stryker |
stryker Brolly Dolly
G |
G The Voice of Reason
Posted: 15:18 - 26 Nov 2004 Post subject: Re: crazy idea: geared vari-drive |
To start with, you have a clutch that can do that .
You shouldn't really have a problem with flat spots the majority of bikes when ridden properly.
If you can get it working like that, you can probably get it working with a full system.
If you could have seperate controls of the drive and the rpm then there is a lot of possibilities (not just the drive increasing with rpm)... You can be at full rpm all the time, then increase and decrease the drive to change speed, making full use of the engine.
Or you can set the power lower for exiting a corner, and be fairly safe in the knowledge that when set right you'll be on the limits of traction however much you up the speed.
You'd also have the option to use it like standard gearing would be used.
I however believe there is serious problems with using vari-drive style things on high power machines.
I have considered various designs for sprocket systems that can dynamically adjust their size, but haven't come up with any serious practical ideas.
The part on a scooter that actually eliminates flat spots is the centrifugal clutch really. This only engages at a certain rpm and can be set to 'slip' more or less to get better drive or a smoother launch.
I believe centrifugal system are available for mx bikes; this means they can have maximum power from low down without having to play with the clutch when they're navigating a berm. Also means their bike won't stall if they drop it . |
stryker |
G |
pipnet11 |
pipnet11 Brolly Dolly
mr jamez |
mr jamez World Chat Champion
Lone-Wolf |
Lone-Wolf World Chat Champion
Posted: 18:45 - 26 Nov 2004 Post subject: |
Wotcha.
Once again the old git casts his mind back . . ah ... Raleigh Runabout & Mobylette mopeds. They used this very system. The engine was suspended from the frame by its cylinder head, and moved back and forth as the effective diameter of the drive 'conical pulley' increased and decreased.
There was a slight drawback with this system, as a mate of mine found out. He was happily riding away when the bolt that suspends the engine gave way . . . the engine promptly made a dash for freedom, the drive belt snapped, the throttle cable snapped and the engine, now happily revving its head off went spinning all over the show until it had used the remaining fuel in the float chamber. ____________________ Cheers.
L.W. - www.moonshiners.org.uk |
loply |
loply World Chat Champion
Posted: 18:59 - 26 Nov 2004 Post subject: |
Continuously Variable Transmission. My dads car has it (Honda Jazz). You neednt use centrifugal force to move the belt, you can do it with a motor.
The system cant handle very much power and is quite inefficient. Honda Jazz 1.4 produces 80bhp. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
Bendy |
Bendy Mrs Sensible
Posted: 19:02 - 26 Nov 2004 Post subject: |
Unkie Wolf always has the coolest stories. |
Posted: 19:59 - 26 Nov 2004 Post subject: |
Hmmm, Daf variomatics. We haven't seen the last of those
I liked the way you could bang them into reverse when you were doing about 60mph and the whole car seemed to go Boooiiiing then shoot off backwards. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Retro-Man |
Retro-Man Traffic Copper
Posted: 20:22 - 26 Nov 2004 Post subject: |
one word
VOLVO.........
Anything that belongs on a volvo has no place on anything I would even loosely term a motorcycle
____________________ https://domharnessphotography.webs.com |
Retro-Man |
Git |
Git Brolly Dolly
stryker |
G |
yohomiesmelly... |
yohomiesmelly... Two Stroke Sniffer
binge |
binge Emo Kiddy
Posted: 18:39 - 27 Nov 2004 Post subject: |
Just like if you managed to start a scooter up in reverse it would go full speed backwards...
My mate Bill has got a piaggio APE 50, which he has had kitted out to a 90cc, Its basically lambrettor gear system in a 3 wheeled van...
If he puts it into reverse, he can go up the gears. He went to a carpark and managed to get 40mph in reverse. Im suprised he didnt roll it!
https://www.vehicle-documents.it/schede/piaggio/ape/ape1.jpg ____________________ - Honda XL125S - CBR400 NC29 - VFR400 NC30 - CBR400 NC29 - TL1000R - TeeZeR Pit! - Bandit 12 - YZF450 - LuckyMX125 Pit! - Demon X XLR 140 Pit!
- Honda Chaly 140cc - Thumpstar 190cc 4v MiniSM - Aprilia RS125 Pit-Bike - |
The last post was made 19 years, 154 days ago. Instead of replying here, would creating a new thread be more useful? |
