before I was able to pull over and let it cool down. The weird thing is that all I need is 20 metres ahead of me to quickly accelerate down and it drops the temperature by 10 degrees or so. It's more of a problem when the traffic isn't moving and I'm stuck, not moving anywhere.
Can anyone help, or give me some advice?
Cheers |
Guest |
Guest Brolly Dolly
mr jamez |
mr jamez World Chat Champion
Dom |
Dom World Chat Champion
Kickstart |
Kickstart The Oracle
mr.z |
mr.z World Chat Champion
Posted: 03:07 - 24 Nov 2004 Post subject: |
A guess but your readiator cap could be past its service limit...
The cooling system is pressureised, because at higher pressure the boiling point is higher, so it can get hotter without boiling over... i'm not sure how you check them but a trip to the breakers to get another might be worth a go?
If its getting hot rapidly then the thermostat could be stuck/knackered?
Another that the radiator is blocked, not cooling afficiently enough, flushing it out with a garden hose, then rad flush a few times then a couple of lots of deionised water and then the propper mix should get rid of any nasties that have got caught in the radiator...
Either way, try and get it sorted asap, overheathing might not seem to do any damage but its bad news, and being a two stroke it will like you even less for it (read engine rebuild allot earlyer than normal + possible warpage of engine insides) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
Cav |
Cav L Plate Warrior
Posted: 12:40 - 24 Nov 2004 Post subject: |
Thanks for the replies
I should have mentioned in my original post that I have replaced the cap on the coolant tank as I thought it might have been losing pressure, but that doesn't seem to have cured it.
The thermostat sounds like the most plausible answer so far. I guess I could test it by removing it? and see if that reduces the temperature? Would the only downside to removing the thermostat be that it would take ages to warm-up?
I would drain the system but I can't find the drainage valve :/ |
Kickstart |
Posted: 13:28 - 24 Nov 2004 Post subject: |
If the problem is the thermostat then the radiator will be cool, but the same will apply if the coolant mix is too strong or if the water pump is shot.
You can check the thermostat, basically by sticking it in hot water and checking the temperature that it opens at.
Not sure about removing it. Chances are that on the RS it will just never warm up. On some cars removing the stat can cause them to overheat.
The cooling system drain is on the front side of the engine and is labelled "Aqua". It is a small allen key bolt and looks like one of the ones holding the 2 halves of the crankcases together.
Frost |
Frost World Chat Champion
The last post was made 19 years, 157 days ago. Instead of replying here, would creating a new thread be more useful? |
